Question about Amana ALE443RAW Gas Dryer
Sock was sucked into lint filter. Was able to remove most of it by reaching through back air duct. A small part of the sock is still stuck, wrapped arounf something. How can I remove from lint filter? I have removed bottom door it looks like the entire front panel needs to be removed.
  • Amana Master
  • 3,361 Answers
Yes,remove the front panel to clear the jam. Carefully inspect the blower wheel after it is cleared. The blower wheel must not be loose on the motor shaft.
Posted on Feb 08, 2010
Testimonial: "Thanks, you confirmed my assumption."
How do I remove a sock that fell through the lint trap?
How To Fix Dryer Lint Trap Problems (Removing Items That ...
? 5:32
https://www.youtube.com/watch?v=Fcw1aPqGiSI
Feb 4, 2015 - Uploaded by UKaToNeN
Have you ever had something fall down into the lint trap on your dryer? It`s happened to more folks than you ...
how do I get sock out of lint filter shoot of electric dryer ...
www.shopyourway.com > Manage My Life > Questions
I'm sorry to hear that a sock fell into your lint screen chute and I would like to assist you. Be sure to unplug the dryer prior to servicing it! Do not run the dryer until you are able to remove the sock! There are two ways to do this.
Nov 29, 2015 | Electrolux Dryers
A sock was accidentally sucked into the lint filter area, and now the dryer is making a loud noise.
Try to disconnect the filter and throw the sock away it is probably more holes than sock by now.
Goodluck
kolbrun
Oct 18, 2011 | Amana NED7200TW Electric Dryer
Brand new dryer. **** went down lint filter area
You may have to remove the front panel to enter the air passages and blower fan. Try feeding a vacuum cleaner hose (remove the metal hose end) into the area behind the filter to see if can pick up whatever dropped into it. Hope this helps!
Apr 12, 2010 | LG DLE2050 Dryer
Heats up sometimes but not all the time
It could be an air flow problem, which is easy to correct. Remove your round dryer duct and check for any lint obstruction, sock, etc that may be blocking the air flow. Then check where the duct connects to the dryer and remove any lint that you see. Then, go outside where the dryer exhaust vent is and check and clean any lint that may be obstructing the vent. Be sure if the outside exhaust vent has a flap that its working properly and moving freely.
If your air is not moving freely out of your dryer, the overheat sensor will shut down the machine. Clogged ducts are the most overlooked problem with dryers and cause most of the problems. Good luck!
Oct 10, 2009 | GE Dryers
A sock fell in the vent of my whirlpool dryer
If you mean the lint trap, try this: Unplug the dryer. With a dryer brush (~$10.00 @ Lowe's/similar), bend to approximate the curvature of your cavity and try to retrieve. If this doesn't work, slide/scoot the dryer out and remove the venting duct. Carry outside and dump. If no sock there, look into the dryer exhaust (where the duct connects). Use the brush again to retrieve said sock (and generally clean as you go, as it never hurts). Also look at your vent where your dryer exhaust passes through the wall, clean as you go..... This should get you back up and running.
Regards, --W/D--
Jul 17, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Drum Stuck
First, take off the top of your dryer. Use a screwdriver to pry the top up in front, then it's usually held on by some swing metal hinges on the back that simply come off by themselves as you rotate the top of the unit up and back. Then, you should be able to see all the screws and metal brackets holding the front of the unit on, remove all of these and you should be able to pull the front off. It may be necessary to unplug some of the wires when doing this. Then you should have full access to the front lint filter section on the door, and the fan section underneath the drum. The fan and the drum spin together, so if the sock is stuck in the fan that will also stop the drum. Good luck
Nov 30, 2008 | LG DLE2512W Electric Dryer
Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Mar 25, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
I took lint filter out to clean it and forgot to put it back in, I started gas dryer and it stopped, I believe there is a sock stuck in there somewhere. Does the front come off and what do I need to take...
Hello Kims987K,
You may want to check circuit breakers in your Breaker Panel to see if the one for your Dryer is tripped, and reset it if it is. Even though you have a Gas Dryer the Drum still operates on electricity, so without it the Dryer wouldn't function at all.
I don't think that the sock is stopping your Dryer, as the lint filter just filters lint from your Dryer's exhaust. So, even with the lint filter out a sock couldn't fit through the small holes in the drum that ventilate it (that's how the lint gets to the filter). I guess there could be a switch that detects whether the filter is in the machine and cut it off though, so you may try to re seat the lint filter (replace the lint screen/filter making sure it's in all the way), and try to start it again. If you look inside the Drum and see any way that a sock or anything else could get out other than through the door opening? That would be a problem.
If the filter was missing for several loads of laundry? Then you could have a restriction in the exhaust causing a thermal overload circuit to cut it off too (prevents the Dryer from catching fire). Does the light come on in the Dryer when you open the door?
From the information you posted, all I got is that it's a Gas Dryer that won't run and you appear to be missing a sock, so more detailed information will probably help in finding your solution.
I'll check back, and Good Luck finding that sock.
Mar 05, 2008 | Dryers
Amana ALE443RAW Gas Dryer Logo
410 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
