Paper is loaded; printer says "out of paper." Went through recommended steps such as unplug and clean rubber paper-feed wheels. No luck.
  • 2 more comments
  • lipmanandrew Feb 08, 2010
    It's an HP Deskjet D2530. These steps don't seem to help; the rollers seem engaged but not moving. Any further ideas?
    Andrew
    HP printer not working, though paper is loaded, says "paper not loaded." Have tried all measures on HP assistance website.
    Rear door is shut
    how might I check it at my house? Thanks, Andrew
  • 466 Answers
You might have a dislodged (or worse, broken) paper-out sensor. Usually you'll see a tiny plastic leg at the bottom of the paper tray slot, or over one of the paper-feed rolls.
If you have a parallel printer (unlikely, but for completeness), verify the cable. There is a pin whose purpose is to carry the paper-out signal, and you might have an electrical malfunction there. Quite possible with old and worn-out parallel cables.
Finally, "out of paper" might be a misunderstanding: the printer might be trying to signify that it's out of the "appropriate" paper. For example this would happen if you loaded A4 paper, but tried to print a large-sheet calendar or an envelope-size document. Try clearing the print queue and printing a test page from the printer control panel, if the option is available, or try printing a "known good" document.
Hope this helps, have a nice day
Posted on Feb 08, 2010
  • 2,567 Answers
Check the rear door of the printer. If you removed the rear door to clear a paper jam, replace it. Gently push the door forward until it snaps into place.
  • Mohamed Omran Feb 08, 2010
    All inkjet printers from HP has some sort of an optical paper feed sensor. This sensor detects whether there is paper in the paper feed tray or not & reports "out of paper" if it could not detect paper in the tray.
    Check this sensor. It might be either faulty (in which case it will need to be replaced) or need to be cleaned.
    President:
  • 3,278 Answers
Hello, Andrew.
Some issues which could cause "Out of Paper" messages:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the tray face down. For photo paper, always load the rougher side of the paper facing up.
  • The paper is too slick for the product.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are dusty.
I know that you cleaned the paper-feed rollers, but if none of the other above applies, please provide your brand and model of printer.
Hope this helps.
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at http://www.okidata.com/ .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
When I send something to print the right hand side of the paper comes out all crumpled up, as if there is something stuck that it can not pass. I have looked in the printer but can't see anything. When...
Issue
While printing, the printer paper is torn, ripped, wrinkled, or damaged.Solution Follow these steps in the order presented to resolve the issue.Step one: Remove all paper from the input and output trays Remove all paper from the input and output trays on the product.Step Two: Check the paper path for obstructions Press the Power ( ) button to turn off the product. Verify the input tray is empty, and then check for paper jams, bits of paper, and other obstructions, gently removing any obstructions.Lift the top door or the front cover, depending on the product, to access the print carriage, and then check for any obstructions in the paper path.Gently remove any paper or other obstructions from the paper path you might find, and then close the print carriage access door.Open the rear access door.Gently remove any paper or other obstructions from the paper path.Check the spring-loaded rear access door rollers to verify that they are clean and can be rolled.check the paper rollers inside the rear access and verify that the rollers are clean and roll upwards.Check the star wheel assembly inside the printer on the output side of the carriage. Verify that it is in good condition and clear of paper bits or other obstructions. NOTE:The star wheel assembly is located inside the printer on the output side of the carriage. The star wheel assembly is a set of small, star-shaped wheels on top and rubber rollers on the bottom. The assembly grips the printed side of the paper, and moves the paper to the output tray after printing.Replace the rear access door and verify that the rollers on the door and the rollers inside the rear access of the product are "matched up" with each other.Press the power button to turn on the product.Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include: Plain paper, 20 to 24 lb (75 to 90 gsm) Legal size paper, 20 to 24 lb (75 to 90 gsm) Card stock, up to a maximum of 110 lb (200 gsm) Envelopes, 20 to 24 lb (75 to 90 gsm) Photo paper, 145 lb (236 gsm) NOTE:Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.Step Four: Make sure that the paper is loaded correctly Gather a stack of plain, white paper and load it in the product's input tray.Use only one type of paper in the stack.Use 10 to 25 sheets of paper in the stack.Fan the stack of paper to make sure that the sheets do not stick together. Tap the stack of paper against a hard, flat surface, such as a table top, to make the edges even.Insert the stack of paper into the input tray.make sure that the stack of paper is flat in the input tray. Verify the right side of the stack of paper touches the right