Question about Ryobi Cultivator
Require new clultch mechanism for my RLH410049926 Ryobi Lawn Hornet? It appears the spring has been rubbing on the outer cluch drive for some time. So it may need replacing as well. How do you go about replacing it if parts are available?
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello s, the model number will begin with --p-- or--ry,,,i think you gave the serial number.
evwood
  • 50 Answers
SOURCE: can't remember what fuel our Ryobi Lawn Hornet uses
All 2 cycle tools must have oil mixed with the gas. Use the proper oil and mixture recommend by the manufacture.
Posted on Jan 03, 2009
  • 279 Answers
SOURCE: how do you take off the clutch off a RYOBI lawn hornet mk3
You have to hold the engine from turning, somehow. If you get it held firmly, then you have to give the clutch a rap with something to loosen it. I use a piece of hardwood and a hammer. Make sure it is being driven counterclockwise. All you have to do is get it loose, once you do, you can remove it with your hands.How to keep the engine from turning? Some suggest using a bolt threaded the same as the spark plug, turn it in past the top of the cylinder. Now turn the engine over easy until the piston touches the bolt. Now is when to rap the clutch with the wood/hammer. Good luck...Lee
Posted on Oct 08, 2009
SOURCE: I have a Ryobi Lawn Hornet MKIII Model: RLH 1100
I did finally find the owners manual and it told me everything that I needed to know. The correct mix is 25:1.
Posted on Dec 30, 2009
  • 144 Answers
SOURCE: Ryobi Lawn Hornet rlh1100a mk111. Having purchased
Take a small stiff wire, put it through the fuel line hole and filler neck of tank. Cut the end of the fuel line on approx. a 45 degree angle to make it easier to start it through. Wrap the wire tightly around the end of the fuel line about 3 or 4 times do not wrap around the wire itself, that makes it harder to start in and pull it through slowly helping it along by pushing on it, do this from outside the tank, and when it is started in it is easy to pull through. I hope this helps you out, best regards.
Posted on Dec 20, 2010
  • 150 Answers
SOURCE: needs carby ajusting for ryobi
Hi duthie20, the low speed(closest to engine block) should be 1 and a quarter the high speed 1 and a half(the other one). That should get ya going, you may have to tweek these adjustments a little eigther way. Happy New Year!
Posted on Dec 28, 2010
I have a ryobi lawn hornet mk.111 and I need the cover that goes over the carburetter is it still available?
http://shop.ebay.com/i.html?_nkw=ryobi+cover+&_cqr=true&_nkwusc=roybi+cover&_rdc=1
Apr 03, 2011 | Ryobi Garden
I have a ryobi lawn Hornet (weed trimmer) MKIII, i...
Sounds like it has a fuel blockage. Three things to check are;Inspect the fuel-filter (inside the tank) for contaminants. Inspect fuel lines for cracks. Inspect carby for oil residue (blocking the jet). Hope this helps
May 17, 2010 | Garden
Ryobi Electric Lawn Hornet Model RLT800QF. Need
I went to www.ryobipower.co.uk, I was ynable to find a lawn hornet on the website. But you may have better luck because in the states we do not have lawn hornets.
Good Day Mate
Dec 14, 2009 | Garden
Primer button Ryobi lawn hornet
Vacuum created by piston operation after closing the choke pulls fuel into carburetor port into engine. In much the same way as the primer bulb provides fuel for the port. These type engines usually take a few more pulls before they will start. And if there are any leaks in carb. system will be very hard to start.
Apr 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Can't remember what fuel our Ryobi Lawn Hornet uses
Dec 08, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi lawn hornet wont start....continually
Hi Tamcoff - If its the same model as mine (and you can't always rely on the Parts Cattledog!!):
- to remove the bell housing; twist off the spring and using a T20 torx screwdriver unscrew the retaining screw in the centre of the housing (normal RH thread)
- place a large screwdriver in the slots of the cover to jam the impeller and using a copper drift (or similar) and hammer, tap sharply the in one of the clutch recesses (one of mine hasd 'OUT' embossed in it) unscrew the clutch from the drive shaft (normal RH thread)
Cheers,
Bob
Dec 08, 2008 | Garden
Ryobi Cultivator Logo
29 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
