Question about GE 25952EE1 Cordless Phone
Phones are powered but do not connect to base so can't receive or make calls. Is there a way to reset?
    Problem Solver:
  • 8 Answers
The manual, which can be found at: http://www.home-electronics.net/ge/pc/IB/25952EE1_IB.pdf, reads:
4. Place the handset in the base cradle. The charge/in use indicator turns on,
verifying the battery is charging. The unit will take 20 seconds to register
and verify its security code. READY shows in the display.
NOTE: In case of a power failure, the handsets may display
UNAVAILABLE when the TALK/CALL BACK button is pressed.
You must then place all handsets on the main base cradle
for 20 seconds to re-register.
That should reset your handsets. Hope this helps :) Thank you very much.
Posted on Feb 08, 2010
How do I link handset to base after power outage CS6529-3
You set the cordless phone back into the charging base. After a few seconds (longer if in need of a charge), the cordless will register with the base establishing the connection required to place and receive calls.
Feb 19, 2015 | Lands Phones
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
I can't receive any calls
Depending on your service provider and what type of phone you are using there could be several different ways of solving this problem. If it is a cell phone you might try the reprogram number to reset it if it's a house phone unplugging the power supply on the phone and/or phone base may do the trick. One again this all depends on the phones make, carrier, and type.
Jan 27, 2012 | Lands Phones
My panasonic KX-TG5000 phone headsets cannot make or recieve outgoing calls and the intercom function is gargly.
You need to reset the menu once again as it is possible that the phone had hung up as there was LINE PROBLEMS . Once this was reset the CLIP facility came back. So if you can once again remove power battery and keep aside to reset , then start all over to set up the base and slave units to MESH , the intercom and line facility must work.
You can remove the battery from the slave remote units to reset.
Oct 20, 2011 | Panasonic KX-TG4500 Phone
When power off...phone connection is droped
yes it is necessary for the base station to have a permanent electrical connection. when you receive and send calls, the base station is the transmitter and receiver of all of the handsets. if your power goes out a lot, get a corded phone as a backup (available at walmart for less than 20 bucks).
Jun 10, 2009 | Panasonic KX-TG5632 Phone
Can not able to answer any incoming call
if you suspect the problem is with your device, then reset the phone by following the instructions given in the instruction book which came along with your phone..if it still doesnt work then check the connectivity by connecting some other phone(friend's phone) with your landline cable.if the new phone is also not able to receive calls then contact ur service provider..but if the friend's phone works with your land line connection then pls report again
May 22, 2009 | Uniden TRU9480 Cordless Phone
Phones won't pick up calls...say connecting
HOLD THE HANG UP BUTTON AND THE POUND BUTTON DOWN FOR 5 secons. select base unavailable....yes. then hang it up on the base and it will register to the base. if that doesn't work then unplug the base then plug it back in then put the reciever on the base.
Nov 20, 2007 | Uniden TRU9380-2 Twin Phone
GE 25952EE1 Cordless Phone Logo
526 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