side of the input tray and that the stack is pushed completely into the tray.Position the paper guides firmly against the sides of the paper stack without bending the paper.Step Five: Test the All-in-One Follow these steps to print a self-test page. If the page prints successfully, the product is functioning correctly.Press the Setup button on the printer.Depending on what product you have, perform one of the following:Press the arrow key to select Print Report and then press OK.Press the arrow key to select Self Test eport and press OK.A test page prints.If the test page prints without damaging the paper, you do not need to take any other action.If the test page is damaged during printing, proceed to the next step.NOTE:For printers which do not have a Setup button, check the product documentation to find out how to print a self test page.Step Six: Contact HP If you have completed all the steps listed above and are still experiencing a problem, the rear access door or the star wheel assembly is likely damaged. To replace the rear access door, contact HP. If the star wheel assembly is damaged, replace the product.Cause There are several possible causes: Bits of paper might be obstructing the paper path and need to be cleared.Unsupported paper types and sizes might catch and tear in the printer mechanism while printing.Paper pushed too far into the input tray when it is loaded, might feed into the printer incorrectly, causing the paper to tear.Paper stacks loaded into the input tray with too many or too few sheets of paper, might feed into the printer incorrectly, causing the paper to tear.Paper stacks that are not properly stacked when loaded into the input tray, might feed into the printer incorrectly, causing the paper to tear.The rollers on the rear access door and inside the product's rear access might not be clean, in good condition or freely rolling.the star wheel assembly might be obstructed or have damaged or missing parts, causing the paper to tear.The rear access door might be damaged.The wheels on the star wheel assembly might be damaged.
Oct 12, 2011 | HP Officejet J5780 All-In-One InkJet...
Paper is loading crooked and causing a jam
Sounds like there is something that has fallen into the paper feed path. Shutdown printer, unplug power from back of printer, and remove paper. With a flashlight, inspect the area around the paper feed roller for any debris (one time I found a penny lodged on the left side of the roller) that might have fell inside path and for damage to rubber wheels. Ink can build up on rubber wheels causing the paper to misalign. This can be cleaned off with q-tips and 91% Isopropal Alcohol or Dilute. If debris is found and cleaned then reload paper into feed path, make sure paper guide tab is in position against paper source. Plug printer power back in, turn on printer and push the paper feed button. If that doesn't fix problem the only other solution is the replace the paper feed roller or buy another printer. Let me know if this fixes the problem or if you find another issue. Have a Nice Day!
Jun 06, 2010 | HP Photosmart C6380 All-In-One InkJet...
Who can fix my printer from paper jamming? It is a Dell Laser Printer 1700 and keeps jamin the paper. Who do I call? Have tried almost everything.We live in a remote Mountain area Colorado.
If you mean that the print cycle starts, but the "Paper Jam" lights up at the point where the paper starts to enter the drum, here's what I found worked.
The rollers that feed the paper come down onto the clean sheets on a plastic, spring-loaded arm Those rollers sometimes get too slick after a lot of use and they won't push the paper up and into the drum -- they slip like worn tires.
Solution: slip the rubber "tires"off the plastic roller "wheels" and reverse them, inside-out. Put them back on the wheels and the new rubber surface will probably push the paper just fine.
To do this you have to turn the machine upside down and remove the paper tray. I would unplug the unit and remove the drum as well before trying this.
Good luck.
Apr 16, 2009 | Dell 1700n Laser Printer
Magicolor 2400w won't feed paper
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Jan 26, 2009 | Minolta magicolor 2400W Laser Printer
Feeding problem
give one paper and check if it accepts correctly
Oct 05, 2008 | Epson Stylus 1400 InkJet Photo Printer
Paper wont load
You can try cleaning the rubber paper feed rollers, located where the paper feed into the printer. Use a rag moist with rubbing alcohol and rub all rollers thoroughly and this should help. Good luck John
Sep 12, 2007 | Canon Pixma MP450 All-In-One InkJet...
Paper won't feed
The paper is pulled in with rubber traction wheels on a rotating rod where the bottom of the paper sits in the loading area. If these rubber wheels get slick or hard, they won't pull. Buffing the rubber wheels lightly with fine sandpaper will restore the wheels to the rubbery texture they need to pull the paper. But be SURE to completely clean any abrasive dust out of the machine before use.
Aug 02, 2007 | Brother MFC 210C All-In-One InkJet Printer
Paper feed not working
remove the paper from the machine and look where it feeds in. There should be some rubber rollers, try cleaning them with a rag and some rubbing alcohol. If this doesn't work let me know. Also fan the paper before loading it. John
Jul 07, 2007 | Cannon i70 Printer
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
