Question about Remington Electric Pole Saw
I have a remington pole saw #108526-01 with a torn oil cap. Can I replace it?
    President:
  • 2,220 Answers
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
107512-01 is the part number $4.72
RemiongtonPower is no longer in production and eventually eBay will be your only source for parts. HTH
Lou
Posted on Feb 08, 2010
  • 677 Answers
Http://www.masterparts.net/rps96.html
They should be able to get your part.
Am I wise to purchase a Remington Pole Saw or should look for another manufacturer? Which Remington Pole Saw would you purchase: a. 18V Cordless b. 10" Electric
Remington Saws have ceased operations and, unless you like to make your own replacement parts, they are prone to failure. The gearbox is sealed and the motor brushes are not available anywhere. Look elsewhere!
May 11, 2010 | Remington Electric Pole Saw
Remington electric Pole Chain saw - what type of oil do I use?
SAE 30 motor oil if the temperature is between 30 & 75°F.
-Colder use SAE 10 oil.
-Warmer use SAE 40 oil.
take a look on amazon: Amazon com SAE 30 motor oil
Apr 24, 2010 | Remington Electric Pole Saw
What kind of oil solution do I use in my remington chain pole saw
I recommend bar and chain oil (SAE 30 with additives to make it adhere) available at hardware stores and home centers.
From a Remington OM, page 9 (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F
  • Colder use SAE 10 oil.
  • Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
  • It is normal for oil to seep when saw is not in use.
  • Empty oil tank after each use to prevent seepage.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 30, 2010 | Remington Polesaw Wizard
Replace remington saw model 106890-02 push button out of oil cap -- where can I buy online
Give Master Distributors a call, they stock most parts for Remington saw products. 1-800-446-1446
Here's a link showing the parts break down for the hand-held and pole saws.
http://www.masterparts.net/106890-01.html
Hope you found this Very Helpful - Best regards!
Aug 19, 2009 | Remington Polesaw Wizard
Where can I find a chain oil cap for a Remington Pole saw,Model 108526 - 01
call Tim independent cycle 660-826-0149 he will have part or will find one
Aug 05, 2009 | Remington Electric Pole Saw
What kind of chain oil to use for a 10in remington electric
According to the manufacturer... "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." So, I suggest for any Remington electric chains saw not to use bar and chain oil. I hope this helps...
Jun 25, 2009 | Remington Electric Pole Saw
I need a new oil resevior cap for my Remington pole saw model #108526-01 and I do not know the part number.
According to your owner's manual... http://12.153.20.74/manuals/108539-01L.PDF. You will need part # 107512-01. You can contact Master Parts at 800-466-1446 or you also can find them online at www.masterparts.net. I hop this helps you!
Jun 23, 2009 | Remington Electric Pole Saw
Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
Apr 26, 2009 | Remington Electric Pole Saw
I have the model 108526-01 Remington pole saw which has the round pole with a plastic compression nut (which recently broke). Can I buy the newer octagonal pole and if so, does it use the same saw mounting...
I have the sollution, had the same problem with the broken compression nut. Just use two hose clamps, one to hold the pole extended and the other clamps around compression base. Its a cheap easy fix and it work great fo me. The Real Mr.Fixit
Apr 03, 2009 | Remington Electric Pole Saw
Lost the push button out of the oil cap.
i called master parts and they gave me a phone number to get replacements.
Mar 03, 2009 | Remington Polesaw Wizard
Remington Electric Pole Saw Logo
603 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
