Question about XFX GeForce 6200 Graphic Card
Geforce 6200 shows vertical lines over video
The lines only appear on videos that are saved on the computer. Online flash videos work fine. These lines also appear on folders and even my backgrounds. The lines are green, most of the time, in video. Drivers are up to date and my connection is fine.
    Scholar:
  • 59 Answers
My experience with these cards is that one or more of the capacitors on the board is bad and causes these issues and even worse horizontal and vertical distortions. Take a look at the capacitors on the board (if you are not familiar with what parts are the capacitors,.. they look like little cans and usually have a + or - printed on the plastic cover). as you look a each one,.. you can feel the top,.. if it is bulged up and not totally flat or if it appears to have been leaking from the top or bottom,.. the capacitor is bad and needs to be replaced. I have had success on several geforce vid cards with this issue,.. the caps are relatively inexpensive,.. but if you dont know how to solder properly,.. you can kill the board,.. either way,.. if the caps are bad the card will not get any better by itself,... and you may want to consider trying to fix it,... if you toast the card, there is not real loss,.. you wold have needed to get a new one anyway. Let me know what you find out.
Posted on Feb 08, 2010
Computer will not boot to normal and verticle lines on monitor, dell XPS410, windows vista 32 bit
Unplug the monitor video cable from the computer. Power on the monitor and see if you get the same results. If so then your monitor is defective.
Oct 11, 2012 | Dell Computers & Internet
How do i install geforce 6200
Hello! You must first shutdown your computer. Open your cpu and connect the video card on the agp slot of the motherboard. Make sure it is properly seated. Return back the cover of the casing. Connect the vga cable of your monitor to the vga connector of the video card. turn on the computer. The operating system will automatic read the new found hardware. Now try to download the driver of the video card this will give the video card its properties to change its resolution sizes and graphics output. The download site can be found here, just enter the code you see from the image and click download.
Jun 10, 2010 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
When I connect the moniter to the graphic card geforce 6200 it will not show a display at all. connection to the computer using the regular connection it shows
On both the Graphics card and the monitor, the blue connector is a 15 pin DSub VGA video and the white connector is a DVI video.
With the monitor it should default to the 15pin DSub video input.
If you want to use the DVI video input you need to configure the monitor to use the DVI video input. DVI to DVI give the best picture quality.
If you want to go from 15pin DSub to DVI you need a converter cable.
Try conviguring the monitor for a DVI video input.
Jan 30, 2010 | XFX GeForce 6200 Graphic Card
Video card geforce 6200 with 256vid on an Asus
Your computer needs a video-codec for it in order to play all the kinds of video and audio format. I will give this link to download the necessary codecs for your computer, hope this could help you. Good Luck..Thanks..
Just copy and paste this link into your internet browser.
http://www.free-codecs.com/download/K_lite_codec_pack.htm
Oct 24, 2009 | ASUS A7S333 Motherboard
I can't install a GeForce 6200 graphics card
Also, if that card has dual outputs, such as 2 DVI connectors, try connecting your monitor to the other one.
Jul 19, 2009 | ASUS GeForce 6200 TC, TD64 Video Card
EVGA e-GeForce 6200
http://www.evga.com/support/drivers/default.asp?switch=2
Try downloading and installing this one
May 27, 2009 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
E-GeForece 6200 displays partial image when plays avi video
hi im wesley. um a problem might be that the players you are using dont have the right plug ins or dont support the file try using vlc player it works with almost everything
Jul 07, 2008 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Blank screen
I just installed a geforce 6200 with heatsink, no fan, in my computer. Fry's is having a sale and for $20 after rebate, how could I go wrong? Upon first installation, the computer failed to boot.
THE FIX
Discovered modern computers will not even atempt to boot if the power supply is below the minimum requirement for the video card's recommended wattage. More proof that over-powered supplies are not an absolute necessity. I upgraded to 250w from the onboard 180w and it fired up. The rest was disabling the integrated video which i found out was compatible with geforce 5200 level of operations.
My system:
Dell Opti-plex GX260, cut to bare minimum since it was from a commercial business with 1G RAM after upgrade.
May 15, 2008 | XFX GeForce 6200 Graphic Card
XFX GeForce 6200 Graphic Card Logo
260 people viewed this question
Top XFX Computers & Internet Experts
David
David
KG John Justin
KG John Justin
marley mcelhinney
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
