Question about Vacuums
Need belt to suit Hoover Brush Vac Model S1083-006
reddevil6
  • 1673 Answers
SOURCE: Hoover Z 700 Model U9145-900
Try going to hoover.com and either email them or there is a number that you can call, this is hoover direct, so someone there should be able to help you. Have your model and serial numbers and purchase date handy in case they ask. It also has a 2 year warranty on it. So if you bought it in the fall of 2006, then you have until the fall of 2008. I would take it to an warranty servicer and get it repaired before the warranty runs out.
Posted on Mar 18, 2008
reddevil6
  • 1673 Answers
SOURCE: changing belts on Hoover wind tunnel U6401
Take off the bottom plate covering the brush roll, 4 screws. There are 2 belts, if you replace both, put the V belt on 1st, then stretch the flat belt over the motor shaft, then over the bigger pulley along side the V belt.
Posted on May 20, 2008
SOURCE: hoover u5209-906 upright
1. You have to lay it on its front so you can unscrew the two screws in the underside (these are on the plastic panel covering the brush). There are also two holes for you to use a screwdriver in right next to each screwhole. Lever the plastic tabs in the direction indicated next to the holes (I think it is towards the motor). This case should then click up and away N.B. There are 3 tabs fixed into the cover on the front edge of the vacuum head. Be sure you don't snap these off.
2. You then need to use the foot pedal at the back of the vacuum to lay it flat and using a flat bladed screwdriver lever the top cover of the head away from the frame on the two back side corners and across the front of the head. The top case should now be able to come off.
3. The belt should now be able to slip off the motor spindle and off the brush.
Repeat the procedure in reverse once the new belt is on.
Cheers.
Posted on Apr 11, 2009
  • 175 Answers
SOURCE: hoover steam vac model f7425-900 filter is
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
Posted on Nov 28, 2009
SOURCE: hoover U6434-900 Brush roll not spinning, has new belt.
I took the top of the vacuum apart and found the cable that drives the wheels was broken. I am going to order a new cable.
Posted on Feb 15, 2010
My hoover steam vac is making a horrible noise and smells like its burning
Something may have jammed the brush roller, preventing rotation. This causes the motor shaft to rotate in one spot on the belt, causing the burning rubber smell. Eventually, the belt will break. You need to find what caused the jam and remove it. It would be a good idea to replace the belt as a burned belt is unlikely to last much longer.
Dec 18, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Need part # for drive belt
Here's a link to the schematics. It diagrams each part and it's number. Best of luck.
http://www.vacuum-depot.com/parts.asp?SchematicID=190
Feb 25, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hi I have model u64330-900 hoover windtunnel. It
It sounds like your vacuums belt is stretched and worn. You'll need to replace it. Below is a link to a website that gives instructions with pictures on how to change the belt. You should be able to get a replacement belt at any department store or vacuum retailer.
I hope this helps you.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Sep 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt won't stay on
A belt will slip off because it is stretched, or the brush bearings are worn, or the motor drive shaft is misaligned.
Hoover belts fit snug.
After as little as week they begin to stretch. Even though they are not broken, they will spin loose. IF you can stop the brush with little effort and the belt keeps moving the belt is stretched. Do not buy a belt buy size, buy it by model. But 2 and store your spare under the hood of the vac if possible.For best cleaning results,change every 3-4 months if you vacuum weekly. 6 months at most.
Most times your old belt will be stretched as much as 30% oversize. If it looks shiny inside it has likely been slipping.
Before reinstalling check that your brush rolls freely and clean the bearings at the end of the brush roll.. Once reinstalled check it again before turning on the vac.
Sep 13, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Feb 07, 2009 | Hoover Vacuums
Hoover wind tunnel vac
If the belt is getting hot, then it is slipping instead of turning the brush roll. Check thge brush roll, make sure the ends are turning freely. Is the motor running ok? If it is then either the brush roll is bad, need a new belt, or something is catching the belt, not letting it move.
Mar 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Changing belts
Turn vac over, remove the 4 screws holding the bottom plate covering the brush roll. There are 2 belts, one is a V belt ( 38528034) for the brush roll, the other is a flat belt (38528035) that goes from the larger pulley and the motor shat, put it on the motor shaft then stretch it to go over the pulley.
Jan 22, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt on steam vac v2
The V2 doesn't use a belt, it uses a turbine to drive the brush block, If brushes are not turning, either the shaft on the brush block broke off, or the turbine is bad and will have to be replaced.
Dec 23, 2007 | Hoover F5906-900 Upright Steam Vacuum
Hoover belt replacement
Turn vac. over, remove the buttom plate over the brush roll, then at the bottom edge of the top cover, using a flat blade screwdriver, insert into the slots and pry up to unlock the tabs, then the top cover will come off. Put the belt on the brush roll and feed the belt thru the opening and put stretch it over the motor shaft. Put the top cover back on and push to lock the tabs.
Dec 19, 2007 | Vacuums
Vacuums Logo
164 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
