Crappy tv Nothing happens when you turn it on? I don't have a repair manual or anything. The tv isn't that old.
  • shun09 Jul 08, 2008
    when I turn the tv on it makes a continuous clicking sound but know picture..
    Genius:
  • 1,139 Answers
Hello madlady,
It sounds like you have a power supply issue. Now that being said, I would suggest that you have a qualified TV technician look at this set and repair it. If you want to do this yourself you will need:
1) A schematic diagram (repair manual can get it at www.servicemanuals.net)
2) Multimeter (To measure voltage and resistance levels)
3) Isolation Transformer (To use with TV if you are planning on using equipment that requires AC power)
4) Oscilloscope (To measure and view waveforms for testing)
5) Pattern generator (To create a reference testing signal)
Now if you know what these pieces of equipment are you will need them, if you do not know what they are, I again suggest that you take the TV to a qualified TV technician for repairs.
I hope this helps
Thank you,
Shuttle83
Posted on Feb 23, 2008
RCA keeps turning on then righrt back off, does it for at least 4 times, don't show any picture no audio. What's the problem?
Im going to assume if you press the on button on the remote or the tv, that is just clicks at you and does nothing then turns off...if so kiss it goodbye..it's a problem with its main board and there isn't really anything you can do to fix that. Unless you are good with electronics that is...if it's new it may be under warranty, if it's old well then no luck there...
Jun 10, 2012 | RCA Televison & Video
1995 Nissan Pickup 3.0 will not start
The radio uses hardly any power to work.cranking takes much more u need a voltage reading from battery.anything under 12.6 from cold means new battery
Feb 05, 2018 | 1995 Nissan Pickup
02 AVALANCHE 606.000 RUNS EXCELLENT FOR 5 MILES THEN SPITS SPUTTERS STALLS RESTART FINE THEN RUNS SMOOTH PORRS LIKE A KITTEN
Do you have any OBD Check Lights on your dash?
Any stored codes?
Don't see the intake question,same,
worse,still has to be fixed
I would suggest you drive around with a mechanic
& have that person bring along a professional grade
scan tool or software & see what data shows up.
If that isn't done, there is a good chance you will be told
they couldn't find anything,that happens way too often
You don't get what you go to a repair shop for & they don't
seen to understand why your there.
May 07, 2012 | 2002 Chevrolet Avalanche
TV will not turn on. Red flashing light, nothing else. Tried remote, nothing. Tried manually turning tv on, nothing. Tried unplugging and plugging back in, nothing.
Hi.
This sounds like you are experiencing the same thing as thousands of other tv owners right now.
Your tv is suffering from " capacitor flu".
The capacitors that control voltage regulation, convergence, or the ones on the main board have failed.
This is not due to anything that you have done, it is because about 15 years ago, some companies chose to put profit ahead of quality.
There were about 20 electronic component manufacturers in the mid-1990's that mass manufactured capacitors, and they were done so with the wrong formula for capacitance gel. They used a formula which was later determined to be harmful to the capacitors, but instead of pulling those off of the market, they ignored the massive failures and left then out there on the market anyways.
All together, the companies made a combined 50,000,000 capacitors that were junk, and instead of lasting the 25-30 year design like they were supposed to, some of them are only lasting a few months to a few years, at best.
Now, that isn't to say that this means that your tv should be tossed in the trash, but if you take it to get it repaired at places like BestBuy, Fry's, or Staple's...you will want to get an estimate of repair costs before actually having it done.
The reason for this is because to get the proper capacitors put in your tv is a time consuming, and expensive repair.
You may find that the cost of repair is more expensive than the cost of replacing the tv, or you may find that it reasonably priced to get the repair.
That is why I recommend getting an estimate first.
This way, you will know ahead of time which way is the most economically feasible venture for you.
I hope this helps you understand what is going on with your tv, and that it gives you some insight as to how to remedy the situation.
Good luck to you, and have a good day.
May 30, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I bought my 16 year old daughter a 1996 cavalier that runs great and starts fine...when it starts. When it doesn't...you turn the key and nothing happens...so far I have replaced...the ignition, the...
wow crappy situation. sorry about that. i would say first thing to check would be the neutral safety switch on the column or tranny. try wiggling or pulling up on your shifter lever when you start it or see if it will start in neutral. if it starts then its your safety switch.
if that does not work i would say maybe you've got a bad solenoid. even though the starter is new it could still have a bad solenoid. has happened to me before.
let me know if one of those helps. i hope you get it figured out!
Jan 07, 2011 | 1997 Chevrolet Cavalier
HP DV9700-L/side ports- which one will work for second display/TV
I do not know if this is the answer you are looking for, but I know that when I connected my S-video connection to some old crappy big screen TV, I had to set the laptop's second video output to specifically output to S-video. There were 3 or 4 different settings that had to be done. I dont remember the details, all I remember is that the 1. the second video monitor had to be set to the s-video connection. 2. the analog video setting had to be set to PAL or NTSC or whatever they are, I dont know what it is off the top of my head, then there was another setting, I dont remmeber, I think it was the setting to 'clone' the screen so that it just duplicated it. In this case, you might have to set the resolution to somthing smaller that would fit on a standard definition screen.
Jul 10, 2009 | HP Pavilion dv9000z Notebook
Screen won't light up, sound won't work-ipod touch 16G 2nd generation
it's possible that the mouthwash got into the battery and zapped it.
i would change the battery and see what happens.
if nothing happens with a new battery, don;t bother chasing the problem because there isn;t just one.
Good Luck
May 30, 2009 | Apple iPod touch
No image
same thing happened a few days ago to me..been inop for few days...unplugged and tried again..now its back on.....crappy system
Oct 23, 2007 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
TV does not turn on
it will cost around 400 to fix. its the power supply. it happened to every akia like this and astar 26 lcd. just a crappy tv. i would have to say they all lasted about 1 year when this started. i sold these tv s for a while at my work.
Oct 14, 2007 | Akai LCT2660 26 in. HD-Ready LCD...
Televison & Video Logo
344 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
