Question about Refrigerators
How do I gain access to the freezer drain line for a Roper Model# FRT17G4BW9? The drain line exits the back of the refrigerator just above and to the side of the drain pan on top of the condensor.
  • 4,793 Answers
With great difficulty.much simpler is to poke thin wire with small piece of cloth dipped in clorine bleach up the exit
Posted on Feb 09, 2010
Ice on the back of freezer wall.
Hi Marcus,
It appears from your issue stated you have a defrost problem. You will need to gain access into the freezer compartment, remove all the ice, and most likely replace the thermostat located on the inlet tubbing within the freezer section. Of course if all the ice is in the evaporator only. If only on the bottom of the freezer, you would need to only clear the ice away, and use hot water to clear the drain system.
Good luck, feel free to ask more questions, glad to assist if needed.
Oct 15, 2013 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a Roper Frost Free top freezer model Model@RT16DKXXW06 Serial#EB2423742 Type#16ATR92 Mfg 06/92 the pats 6-8 weeks it has been leaking water on the floor I assume from the defrost cycle. What can I...
yes the drain is in the rear of the freezer ..you will need to remove the covers on the bottom and the back to see the drain..remove all the ice buildup on the bottom ..then use hot water to thaw drain...the reason for the line freezing up is freezer is set to cold freezing leftover water from defrost..let me know good luck/joe/
Aug 27, 2010 | Roper Refrigerators
Sometimes water is flooding to the bottom of the refrigerator.. I know the drain hose is stopped up. I found one end at the bottom in the back. However I can't locate the drain in the freezer to blow out...
The drain is behind the panel inside the back of the freezer. It is under the coil. You may need to run hot water through the drain line to defrost it before you can blow it out. Good luck
Apr 30, 2010 | Roper RT12VKX Top Freezer Refrigerator
Water leaks under refrigerator and food frezing at bottom level
Would like you to click here=> WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
Then scroll down to the bottom area of the page where it describes a model just like yours, Let me know if this is helpful or ask questions and I will assist you.
If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com Thanks, Sea Breeze
Feb 18, 2010 | Refrigerators
Refer defrost does not drain into pan but into refer
YOU NEED TO CLEAN DRAIN LINE REMOVE PANEL S IN FREZZER AND FIND THR DRAIN HOLR USE A TURKEY BASTER TO FORCE WATER DOWN HOLE YOU NO WHEN IT IS CLEAR WHEN WATER STATS TO GO DOWN FINISH WITH A CUP OF VERY HOT WATER TO FLUS ANY ICE THAT MAY BE LEFT
Jan 31, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Another refrigerator with same problem
Pull the refrigerator away from the wall.
Inspect the drain line and drain pan.
The drain line comes down the back of the box and into the drain pan on top of the compressor.
The drain line may have a crack in it or may be missing the pan.
The drain pan may have a hole in it.
Jan 26, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
My Roper refrigerator collects water in both vegetable bins. Help!
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Jan 21, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper fridge problem
Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 08, 2008 | Roper Refrigerators
Clogged defrost drain tube
You can access the drain tube from the back of the refrigerator. There is normally a trap located after the drain line exits the freezer compartment. Clean out the trap and it may solve your problem.
Apr 29, 2008 | Refrigerators
Water in refrigerator
clean the drain hose using air presure and liqued susa
Sep 24, 2007 | Roper RT14DKX Top Freezer Refrigerator
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
