Question about Dyson Vacuums
POWER CORD DAMAGED AND NEEDS REPLACING. wHAT IS THE SECRET TO OPENING THE SWITCH MECHANISM ON MY DC03. I LIVE IN A REMOTE AREA AND CAN'T JUST DUCK IN TO A SERVICE AGENT. CHEERS, KINGSLEY DYSON
  • kgydys Feb 08, 2010
    Comments did not seem specific to DC03 - hard to follow !!
  • 265 Answers
I am not an expert to this kind of machine but I can share with you this link below which I am sure would be a big help to you. Good luck.
http://www.sparesaver.com/help-and-support/dyson-section/dyson-hints-and-tips-451/dyson-dc03-hints-and-tips-468/dyson-dc03-cutting-out.html
Posted on Feb 08, 2010
  • 3,740 Answers
Hi an welcome to Fixya. Most any vacuum you remove the mounting screw then take out the cover cord and switch all at the same time.
Usually you remove the bottom piece first as you are lifting it out as it will fall away if your not careful then cord and switch.
You can order the cord here. UK
http://www.dysonpartsdirect.co.uk/dysonparts/dc03parts.shtml
There is also a NZ dyson parts store:
Contact us Telephone: 0800 397 667
Our customer service team is available Mon-Fri 8.30am to 5.00pm. Email:
dyson@averyrobinson.co.nz
Dyson 03 how to repair damaged hose
Depending upon the damage, follow one of the instructions found here. If it is electrical, buy a replacement hose.
https://www.google.com/search?q=how+to+repair+damaged&oq=how+to+repair+damaged&aqs=chrome..69i57&sourceid=chrome&es_sm=122&ie=UTF-8#q=how+to+repair+damaged+dyson+dc03+hose
Mar 11, 2015 | Dyson Vacuums
Brushbar not turning
Hi there, it's Jack at Dyson.
DC03 doesn't use a traditional user-replaceable belt. Instead it has a brush control clutch mechanism which allows you to turn off the brush bar when cleaning hard floors and delicate rugs.
If the brush bar doesn't seem to be rotating, it's worth double-checking you have the brush control set correctly. When the machine is reclined into the normal vacuuming position, the brush control should move to the Drive/On position:
Please note, as a safety feature the brush bar will never rotate when the vacuum is standing upright.
If you're confident the brush control is in the correct position, but the brush bar still won't rotate, please give our freephone UK Helpline a call on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
Sep 16, 2014 | Dyson DC03 Bagless Upright Cyclonic Vacuum
Can you replace dyson on/off switch dc05 turbobrush
There are a number of places that list replacement switches. There are also a number of DC05 models, though the power switch is not likely to vary across them. Amazon, for instance, has a Dyson Switch for models including the DC05 and six other models (see here
Dyson Switch Dc03 Dc04 Dc05 Dc07 Dc08 Dc11 Dc14 On Off )
This video (ostensibly for a DC08, but the procedure should be pretty much identical) shows how to take the unit apart, get at and test the on/off switch, and replace it if need-be.
How To Change Dyson DC08 Switch An Easy To Follow Tutorial
Good Luck!
Jul 31, 2014 | Dyson DC05 Cylinder Bagless Canister...
How do i relace mains lead
If this is the mains AC cord this must be done according to the winder mechanism of the vacuum pump. Since the make model is not mentioned you need to open the unit and carefully remove the power cable, replace ONLY with the recommended type that will take up spooling without damage.
Dec 09, 2011 | Vacuums
DC03 Clutch Replacement
Hi Mike,
We can't provide directions on replacing a DC03 clutch, as this should only be carried out by a Dyson engineer. If you feel your DC03 isn't picking up as well as usual, you may be able to resolve this with some simple troubleshooting steps:
http://www.dyson.co.uk/support/help.asp?model=SUP-DC03&article=527
If you've tried this and would like some further assistance, get in touch with us free on 0800 298 0298. Our Helpline is available from 7am until 10pm, 7 days a week.
Kind regards,
Jack
Dyson Online Customer Support
Nov 02, 2011 | Dyson DC03 Bagless Upright Cyclonic Vacuum
Will not start. replaced switch. What next?
1. Make sure that both safety switches are engaged (front and bag area).
2. The power cord can break internally where you won't see it. Look for damage or twists in the cord. With the vacuum turned on wiggle these areas between your hands and see if it tries to run. If so replace the cord. If not the he motor may need to be serviced
Apr 29, 2011 | Kirby G5 Bagged Upright Vacuum
The mechanism that rolls back in the power cord seems to be working slower and sometimes not at all. Was wondering if the mechanism in question has an adjustment to increase the tension on it so the power...
it easy to adjust the roll back of vacuums the problem is hard to dismantle the unit to remove all the things to see the adjustment roll,all vacuums is need to remove all screw to open the unit even to replace the small parts like switch,and sometimes we cannot adjust the roll back if the spring is worn out we need to replace the new one,for me much better call and service technician for your comfortable and practically to not damage the other plastic part of the unit.and you get a warranty service for that one.
Jan 01, 2011 | Kenmore Vacuums
My Hoover Dirt Finder red light stays on. All
Inspection of the circuit board found that the 470uF capacitor looked damaged. I replaced it and I now have the Green and Red lights are working correctly.
Jan 19, 2010 | Hoover U6476-910 WindTunnel Upright Vacuum...
Dyson dc03 faulty cable The cable from the mains plug to the on/off switch has split and needs to be replaced. How do I gain acess to the switch ? I am a competent engineer but I do not wish to damage the...
I've never worked on a DC3, but whilst the shape and position of the switches changes from model to model, most are secured the same way.
If you look closely at the switch cover (the bit you press for on/off), there is usually a small slot to one side. If you insert a thin, flat tool (a small screwdriver or flat file, etc) into the slot, you should "feel" it disengage a tab. If you now gently prise up the switch cover, it should come off easily.
Hope this is of some help.
Oct 14, 2009 | Vacuums
Vacuum stopped working
Sometimes after years of use the power cord can break internally where you won't see it. Look for damage or twists in the cord. With the vacuum turned on wiggle these areas between your hands and see if it tries to run. If so replace the cord. If not the switch may be bad or the motor needs to be serviced. Good luck. Please rate me so I know if I helped.
Dec 30, 2008 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
106 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
