Question about LG WM1814CW Front Load Washer
Where can I order a new drain pump? - LG WM1814CW Front Load Washer
    Genius:
  • LG Master
  • 1,461 Answers
You could try Espares if you are in u/k
Posted on Feb 08, 2010
My fisher and paykel top loader washng machine is bloked and will not Rinse, drain and spin. Mainly Drain as im pretty sure its blocked from fluff etc nybody can plese tel me how to unblock it? Thanks
The drain water pump is the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
Apr 10, 2015 | Fisher and Paykel Washing Machines
I thank you so much for your guidance on repairing my Affinity with the E20 code.I went through the process - It was totally clogged. I put everything back and the washer does not drain still. What do I...
The E20 code is a general pump failure code. This is usually the pump being clogged.
Try using a wet/dry vacuum on the end of the drain hose to see if there is a blockage that you don't see. If you still get the error you will need to replace the drain pump.
Here is the new drain pump to order.
Nov 25, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
PAV910AWW MAKE NOISE SPIN
The noise you are hearing is from the drain pump that was a bad design. I change out about five of these pumps a month. There is a redesigned pump that is for that unit. To replace the pump, unplug the unit, tilt the machine back and remove the belt, remove the rear bottom left side access panel to access the pump. Remove the two hoses from the pump, then remove the three screws that hold the pump down. Install the new pump in reverse order. The new pump will look completely different but that is the new design. Here is the new pump to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 24, 2012 | Washing Machines
F21 and SUDS code on Kenmore Elite 5t Steam Washer. It was not the drain line. I replaced the pump and still getting error codes
Are you using the "HE" detergent? Also, don't use to much as it will cause the SUDS error.
Oct 15, 2012 | Washing Machines
My HE2 front load wouldn't drain & spin and was making noises below. i called Affordable Repair and they said the control panel had to be replaced for $200 + labor. i said the noise is coming from u
Hi.
The noise coming from underneath is symptom of a problem with drain pump or drain line.
The standard procedure consists in accessing the drain filter to check if it is blocked, then testing drain pump. Most of the time the noise is caused by blockage at drain filter. In some case the pump is gone.
The control panel gets replaced only after checking drain filter, testing drain pump and also after testing the water pressure switch that determines when to start or stop the pump.
Bye.
G.
Dec 08, 2011 | Kenmore HE2 Plus Front Load Washer
Water will not drain
Need new drain pump. You will need to have Model and Serial number when you call to order a new pump or belt.
Jan 06, 2010 | KitchenAid Dishwashers
Won't spin won't drain - needs a new belt
the belt does not affect the pump to drain the machine clean pump and filter
Dec 15, 2009 | Kenmore Elite 45986 Front Load Washer
Is replacing the waterpump and thermo hard
NO. the top radiator hose is where the thermostat is,r&r the bolts set the hose and the goose neck to the side remove the gasket and the thermostat,replace the new one in the reverse order.(pay attention to the direction of the thermostat when you install it.
The water pump loosen the belts, drain the radiator using the pet **** under the radiator,or you may use the bottom radiator hose,take it off the water pump and drain into your pan.r&r the bolts from your pump and remove the pump.Clean your gasket area and installl new one in reverse order.
Aug 01, 2009 | 1985 Cadillac Eldorado
Will not drain
im assumig that youve already had the machine tipped back and bottom cover removed, as you look at the pump there should be metal clamps securing it to the drain pump motor, you can release the clamps and the pump will release from the motor giving youbetter acess to the clamps..
BE WARNED if there water in the machine its comin out when you undo the clamp!!!! and if you need to order a new pump assy theyve since changed design and you must replace the drain pump/motor alltogether, not hard, but old pump no longer available
Apr 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
LG WM1814CW Front Load Washer Logo
44 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
