Question about Dishwashers
The pots and pans button keeps blinking, and I can't turn the dishwasher on to wash. so i disconnected the dishwasher, then reconnected it, then I can hear the water drain. but the pots/pan or rinse button keeps flashing.
  • 572 Answers
Might have a faulty touch pad
Posted on Feb 08, 2010
Pots and pan cycle button keeps blinking
I don't see the make and model of your dishwasher listed, but I suspect it's a whirlpool.
I've seen this quite often on Whirlpools. 90 percent of the time, it's the user interface control panel like this one here:
Oct 18, 2014 | Dishwashers
Pots and pans light keeps blinking and not working on Whirlpool Gold Dishwasher - what do I do?
Pots and pans requires HOT water. If your heater is not working it will not run the cycle. Possibly the heating element is bad or has become disconnected. Only has two wires coming in from the bottom of the dishwasher (underneath behind the kick panel). Do not touch them unless you know power to the DW is off. Heating element is nothing but a high resistance wire in a tube so you can check it with an ohm meter. Continuity means it is good. AS LONG AS that continuity is not with the outside tube.
Not hard to replace it but up to you to decide if it is more trouble than you want to do.
Sep 15, 2012 | Whirlpool Dishwashers
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
Pots and pans and normal wash blinking
Try resetting it. Locate the switch in your breaker box, and flip it off- then on again. Hope that works!
Aug 09, 2009 | Kenmore 13743 Staimless Steel Built-in...
Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Feb 16, 2008 | Kenmore 15769 Built-in Dishwasher
Quick Rinsw button blinking
I may have fixed my similar problem- I opened up the machine to get access to the control panel as tech17 advised- then in addition to disconnecting the mylar ribbon, I disconnected all the connections to the control panel.... keep in mind to ensure not to confuse any of the connectors you disconnect. Running a cycle at this time... seems as if working.. can't tell if water is running or just the motor- -- HA! -- i confirmed no water being pumped in.... We then found a float switch (Item 30 on schematic) that got loose from its casing on the front interior right lower side... we put that switch into its proper place and now ALL IS WELL!!!! Yippee!!!
Feb 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Lights on pots and pans blink constantly
try disconnecting power for a bit. try the cord under the sink. if its hard wired (no cord) you can try the breaker.
may reset itself.
otherwise, you have a logic board issue.
consult the manual first for explanation of blinking lights etc.
then call the mfg for further info and if needed, schedule an approved repair person.
good luck
mark
Dec 21, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
253 people viewed this question
Top Dishwashers Experts
