Puk code for a nokia 6300
Hi everyone
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1)
If you still have your packet that your Sim Card came in, you should
find your PUK number in there, if you don't have the packet, please
read bellow.
2) You must get a phone that is on the same network
as your phone and call the networks Customer Care and ask them for your
PUK number, they will ask you for your phone number, then they will
tell you your PUK number. Once you have done this, you will be able to
reset your Pin number so you will be able to go into your phone again.
Please also remember to give this solution a FixYa! rating if it helps you.
Kind regards
Dustin Ellse
I blocked my fone and used 22222222 as puk code only now its askin 4 a new pin code but when i verify it it says error can anyone help me please x
Complete information :
The SIM card protects
your subscription and not the phone from unauthorised users. If you
change SIM cards you can still use your phone with a new SIM card. Most
SIM cards are blocked at the time of purchase. If your SIM card lock is
on you have to enter your PIN (Personal Identity Card) every time you turn on the phone.
If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK
Note:
card (Personal Unblocking Key). Your PIN and PUK
is supplied by your service provider. You can edit your PIN and select
a new four to eight digit number
To unblock your SIM card:
To edit your PIN:
To turn the SIM card On /Off
Hy,
When i tired to change the Pin it asked to enter a Puk then i entred the Security code.. but thats not working... please Required PUK of 6300
Prince
The PUK number is available from your network service provider free of charge.
Puk code nokia 6300
My sim ard is blocked as well, and I entered the PUK code which was 22222222 but then it tells me to enter a new PIN code, and I enter it twice CORRECTLY but it still comes up with code error! What do I do?! Without having to call up... Please help, others have asked but no one seems to be responding... Thanks :)
GO TO YOUR SELECTED NETWORK PROVIDER TELL THEM BOUT YOUR PROBLEM AND THEY WILL GIVE U THE UNLOCK CODE OF UR SIM USING THEYRE ACCESS
Your puk code is determined by your sim cards ... just try to still look back the papers of your sim card and then there you will find puk numbers that you will be able to type when there is a message that puk number.. it states there if 1 or 2..
thanks
If you cannot find the puk code of your simcard , buy another new simcard .....
Get a new simcard
I need my puk code of nokia 6300 an sim card is TATA Docomo
Just call your service provider using the same service phone.it has really worked for me alots...thankx.
If you put in any eight diget number i takes you into the next step witch is putting in your new code but no mater if u put it in right or wrong it still is error
Ahhh **** nokui people
Service providers have the answers, and for free of charge, but make sure the phone your calling from is with the same service as the one you need a PUK for, :)
It does not work on mine...
The code puk is 22222222
Call you service provider and they will give you the puk code
Try this 777655565 and it will work, it worked on my nokia L0L
Help me
i put in 45678 and it worked put when i put in the new pin code and verified it, it said code error!!!!!!!!!!!!!!!!!!!!!!
When i start my nokia 6300 china phone it's on and then off immediately. if i start without sim it's always on. how can i use the phone without any problem?
I can not slove this proplem
I need puk code for my phone pls...its really important!tnx
I entered 22222222 and it said pin # and i did it butno it was stil wrong HELP !!!
Best way is to go to one of the east-indian cell phone technician and he will do it for less than $20.00, I bet ya
SOURCE: I need to format Nokia 6300 Cell Phone
Hey dear,
I am using Nokia 6300 since last 7-8 months, i would like to help you for that,
Option 1 :
Your settings are restored but you might not know abt it as messages
and phone book stays intact, rest of the settings after you purchased,
which you have customised are restored.
Option 2:
You can update the complete software of your phone this may resolve
your problem of restore factory settings, I remove memory card while
taking back up and updating the software as it takes time to back up
the data and you may loss the data.
Option 3:
You should visit the Nokia care center if you're unaware about both the option.
Option 4:
To format your memory card go to gallary just keep selected your memory card and go to option you will find format memory card.
I hope you might get solve your problem, and my answers are helpful to you.
One more option :-
hard reset your phone hard reset using this code *#7370# (ALL DATA WILL BE DELETED)
Thanks!!!!!!!!!
SOURCE: puk code for a nokia6300
call the customer care which sim card u r using, they will ask u a number which is available on sim card u have to tell them that number and ask for puk code and reseting code.
gud luck.
SOURCE: puk code for nokia 6300
Basically sir, PUK code is not asked by Cellphones, rather, by SIM cards, your SIM required 4 digit PIN code and someone entered it 3 times incorrectly and now its asking for PUK code and your service provider (means your network company like Vodafone, ROGERS etc) will give you 8 digit code (mostly free) and if you'll enter PUK 3 times incorrectly then you'll lose your SIM card and data in it.
what is the price of nokia 6300?because i will bought tomarrow.
MY PHONE TELLS MY TO PUT A PUK CODE AND I LOST ALL MY PAPERS FOR MY SIM CARD
hi..i my phone nokia 6300 is asking for puk code ..please any can help me
my phone is asking puk code and after that to enter new pin. code. what code should i type. and it last attempt
hi my phone us asking puk code and asking to enter a new pin code at the last attempt. what code should i type
it says on my nokia 6300 sim card rejected plzzzzzz help
I got my phone in China and I'm in New Zealand now, can I still get my PUK here or do I have to call up China?
i have a nokia 6300 and i no the PUK code which is 22222222 but what is the pin that you put at the end
my phone i blocked and i am trying to unlock it
i'm tryin but i can't
plzzzzzz help
i forget my pin code
I forgot my pin number, now the phone is locked.
i just got the new nokia n95 and i wet to put a password on the sim card and it has put a lock on my sim and now i need a PUK code ... PLEASE HELP ... I DONT KNOW WHRE I CAN FINE a puk code
i went in the security code thing thinking i can enter a pin and when i tried it said pin blocked enter puk code so i turn the phone off and turn back on and it only pops up as pin blocked enter puk code and i really need to unblock cause i am in switzerland and my mom needs to talk to my dad through my phone
autometically sms send.
sms autometically send
i need my puk code on my nokia 6300
how to fix it
I forget my code then it need puk code so how can I get it ?
it lockeed it self it says pin blocked enter puk code
i carnt unlok my phone
how do you get rid of the puk code? it keep poping up on my phone
I accidently locked my SIM card on my nokia what is the PUK code?
i entered the pin code i wanted it to be. then it said. PIN LOKED. ENTER PUK CODE
my phone shows enter PUK code and it wont let do anything and i dont no the code
a have enter a wrong pin number and its block and its appers like this on the screen
PIN blocked. Enter
PUK code:
PUK COD
I entered the wrong pin an its asking me for a puk code
puk code
my number is: 870 6237931
my phone refuses the puk code o cpild not open it
my phone refuses the puk code, could not open
i was playing with my phone and the codes when it disabled. i think i know the PUK code, but after i put in the password, which has changed to i dont know what, it said "code error" and asked me to input the PUK code again. now i cant use my phone for anything but emergency calls (911, etc.). PLEASE HELP
i lost security cod then what cod is that i can get a cod
nokia 6300 micro phone problam
