Question about LaCie d2 Extreme (300793U) 500 GB Hard Drive
Locked Folders I have a Lacie 500GB hard drive and can not unlock some folders.  It will not let me change permissions and I did not lock them.  Any ides??
  • 4 more comments
  • Anonymous May 25, 2008
    I have the same problem! Did you find a solution?
  • Anonymous Sep 27, 2008
    same happened to me. what the hell is going on?
  • anitaherz Nov 15, 2008
    Brand new lacie 500gb hard drive. I can't even back up my machine because this flippin thing is locked and apparently i don't have the key!
    Anyone know how to solve my life's problems? Well, just this one?
  • Anonymous Nov 16, 2008
    Same problem. The silly machine has locked me out! It's less than 2 weeks old. Not impressed.
  • sylx100 Feb 28, 2009
    the same problem, the disk is locked forever.... how can i unlock that ****?
  • Roberta Smith
    Roberta Smith May 11, 2010
    what folders are they ?
One week ago my LaCie external disk has been locked during a system reinstallation process in which the hard drive was plugged in.  The message was that I had no permission to access it. I thought I would loose for ever all the files I have been backed up for years. But finally I have got the solution for that. There is a sofware called MacPilot (I used version 3.2.6, $20, 15-day trial) that fixes it. Once instaled, click TOOLS, then "Files&Folders" at left, then "Unlock File or Folder", press "Choose", it opens FINDER and then you click LacCie Disk. When the padlock symbol at the botton of LACie disapears, you can finally change the permissions to "read&Record". That's all, and I hope it helps.
I recommend that you always unplug external hard drivers during system reinstallation to prevent that.
Posted on Mar 04, 2009
I cannot create folders on my external Lacie harddisk
My suggestion would be to copy all the data to another drive temporally. Then reformat the lacie drive using your new computer, install truecrypt, move the data back over. The issue could have to do with the filesystem of your hard drive.
Jan 25, 2015 | LaCie Computers & Internet
Wd my passport retrieve data
Step 1:
You might not have the appropriate software installed on your computer to show / read the files
IE: adobe flash , directx , win zip , codec , word ...... Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
Feb 08, 2013 | Western Digital 1TB My Passport Essential...
Iomega 1tb drive have files hidden
Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available. Hope this helps.
b>
Dec 10, 2012 | Iomega 1TB Prestige External USB 2.0 Hard...
Error message says I don't have permission to save in this location. Contact administrator to obtain permission.
Hi there, It sounds like your network administrator has locked your ability to write to certain folders. If this is a home hard drive, the only way to fix this would be to completely reinstall windows. If it's a work computer, you need to talk to your IT Department. -Alex
Aug 13, 2011 | Cavalry Storage Computers & Internet
I CANT DELETE FOLDERS IN MY HDD
Download a program called "Unlocker" and use that to see whether your folders are locked, and this will let you unlock them so you can delete them :)
http://download.cnet.com/Unlocker/3000-2248_4-10493998.html
Mar 08, 2011 | Verbatim 500GB USB Desktop 500 GB Hard...
I also can not move folders to another hard drive
you need to check the files permissions. either you will need to fix the permissions by using the Disk Utility or you will have to click on the folder in question. press on the keyboard Command + i ( information for folder) then on the bottom of the window there is the sharing & permissions section. if you want to be able to move, copy, delete and read from that folder you will need to set it here.
If the little lock in the bottom right corner is locked you must click on it to unlock it, then enter in the admin password. once you set the privileges for each person or persons, you should click on the sprocket with down arrow. And specify if this setup is for only that folder tier or apply the same setting to all inclosed files and folders inside that folder.
if you do not do that last step then you will have that same issue again.
Jul 02, 2009 | Apple MA589LLA Mac Desktop
Lacie USB 2.0 No files or folders displayed in backup folder
Did you try showing "hidden folders and files"?
In the Explorer, select the Tools menu, and pick Folder Options.
Select the View tab and in the list enable "show hidden files and folders".
You can also try showing system files (so choose not to hide them).
That should show you all files and folders on the disk.
Do make sure you are logged in as a user with admin rights.
May 13, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Deleted 4 folders for lacie silverscreen 500gb
Dead easy, simply attached the SScreen to your PC/Mac and create the four folders:
"Movies"
"Pictures"
"Firmware"
"Music"
It requires these four folders to boot the OS!
--No Quotes in folder names--
Cheers
Jun 05, 2008 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Can't access my share folders
Drive management show only safely remove usb drive.
When u use mionet software it map the share to a drive letter. If u create folder or files on that drive u dont have permission to chance those files or folders on \\mybookworld.
Solution, dont use mionet software.
Nov 12, 2007 | Western Digital 500GB My Book World...
LaCie d2 Extreme (300793U) 500 GB Hard Drive Logo
432 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
