Question about Logitech Z-640 Computer Speakers
Logitech Z-640...missing center and 2 satellite speakers
Recently purchased a used logitech Z-640 sub w/ 2 satellite speakers...i cannot seem to find the center speaker,which links this system to my computer...ive checked ebay to no avail....is there any way to bypass this?(cord?)...will any other satellite speakers work with this sub?
MUKHTAR
  • 2017 Answers
SOURCE: Speakers not working correctly
pls swap the spk pin in to your sound card jack socket . bye
Posted on Sep 24, 2007
  • 38 Answers
SOURCE: Subwoofers not working on Logitech R-20 speakers; worked until recently
There must be a control on subwoofer, like a volume control. Turn it and check it. Also check the connections.
Posted on Jul 17, 2008
SOURCE: missing parts
i have the subwoofer but not the speakers and sound touch control center, wires or guides due to fact that they are stolen. could you help me fix this problem? i love the old one as i do not want to buy another system.
Posted on Oct 15, 2008
SOURCE: Logitech x-530 rear speakers and Center speaker not working
you have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
Posted on Dec 06, 2008
  • 43 Answers
SOURCE: logitech x230 speaker system right hand speaker stopped working
speakers do unfortutionly go bad better just to buy another speaker just watch the ohms should not be more than 8 ohm speaker. please make sure you can return if you buy incorrect.
Posted on Dec 07, 2008
I just bousght a martin ash home thearer ..how can i conect the bass??
I bought one last night i think its a fake.... doesn't even have instructions. If u figure this out let me know. But i just look up the site called the white van scam... i bought it from some guys in a white truck. And it sounds just like wat they sold me with the same canvas
Apr 18, 2012 | Audio Players & Recorders
I have a logitech Z-640 speaker system connected to a Panasonic Plasma TV and the sub woffer has no volume coming from the large speaker.All the other speakers are OK It seems there is no power going
Hi Ray,
if there is no power going thru than,might probably be your fuse in the subwoofer that's blown.What you have to do is remove the wire mesh from the front using a terminal flat screw driver. You will notice that there are screws around the speakers,remove them inorder to take the speakers out.Once you've done that take out the speakers gently so that you dont disconnect any wires inside.Turn the peakers over and you will see a fuse attached to the speaker.Try replacing the fuse with the asme ratings.
Please refer to the image below on what the back of the peaker looks like.
All the best and Good Luck.
G..
Nov 10, 2011 | Logitech Z-640 Computer Speakers
My satellite speakers are no longer working, logitech do not issue replacement satellites. Do you know if their is a way to use alternative sattelites with the subwoofer?
the back of the sub has 2 rca connections for left and right speakers so all you have to do is either find satellites that use rca connections or find or make your own "clip-on" or detachable wire to rca connection.
Dec 24, 2010 | Logitech Z-2300 Computer Speakers
How do you connect logitech speakers on the pc
1) plug the cable coming out of the satellite with the sub-woofer at the reat 2) plug the 3.5 cable jack coming out of the second satellite to the computer audio out ( generally green color connector ) connect the power adapter with the sub woofer
and you ready to enjoy the music. make sure yo switch on the the power adapter.
Oct 22, 2010 | Logitech R-20 Computer Speakers
I have installed the z 640 but I get no sound at all
  • Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  • Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  • Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  • Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Post back!
Oct 03, 2010 | Logitech Z-640 Computer Speakers
Can find driver for logitech 5.1 x-530 speekers
eBay you might type in major brand on eBay you can get a 5.25 Polk woofer for super cheap may not be logitech but iv done it and to me it sounded good. about to buy a logitech x 530 speaker set for my z 640 surround its compatible if you want the sub woofer than email me if not you can eBay your system and get a busted one to pull pars from.
Mar 12, 2010 | Logitech Audio Players & Recorders
My Logitech Z-640 Computer Speakers emit no sound
you have to reload the machine and if it continues like that,you have to buy a sound blaster
Dec 23, 2008 | Logitech Z-640 Computer Speakers
Logitech x-530 5.1
Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting. Go here to get an operations manual for this setup. http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=d*11Q7xi&p_accessibility=0&p_tbl=9&p_id=2924&p_created=1126107772&p_olh=0 Good Luck
Mar 22, 2007 | Logitech X-530 Computer Speakers
There should be a setting in your sound card, assuming it is a 5.1 surround card, that allows the card to split the signal from two input connections (normally the normal speaker input'green' and the mic input'pink')into the required 5.1 output.
Feb 08, 2007 | Logitech X-530 Computer Speakers
Logitech Z-640 Computer Speakers Logo
176 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
