Question about Fujitsu AMILO D-7820 Notebook
How to open back panel od Amilo D 7820?
I should change a battery for BIOS but I cannot open a back panel on my Fujitsu SiemensAmilo D 7820... I removed all screws, battery, DVD drive, RAM, HDD, but there should be some "catch" I cannot find. Anybody knows??? Thanks!!!!
  • Lovrencic Jun 02, 2010
    dear pal registery, thank you very very much!!! Otherwise i solved a problem few moths ago, but I want to thank you!
@cbacer
a faulty/ flat or removed CMOS battery
results in a warning that Time and Date have to be reset
and that default cmos settings for bios are in use
(i have the same labop an tried it out 5 min ago)
however not everything is lost: a bios password will not be removed
to remove the bios battery you have to tild back the display
all the way back until its horisontal
with a flatt screwdriver(vertical) inserted between the display an the cover of the hinge slightly push the screewdriver away from you (to release the plastic clamps from the backside of the hinge-cover)
do this on both sides
remove the hinge cover (be aware the power button cable is still connected to the cover and should not be forced)
now you can see 3 screws from the keybord , remove them and pry open the keybord beginning nearest to the display
(dont froce the flatt cable under the keybord)
now you see lots of aluminum plating.
you have to remove the one on the upper right side
and the one in the middle (pay attention not to lose any screws inside the labtop they probably short out something)
the cmos battery is wraped in blue rubblefoil and connected to
a smal connector
-be aware this is no trivial endevor.
-you have to be grounded at all times (electro static discharge up to 200kV is mighty destructive when it comes to computer organs)
-if your doing this the first time get somebody to assist you and -take pictures every step of the way so you can retrace you steps
-get a few smal containers for the different types of screws
-use tweezers and not magnets to retreave lost screws
-never ever use brute force, computer designers do not consider
structural integrity a hight priority
Posted on Jun 02, 2010
Testimonial: "Thanks a lot!!!!"
    Genius:
  • 1,584 Answers
DO NOT ATTEMPT THIS PROCEDURE or at your peril, why do want to change this battery as it involves a complete strip down to the bare mobo, a job only to be undertaken by someone who knows how to do this!!!
A faulty / flat CMOS battery is indicated with NO startup at all
Posted on Feb 08, 2010
Testimonial: "..."
Reset bios motherboard
RTM - Read The Manual.
Get onlineand got to www.google.com In the google search box type: "FujitsuSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals. Search the manual for bios or bios password.
Apr 28, 2012 | Fujitsu AMILO D-7820 Notebook
Fujitsu siemens d 7820 i miss graphic after to instol new xp
If it is the graphic's driver that is missing, you can go to the Fujitsu Support > Downloads page to obtain the latest drivers for Windows XP.
  1. Go to http://ts.fujitsu.com/support/downloads.html
  2. In the 'Product Search by Serial-/Identnumber' searc box, type AMILO D7820.
  3. Once the page opens, verify that 'Windows XP' appears under 'Selected Operating System'.
  4. In the list which appears, click on the '+' near graphics.
  5. Select the version of the driver you want and click on the download link.
Really hope this helps you.
May 16, 2011 | Fujitsu AMILO D-7820 Notebook
How to open the back panel of fujitsu AMILO D 7820
u can use the software herionee to change the password ...if not use the guide which is given to u with the lptp t
Feb 05, 2010 | Fujitsu AMILO D-7820 Notebook
I want the bios recognise usb flash
Start Windows.
Insert the USB flash-memory device.
Windows should recognize the device, and assign a "drive-letter", such as 'E:' or 'F:'.
Open "My Computer".
Select the 'E:' or 'F:' drive, and browse the files/folders.
Nov 14, 2009 | Fujitsu AMILO D-7820 Notebook
Amilo d-7820... Sound driver failing install.
Bad, or obsolete, driver. Uninstall the one you have now and get (as in Save, not Run) the latest version directly from Fujitsu.
Oct 18, 2009 | Fujitsu AMILO D-7820 Notebook
Where the procesor is located in Amilo A7640?
The CPU is located under the heatsink/ fan assembly.
May 09, 2009 | Fujitsu AMILO D-7820 Notebook
Replace the screen hinges
LOOK UNDER NIETH THE FEET OF THE COMPUTER AND YOU MAY FIND SOME SCREW SLOTS, OR A MANUFACTURE LABEL IS PLACED OVER A SCREW HOLE TO KEEP PEOPLE OUT OF THE COMPUTER.
LOOK IN THE HARD DRIVE, BATTERY AREA, COOLING FAN AREA FOR EXTRA SCREWS,
THEY ARE SNEAKY WHERE THEY HIDE THE SCREW HOLES AT
LAST BUT THEY MAYBE SNAPPED TOGETHER AAND VERY HARD TO TAKE APART.
GOOD LUCK
ROD THE CANDYMANGANDY
Feb 12, 2009 | Fujitsu AMILO D-7820 Notebook
How do I change the CMOS battery on my Fujitsu Siemens Amilo D 7820?
My best suggestion, is to remove the CD Drive, Battery, and Hard Drive. THen undo all of the screws on the back panel. There is no easy access panel to do this, you have to remove the entire back panel. once you have the back cover off, it should be pretty easy to replace the battery.
Feb 05, 2008 | Computers & Internet
Amilo d 7820
Try powering the laptop on without the battery in (AC plugged in). If it works, you need a new battery.
Dec 06, 2007 | Fujitsu AMILO D-7820 Notebook
Fujitsu AMILO D-7820 Notebook Logo
787 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
