Question about Acer Aspire 6920 Notebook PC
The ac adapter for my Acer laptop has a continual beep in it and is no longer charging the battery.
    Genius:
  • 1,584 Answers
Remove the laptop battery / plug in to mains, if beeping has stopped, faulty battery. If not then charger or mains faulty.
Posted on Feb 08, 2010
Acer Aspire 5734z-4725 battery not charging
If your laptop computer runs normally on the ac adapter, but the battery won't charge, please try the following troubleshooting steps:
1) Remove the battery from the system.
2) Look at the connectors in the bay and on the battery for signs of physical damage.
3) Check the battery charge by pressing the status button or image on the battery near the LED's. Note: The lights indicate the current amount of charge on the battery. If all the LED's come on when you press on the butto, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flashm or blinkm there could be a problem with the battery.
4) Reinsert the battery; puch until it locks into place and the latch snaps back to the locked position.
http://www.chargerbuy.com/replacement-acer-aspire-5734-ac-adapter-19v-90w-cord.html
Feb 22, 2013 | Acer Aspire 5315 Notebook
Acer aspire 5332 plugged in but not charging
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.If it doesn't work, the most likely cause is the laptop charger. Use a new one to confirm:
Replacement Acer Aspire 5332 AC Adapter 65Watt 19V 3.42A
Oct 23, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Acer Aspire one D250-1371. no longer charging battery or powering up with AC adapter. Ac adapter works tried it on other aspire. battery works on other systems. this system will not start up no matter what...
The power receptacle in the laptop (where you plug in the AC adapter cord) might be damaged. In order to diagnose this problem, please follow the diagnosis outlined in this article:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
Next, if you made sure that it is not a power receptacle problem, then you will have to disassemble your laptop, removing one component at a time & testing. First start by removing the battery, hard drive, RAM modules, CD/DVD drive, wireless card adapter, .... etc. Continue removing the parts till you only have the motherboard, testing after you remove each component. Once you get the power LED on the power adapter to glow when plugged to the laptop, you then know that the component you just removed is the faulty one that needs to be replaced. If you reach the point where all components have been removed & only the motherboard is remaining, then the mother board is the defective part that needs to be replaced.
Oct 16, 2010 | Acer Aspire One PC Notebook
Hi! When I press power button, the front LED battery blinking for 5-6 times, then no longer happen. If I remove the battery pack, no one LED blink, no one LED light, nothing happens. The output voltage of...
Your battery pack is not charging. By removing the battery pack and trying to run on AC only you have proved the AC adapter is either not working or the power is not getting through to the laptop.
The best way to sort this is to try another adapter and see if the laptop works, if it does then your adapter is broken (this is possible even though it reads 19.1 under no load.)
If the laptop still does not work with another adapter then the laptop itself will heed repair.
Oct 31, 2009 | Acer Aspire 1640Z Notebook
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Sep 08, 2009 | Acer Aspire 4520-5582 Notebook
Annoying beep
Hi
I think you problem is from the power adapter. It's not working properly.Sometime you have the electricity sometime not.So you laptop switch between AC or DC(battery),that's why you laptop beep.The problem can also be from the power connecter on your laptop.Best is to try to change the adapter and see the result first.
goodbye,takecare
May 15, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 6920 Notebook PC Logo
312 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
