Question about GE Refrigerators
Freezing up. installed heater also thermister also termination sensor ge side by side gss22kgmdcc gd208205
  • GE Master
  • 3,361 Answers
With those parts replaced the fault is in the control board on the rear of the refrigerator. It is responsible for initiating defrost.
Posted on Feb 08, 2010
Testimonial: "you are a great help . thank you i also felt it was the mother board but i wanted to hear from the experts thank you "
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
Defrost heater repalced, thermisters ok, but still freezes up after about 2-3 weeks. how do test the board
http://appliancedigest.com/index.php?/files/file/462-31-9062-ge-refrigerator-adaptive-defrost-service-manual/
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
GE Profile jvm1090ww 01 SN ZR958136 s Convection temperature does not get above 360F when set at 450F. Could never brown meat or bake.
The convection heater is control according to the temperature of the part n 3014 Thermister
Part Number: AP2025611 made by GE
So this is acting like a temperature sensor and it seem that is giving wrong indication to the control panel and switch off the heater at wrong temperature.
So you should replace the thermister.
You can find this and all a other parts of your oven in this link.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=216738&diagram_id=20027025#d20027025
Nov 04, 2010 | GE JVM1090WW Microwave Oven
GE side by side. defrost heater does not come on. Installed new heater, no luck.
When the timer turns off the compresor to defrost it sends power to the defrost terminator (round thing atach to the freezer coil ) who energized the heaters if the coil is frozen ,at this time you can check if there's power to the terminator ,if not timer is bad, and if the timer sends power to the terminator and it won't close when coil is frozen up the terminator is bad.
Aug 13, 2009 | GE Refrigerators
Climate control drawer is 20 degrees, freezes everything,
on the bottom part of refrigerator right wall , theres a thermister, i bet is faulty
Jul 11, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Where is the defrost timer located on GE model# GSS20IEMDWW side by side refrigerator? My freezer works but the other side is warm. I took the freezer panel off and it had a thick layer of frost...
This model does not have a defrost timer. It has a motherboard. You must jump out the plug to the main board to test the defrost circuit. In order to do this take the cover off of the main board, find the three wire connector on the base of the main board, connecter is normally blue in color. On the board itself it will identify termials as line, defrost, and compressor. To test you must create a jumper wire.Install the jumper in the plug terminals identified as line and defrost.This will turn the defrost heater on. If the heater does not come on, look for a defective heater or a defrost thermostat(mounted on the top of the evaporator). If the heater does come on replace the thermister(located on top of evap, white in color and has two white wires part#WR55x10025)
Jun 04, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Test to see if circuit board is okay
From Appliance Aid.com
WHY Force the Arctica to Defrost if it Don�t Want to? Don't bother using the self-diagnostics feature to force a defrost cycle. On some models � those with control knobs - which technically are not Arctica models (Arctica models have plastic liners with touch pads � Standard GE electronic models with metal liners have knobs) servicers would have to invest in parts to build a �test� control panel, complete with touch pads and digital displays, to achieve this (self-diagnostics) function. Instead, save both time and money by following this helpful Arctica Tip: If a frosted evaporator or a �frost block� is apparent, initiating a defrost cycle may not reveal anything helpful anyway. First, disconnect power and then simply check the resistance across the defrost heater and bimetal circuit at the main board located at the backside. The two associated wires at the main board are almost always BLUE and ORANGE. The heater/bimetal circuit should normally read around 30 ohms roughly. Next, check the evaporator thermister at the main board between thermister input terminals J1-4 (Blue/White) and J1-5 (Blue) to determine that its resistance is greater than 1.2k ohms but not more than 166.8k ohms depending on its ambient temperature. If thermister resistance falls within this range according to temperature (Approximately: 6k ohms at 70�F � 16.3k ohms at 32�F � 51k ohms at 0�F) and the heater/bimetal circuit is diagnosed as good, then replace the main board.
Apr 30, 2009 | Refrigerators
Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Apr 04, 2009 | GE GSS22SGM Side by Side Refrigerator
GE sxs defrost problem
How long does it take for the frost to build up, improper placement of the bi-metal will cause a defrost issue by not letting the heater stay on long enough.
Let me know how you make out.
Thanks,
Bill
Apr 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge rifrig will not defrost
you have a defrost issue not being able to verify circuits on the mother board i would replace the high limit, what you are calling the termination stat this stat stays closed unless the temp hits 140, thats right 140 degrees f and change the evaperator sensor.
evap sensor can cause missed defrosts or no defrosts
high limit part number wr50x10068
sensor number is wr55x10025
each part is 7-15 dollars each
Apr 07, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
