Question about Astro Pneumatic Welding Tools
Drive wheels slip and won't feed wire. tensioner tightened as tight as possible.
    Problem Solver:
  • 6 Answers
Make sure your drive wheels and contact tip is the right ones for the size of wire you are using. if your tensioner is too tight it will crush your wire and it will not feed through your contact tip.
loosen off your tensioner and remove any wire that has gone through your drive wheels.
Posted on Feb 08, 2010
Why wont the wire come through my cosmo gas gasless welder
Most mig welders have reversible feed spools. There is a good chance you have the spool in the .030 wire side. Remove the spool retaining clip and flip the spool to .023 wire for example. I don't know what size wire you are using. Also there is an adjustment for the drive spool. Tighten the tensioner spring thumb screw to increase the feed tension.
Apr 28, 2014 | Welding Tools
Does the belt slip going uphill or with a full grass bag?
have you checked the wire that works the drive pulley it may need to be adjusted or replaced
Mar 01, 2017 | Craftsman 22" Rear Bag Rear Propelled High...
How do I tighten a drive belt on a 91 chevy silverado?
Well technically you don't tighten it.
The serpentine belt uses a spring loaded tensioner to keep it tight.
If the belt is slipping either the spring is worn out in the tensioner or the belt has stretched requiring either part to be replaced.
Jan 26, 2013 | Cars & Trucks
The wire is slipping on the wheels and not feeding to the gun
check the tension on the spool - is it free to rotate ( but not so free it over-runs when you release the trigger)
check the tension on the drive wheels - are they turning and slipping on the wire?
Do you have the correct drive wheels for the wire size? if you're using .8 wire, you need to be using .8 drive wheels (or the .8 grooves if you have multiple grooves.
is there a kink in the liner? pull out the liner (remove the whole gun attachment, usually the liner will slide out from the end where it attaches to the welder). Blow out the liner with an airgun while you're at it as they fill up with crud.
When you reassemble the gun, slide a lenght of wire up the cord and check that you can push it all the way in freely.
Then when you rig the welder, leave the tensioner off the drive rollers, and push the wire into the gun by hand. you'll feel if there are any tight spots ( usually caused by kinks in the liner).
once you've rigged it, clamp the drive rollers shut and adjust the tension until they feed the wire smoothly. (leave the contact tip off the gun when you rig it as the tolerances are so fine that even the small flattening of the wire where you cut it will usually prevent it from feeding into the tip. Once it feeds properly, reshape the cut end of the wire and attach the tip (don't force it over the wire or you' ll just damage it)
Jul 13, 2012 | Welding Tools
Changed alternator,battery and still won't keep battery charged
CHECK ALTERNATOR 175 AMP MEGA FUSE. AND CHECK ALTERNATOR 20 AMP INLINE FUSE.IF FUSES OKAY.REPLACE BATTERY CABLES AND CHECK ALTERNATOR BATTERY FEED WIRE AND VOLTAGE REGULATOR WIRES FOR DAMAGE.AND CHECK DRIVE TENSION.MAKE SURE DRIVE BELT NOT DAMAGE OR SLIPPING.
May 30, 2011 | 2003 Ford Expedition
I have a lincoln sp-175plus, when trying to weld it the arc just melts the wire and it balls up at the end. I also put a new contact tip in. As well sometimes the wire feed just stops. I then press...
Your drive tension is too light. There are rollers that the wire feeds through and they need to be tightened. They should push the wire through the gun but slip if you put the tip against a solid object and pull the trigger. If they do not slip, they will jam your gun. Give the tensioner another turn.
Jan 08, 2011 | Lincoln Electric LE 83180 Century...
Craftsman rotary mower, p/n 917.374821 will not move sometimes.
It is quite possible that one or the other of your pinions (item 55 in parts manual) has gone bad in addition to the wheels. Start the mower, engage the drive and lift the back end just enough to clear the ground and see if both wheels turn. If only one wheel turns, attempt to stop it from turning by setting it on the ground at an angle, if the opposite wheel does not turn, you will need to inspect the pinions.
Oct 30, 2009 | Craftsman Garden
Wire doesn't feed
Either the trigger mechanism in the gun is bad, the servo that turns the feed wheel is bad, or you have too much tension on the adjustable tensioner knob. Take the wire out of the feed wheel, plug unit in and see if you can get the wheel to turn. If not, it is the trigger or the servo. If it turns, the tensioner was too tight.
Jul 10, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Wirefeed slips, i have the correct size o.9mm flux cored wire, I think there may be too much play in the driveshaft/wheel (single drive wheel only) If so can I get another wire feed for it..?? (gassless...
It sounds like the feed spool is too loose or worn out.There should be a tension adjustment. What wire size are you using? On those off brands they usually use .035. and make sure the spool is not dragging. The wire spool also has a tensioner, or should have, in the center. Good luck.
Jun 07, 2009 | Welding Tools
I tighten the screws behind the belt but it still slips as i walk
Sounds like the motor drive belt is slipping,remove the motor cover,be careful some models have hidden screws in recessed areas underneath if you remove the correct ones the hood comes off easily. There is a bracket that has a bolt to adjust the motor belt tension.Also if you tightened the walk belt up it may be too tight which could cause it to wear or tear easier,the rule of thumb is tighten the walk belt just tight enough so it doesn't slip.
May 15, 2009 | Nordic Track /proform Treadmill...
Welding Tools Logo
273 people viewed this question
Top Astro Pneumatic Welding Tools Experts
Bill Boyd
Are you an Astro Pneumatic Welding Tool Expert? Answer questions, earn points and help others
