Question about Maytag Dryers
Start button not working. Is there a alternate
Start button not working. Is there a alternate keystroke to bypass it?
  • mstajduhar Feb 08, 2010
    Just to be clear. This is a membrane keypad, not a "switch". I ran the Membrane Keypad Utility and it determined the start button is faulty. I can also run sub-systems like the blower, motor and heater. Does this cause you to think of some other possibilities?
    Maytag Neptune Clothes Dryer MCE8000AYW. Ran test to confirm START button on membrane keypad is faulty. Is there an alternative key stroke sequence to start the dryer? Thanks.
  • Maytag Master
  • 43,501 Answers
The only way to bypass it is a bit dangerous...
You can take the the panel apart and monetarily jumper the wires on the start button... this will get it going for you..
Just be very careful the voltages there could kill you!!
Heatman101
Posted on Feb 08, 2010
  • 311 Answers
No unfortunately there is no alternate keystroke to bypass the start switch. It is actually not very common for the start switch to go bad. You could remove the back panel and if the start switch only has two wires going to it you could actually wire them together. If the dryer starts and runs then you know its a bad start switch.
The most common cause of a dead maytag dryer would be a blown thermal fuse. It is located on your blower housing.
I would also check to make sure your breaker is not tripped and you are getting 240v to the dryer.
Hope this helps _MJ_
  • Matt Ace Appliance Feb 09, 2010
    Ok im sorry I was under the impression that it was an actual switch. The fact that the motor and heater can be ran in test mode would indicate that your relay on the control board must be closing to send the voltage down to the components. So I would assume it is a faulty touchpad or control board. I ran the model number through our database at work to see if the repair manual mentioned any alternate keypad dance to run the dryer and It did not mention it at all. Unfortunately its probably the same tech sheet that you had to put in into Manual-op mode. Sorry but unfortunately I think your going to have to replace the console assy which comes with a membrane pad. Its part# is 31001658 and its a VERY expensive part. The MSRP is $344.54 so I would definitely make sure that its bad before you replace it. If It has a ribbon you could run continuity tests on each side of the ribbon cable to make sure there is no break.
    One other random thing you can try is unplugging the unit and taking the power cord and grounding the two terminals to the chassis of the unit this will bleed any static out of the boards capacitors. Plug it back in a give it a try. This has worked for me on units that would not go into diagnostic mode.
    Good Luck _MJ_
We unplugged the Mac before we did the shut down, now it will not start up. What can I do?
leave it plugged in for a while. Try holding down the power button until it powers off. When you restart it, hold down the S key to see if it will boot in safe mode.
For list of other keystrokes and tricks for macs, go to apple support or google keystrokes for mac OS
May 19, 2014 | Apple iMac G5 Desktop
Dv7-1023cl problems with quick touch buttons
You don't need to activate the drivers. if you reinstalled them then they are there and should be working.
There should be alternate methods to using the quick touch keys, such as using the conventional methods.
For example to change your volume, just click on the megaphone at the bottom right near the time and adjust the volume. Or click Start/Control Panel and look for Audio or Sound and adjust the volume. Also click Start/Programs/Accessories/Entertainment and see if there is a volume control there. Also normally you can adjust the volume by keystrokes. Normally you would Press and Hold the FN function key near the bottom left portion of the keyboard and press the volume keys (there should be 3 volume keys, volume up, volume down and volume mute).
As for the Wireless there is a switch on the side or in the front of the laptop that controls the wireless. Also there are keystrokes that can toggle it off or on once the wireless switch is on. Normally you would Press and Hold the FN function key then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the icon of a wireless signal )))) or it will have the icon of a tower with a wireless signal )))).
Apr 23, 2012 | HP Pavilion DV7-1023CL Notebook
Page freezes; cursor registers as a 2-headed arrow (horizontal or vertical); EXTREME delays executing EVERY commands; keystrokes not recognized, only 3-4 keystrokes register, making typed messages uni
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware make sure you have the correct mouse selected also under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall in xp
hope this helps
Nov 30, 2011 | Computers & Internet
Having trouble programing my extreme 3d pro joystick and FSX deluxe. I am using Vista. I can't get the elevator trim up/down to work. Doesn't even seam to work when i press 7 or 1 on the...
