Question about Saeco VIA Venezia
Left power and steamer on overnight and now machine doesn't work
Hi FixYa Gurus--
Big mistake. I left the power button and the steamer button on my Saeco Via Venezia coffee machine on overnight and now the machine does not appear to work at all. The steam release valve was closed and there is still water in the tank, but the machine does not make any noise (i.e., it's not heating water in the boiler) and there is no green light. I've turned the power off at the wall (fyi, I'm in Australia and we have switches on each electrical outlet to turn the power off and on) hoping that the machine would reset itself, but no luck. Any suggestions? Thanks everso,
Paege :)
They have a heat fuse attached to the side of the pump so when you do what you did that melts and does not damage the coffee maker
They charge $100 to replace which is a bit tough, you could bypass easily but could damage to machine it not careful
as we have two and one has just stopped pumping, not picking up water so maybe worn valves and I just have it all to bits and saw the heat fuse on the side of the pump,
Posted on Mar 13, 2008
Steamer Button doesn't work
hi ROC,
the steamer works? can you do foam with milk?
perhaps its the thermostat to regule the heat.
sorry, my english level is low, im french.
Apr 15, 2014 | Gaggia GRAN Espresso Machine Cappuccino...
We unplugged our Bunn and left it unplugged overnight to do some painting. When we plugged it back in the light doesn't come on the warmer and the water does not heat.
The unit is not getting power. If the receptacle is protected by a GFI, then press the Reset button. Otherwise, check that the circuit breaker (or fuse) to that receptacle isn't tripped.
May 06, 2011 | Bunn GR10 Coffee Maker
Laptop may have been left on overnight. been on
Take out the battery and try running it on the power adaptor alone. If this works, you have a dead battery. If not there's something more serious wrong in the machine
Apr 13, 2010 | Computers & Internet
Sony Vaio PCG-9336: Dead machine - Hybernation?
Plug the thing in and recharge the battery for about 6 hours then push the power button to turn the thing on.
Oct 30, 2009 | Computers & Internet
My coffee machine says "ventilate"
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Jan 05, 2009 | Saeco Royal Digital Plus Coffee...
STEAMER NOT WORKING - Hi my francis coffee machine is having problems with steaming.  Everything else works apart from getting steam/froth.  I have descaled it lots but still not working.  What can I...
Since your machine is only 2 months old, you can make use of the warranty.
FrancisFrancis! machines come with a one-year warranty from date of purchase.
They will assume the cost of repairing or replacing any part of this machine that fails during the warranty period or is found to have a manufacturing defect.
Please contact FrancisFrancis! for answers to questions and customer or service needs at: 877-854-4141.
Hope my info fixes your problem,
Thanx for using fixya,
Good Luck.
Sep 30, 2008 | FrancisFrancis! X5 Espresso Machine
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
STEAMER NOT WORKING - Hi my francis coffee machine is having problems with steaming.  Everything else works apart from getting steam/froth.  I have descaled it lots but still not working.  What can I do?
Hi again, I looked at some other posts on this site and tried soaking the steam wand in a cup of boiling water with a cap of vinegar in it.   I left it about 20 minutes and it worked very well.   My problem was just that the wand was blocked with dried milk on the inside.  I'll make sure to run water through after steaming milk in future .....
Aug 06, 2008 | FrancisFrancis! X1 - Stainless Steel...
Saeco VIA Venezia Logo
311 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
