Question about Archos 504 500870 Digital Media Player
Muffled voices in video playback
Ever since I updated the firmwear on my Archos 504 to 1.6.2 and purchased the plug-in to play mp4s, I´ve had a problem with sound during video playback. The sound is fine through the Archos built-in speakers or when connected to the TV through the docking station. However when I play video and try to listen to the sound through headphones, the voices are really muffled, although sound effects and background sounds play just fine. Am I missing a codec for these files? It played fine before so I'm mystified.
  • bex66jazz Mar 02, 2008
    Changing the equalizer settings does not work.
    Master:
  • 474 Answers
Go into your soudns settings, look for any settings that are for the Headphones in particular or auxilary or Line-in. Sometimes if these are on or turned down, it can effeect it. I.E. On my system, the Auxilary has nothing plugged in but if i have it turned on, it gets interference from my wireless and causes sound spikes so i muted it. Yours might be turned down or set low.
Also, sometimes MP4 files have a low Bitrate for the audio or its set top Mono or Stero and your earphones may be the oposit of what its set at so it sounds muffled.
If the MP4 has stereo sounds and you have stereo headphones it should be allright, but if it has MONO sound and you have stereo headphones, it might sound weird.
or it could be set to 5.1 surround and your earphones arent outputing all the sounds so it sound weird. Try using a different media player and devices to test it on and see if its the same on everything.
Posted on Mar 02, 2008
    Brigadier General:
  • 6,966 Answers
Withe the indulgence of Lemmor....
To my knowledge most Archos units share the same circuitry for the audio playback whether they be for lineout, built-in speaker and/or headset. And since they are digital in nature, then it can be presumed that the quality would also be the same all through it whatever medium is used to listen to. Hence a missing codec would effect all and not only headset(s).
Having said that, may it be possible that there is nothing wrong with the Archos unit but rather with the frequency response of the headset themselves. Of course the fastest way to verify this would be to use an alternative headset.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Mar 02, 2008
    The frequency response of the headset is subject to change relative to the length of time it has been used, being accidentally dropped/pressed. One should note that being small, they tend to loosed their full effectiveness after some time.
    Since "played fine before" and I will assume that you have tried all possible combinations of settings/parameters (and even perhaps a sound reset), then freq response and/or compatibility may be the issue.
  • Louie  Role
    Glad that you have figured things out and appreciate the rating too.
  • 749 Answers
Check for the equalizer settings... adjust them according to your listening mood... go to the menu and find it there...
Hope this guides and gives you a solution... goodluck.
How can i put dvds on my 504
You can drag and drop dvd files (divx/avi+AAC codecs) into the video folder of the device, but in order to play the you must buy the Archos cinema plugin. Visit the Archos official page and search your model.
Nov 20, 2010 | Archos 504 500870 Digital Media Player
Hi my archos 504 will play videos for 2-3 minutes then will stop(freeze). No sound is being heard. For music files, it will not play at all. For photos, it is ok. For videocorder, it does not record nor...
This is a good player available in the market.
ONE: Try a hard reset. Just unplug the power cord for 30 minutes or more, then try again.
TWO: the lazer head reader will be faulty, which would result in freeze and cause sound problems
It will not be wise for you to take the set to a repair facility simply because the repair, unless it is under warranty or you have an extended warranty plan, because the cost of repair is as much or more than the purchase price of a new player.
Apr 05, 2009 | Televison & Video
My archos 504 will play for 2-3 mins then will freeze.
you have to format your hd. for this conect your dvd player to pc. there is coming your hdd with a letter disk . click with the right button mouse and give format. after formating make sure to put some video from media player as described in your manual. (videos must be codec compatible to play). if is repeated same thing check your audi and video setting if nothing.... good luck i dont know another solution.
Apr 05, 2009 | Archos 504 500870 Digital Media Player
Archos 504
im not sure about the docking station but to see movies with out the cinema plug in just add videos that are in .AVI format and u can watch them fine.
Jul 08, 2008 | Archos 504 500870 Digital Media Player
Dvd transfer
Download Magic Video Converter from www.isohunt.com and change the video to WMP Standard 8. You don't need 1.25 GB vids for the archos, it's too high a quality for such a small screen.
Apr 18, 2008 | Archos 504 500870 Digital Media Player
Placing films onto the 504
I have put plenty of DVDs onto my Archos, but I use the optional cradle which connect to the TV as well as DVD players. You simply connect the DVD player onto it and play your dvd, which switching on the Recorder function on your unit.
Alternatively, can you convert the DVD onto your PC and then transfer onto the Archos in normal fashion, or is this what you are saying you tried to do already?
Sep 14, 2007 | Archos 504 500870 Digital Media Player
Problem in video / picture playback
quality of video? the playback is set by techs at the factory usally a boring screen with all the colors and black and white...it consistant the tech problably never tested it and passed it. they all need adjustments and precise to. take it back for a exchange. CrazyLarry
Jun 30, 2007 | Archos 504 500870 Digital Media Player
Playback button problems
please check what is your firmware version, the latest one is 1.6.23. If it is lower please upodate it by downloading the file from archos website. Maybe it would help
Jun 07, 2007 | Archos 504 500870 Digital Media Player
Archos 504 500870 Digital Media Player Logo
221 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