I would first of recommend doing a calibration of your joystick. To do that, make sure your joystick is connected to your computer and go to your start menu>>devices and printers. Once your window pops up, find your joystick and right click on the icon, and go to settings. You can find the calibration wizard there. Once that is done, open up your Flight Simulator X, and go to the settings tab. Along the right hand side, click on controls. From there you can configure your joystick buttons to whichever action you like. Please keep in mind as well when your are adjusting the elevator trim, rudder trim, that the adjustments made from one keystroke, or button push, are very very small adjustments. You can change that by moving the slider on the Repeat column, thereby making one keystroke or button push equal to multiple taps!
Sep 13, 2011 | Microsoft Flight Simulator X
Headlight went out - both beams. where is the fuse for this to check first?
Hi and welcome to the site,
Consider an alternate suspect. There is a hidden bypass switch for the headlight activated by the start button switch. Check, clean with WD40 the inside of the start button switch.
Good luck and thank you for asking.
Aug 19, 2010 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Logitech LX8 Mouse back button quit working on AOL
This has been a long time problem with Logitech and Aol. If your mouse software allows you to edit your mouse buttons, change the back button to "keystroke" and enter the back arrow key on your keyboard as the command. Alt left arrow also works. While you don't appear to have a forward button, Aol users who do, would change it to "keystroke"...Alt right arrow.
Mar 09, 2009 | Computers & Internet
Gulbeyaz_hellokitty@hotmail.com
This is directly from Logitech:http://logitech-en-emea.custhelp.com/
"Logitech MouseWare Software:
1. Right click on the Logitech white mouse icon in the System Tray and select "Mouse Properties".
2. Click on the "Buttons" tab and your pointing device should be shown. If you have more that one mouse connected, select the mouse you wish to program by clicking on the "Devices" tab, and select the mouse you wish to program from the drop down menu, then go back to the "Buttons" tab.
3. Scroll down the list of buttons and select the button you wish to program, and click on the function to highlight it.
4. Now click on the "Modify" button. A "Modify Button Function" box will appear with a drop down menu. Select the button assignment you wish to use and click the "OK" button. Now click the "Apply" button to save your changes.
Using the "Keystroke" button assignment.
If the button assignment or keyboard command you want is not listed under the button assignments, you may want to use the "Keystroke" button assignment. Using the MouseWare steps above select Keystroke under Step 3. The "Keystroke Assignment" box appears. Click your mouse cursor into the box that states "Unassigned". Now press the key or combination of keys you wish to use and click the "OK" button. The function should now be displayed in the current list of button assignments. Click the "Apply" button then the "OK" button."
Hopefully this will help. Please let me know if it doesn't.
Nov 25, 2008 | Logitech Cordless Click! Mouse
Monitor
The Ctrl-Alt-Direction key sequence is supposed to be used for changing your workspace. On my computer at work it changes the screen orientation.
Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
(If that doesn’t work, try Ctrl-Shift-R)
This is a feature in Windows XP Tablet PC Edition. Which makes sense. But it looks like ATI Intel copied the keystroke for the same “feature” in their video card drivers. I can’t think of a good reason why I would need an always-on keystroke for this on a desktop PC.
When creating a keystroke-mapped feature that only 1% of your customers will want to use and the other 99%[1] are going to be confused by, put in a menu option to disable it and have it disabled by default.
To fix the issue press Ctrl-Alt-Up. To permanently fix the problem go to:
Start >> Control Panel >> Display >> Settings >> Advanced
Where it is after that it dependent upon your video card.
Mar 31, 2008 | Gateway FPD1975W 19" LCD Monitor
Forward/back buttons....
Which version of Firefox are you using? You can find this by clicking on Help, then selecting About.
Aug 21, 2007 | Logitech MX 600 097855036162
Changing Sensitivity
1. Open the SetPointTM software and assign a keystroke to the button you want to use. For further details about this procedure, launch the Help Center within SetPoint and view the mouse topic To change the task assigned to a button. 2. Click the Windows® Start button, locate the function or application you want to launch and right-click it to display a menu. (If the function or application you want to launch is not available from the Windows Start menu, use Windows Explorer to locate it and then right-click it.) 3. Select Properties. 4. In the Shortcut tab, enter a Shortcut key that is the same as the keystroke you chose at step 1. 5. Click OK.
Oct 06, 2005 | Logitech MX1000 Laser Cordless...
Dryers Logo
144 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
