Question about Amana Washing Machines
My Amana lw4302 has developed a ;eak. Is this
My Amana lw4302 has developed a leak. The water is coming from the bottom. Is this fixable?
  • 254 Answers
More than likely the leak is from your water pump,, tip unit back and look underneath seee if u can notice the leak,, this is repairable if its ur pump just need to contact a parts suppplier or company and get correct pump with model number hope this helps
Posted on Feb 08, 2010
Water leak on floor
Typically on this model the drain hole Under the evaporator cover gets clogged. Remove the cover off the rear of the refrigerator and pour hot water into the drain until it goes down quickly. To remove the cover u will have to remove all the freezer shelves and the icemaker. Remove the covers screw and u should see that at the bottom u will have a block of ice down below. The refer goes onto defrost every couple days and will leak the melted ice onto the floor
Jul 06, 2011 | Amana ABB1927DE Bottom Freezer...
Our amana bottom freezer refrigerator Model ABB2224DEQ at times leaks onto our kitchen floor. We don't have an ice maker so I am wondering where it would be coming from and what needs to be done to...
This is likely water from the auto defrost operation leaking from the evaporating pan. Sounds like the pan may have a hole in it, or the hose which drains the water into the pan is leaking, The pan is at the very bottom of the unit.
Charlie
Mar 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana Fridge: Internal water leak with Amana TJ18KW.
good morning
your freezer cabinet need to get all out also the ice machine(if you got one),and open the back wall
there is a drain hole in the bottom middle of it make sure it is clean, and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards!
Jan 04, 2010 | Refrigerators
Frigidaire GLD2445RFS0 dishwasher has developed a door leak
Make sure the lower spray arm ends (there are 3 arms) are snapped together all the way. One of ours had come apart and was spraying water out the end of the one arm. It was enough to "spurt" water past the plastic gasket at the bottom of the door. I snapped the arm back together and BINGO. Free fix.
Sep 29, 2009 | Frigidaire Dishwashers
My Amana ABB2257CS bottom freezer leaked water
your freezer cabinet need to get all out also the ice machine,and open the back wall
good luck 911servicetoday .com good luck
Jun 29, 2009 | Amana ABB1927DE Bottom Freezer...
Lws34aw
Remove the front panel, two screws on bottom. On the bottom of the motor is a white colored pump, if the water is coming from there you need to replace the pump. you can find this part on line, just google Amana washer parts.
Let me know ifyou have any more questions.
May 20, 2008 | Amana LWA40A
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Feb 23, 2008 | Amana ALW880WH Top Load Washer
Amana LWA50AW Washer Leaks!
you need to get the front off... grap a light and get down and look inside to find out whats leaking... with out looking its just guessing check all water hose connections, water pump, and main seal where transmission goes thu drum
Sep 05, 2007 | Amana LWA40A
Leaking water from the bottom, checked all connections and no leak from connections. Also making noise when running.
Take front of washer .. get light and look for leak and listen to find out where noise is comeing from
Nov 18, 2006 | Amana LWA40A
Washing Machines Logo
166 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
