I want to run my Samsung TV HPS4253X/XAA audio through my JBL DCR600 receivers speakers? Not sure what jacks or what buttons ultimately need to be pressed?
  • 362 Answers
SOURCE: Protron PLTV 32 - audio output jacks not working correctly
Hi reb21, From the Audio menu check and make sure your audio output is not set to Mono, anyother setting should produce a an output signal on both wires. Let me know if this helps and please rate this solution. lone99star
Posted on Jan 13, 2009
SOURCE: samsung lns4041dx/xaa
Same problem with my set. The volume was either fully up, or fully down (usually down), and other controls didn't work- like I couldn't access the menus and could not adjust the width of the screen/aspect ratio.
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Posted on Mar 14, 2009
SOURCE: No sound from external speakers system
Look into your monitor settings and computer settings and see if you can reverse the "input" and "output". If both are set to line in or line out then they pretty much cancell themselves out.
Posted on May 23, 2009
  • 304 Answers
SOURCE: model hps4253x/xaa vertical lines throughout
Need more specfic info. Are the lines on all sources? Are the lines as thin as a Pinstripe?. The possible causes are: The Main bd is bad or the P-Logic bd is bad or the Plasma Panel is bad. Have a trained samsung tech troubleshoot the set.
Posted on Jul 16, 2009
  • 125 Answers
SOURCE: trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Posted on Aug 25, 2009
Testimonial: "very fast, thanks for the help!"
I have a samsung plasma 50" tv, how do I hook it up to this sound bar? I tried to hook it up using the rca jacks and it didn't work.
Near the Audio / Video inputs on your tv, you should see a "headphone" jack or it may be labeled "Audio Out"
some sound bars plug into these jacks using standard heaphone jack.
Other sound bars may need to be connected to the device your using on your tv. (DVD player, cable box, etc.)
Tv speakers can then be disabled in the "Audio" menu of your tv.
Dec 02, 2014 | Samsung Televison & Video
Can JBL Creature 2 speakers work on a Samsung smart tv
Do you happen to have the model of the TV? My Samsung only has two digital optical outputs. If your'e plugging in JBLs, you may only have an analogue input which won't work.
Mar 16, 2014 | JBL CREATURE II Computer Speakers
Hi how do I get surround sound coming from my tv
A Samsung home theatre system can make watching movies at home like going to the theater. Proper setup is essential to get the full benefit of the Samsung system, which is available in 5.1 and 7.1 channel surround sound configurations.
Typically the final step in setting up any home theater is connecting your TV to your system.
Like most home theatre systems, your Samsung home theater receiver will allow you to plug all of your components into it, meaning you only have to run a few cables to connect your television to your system.
Make sure your playback devices are properly connected to your receiver.
Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver.
DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs.
Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component.
If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV.
If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your Samsung receiver if you want to output your television's audio through your home theatre system.
Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television.
If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote.
When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable.
Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Samsung home theatre system owners guide download
http://downloadcenter.samsung.com/content/UM/200903/20090327091825515/HT-AS730S-XAA.pdfalso
If you're not an electronics junkie, hooking up your surround sound can seem daunting.
There are so many wires and settings that it's understandable why some people might rather pay someone else to do it for them.
But you can do it yourself as long as you make sure the speakers are positioned correctly; the wires are not only plugged in all the way, but plugged into the right places; and the settings on your television and amplifier are set up correctly.
Check to make sure your surround-sound speakers are correctly installed.
Locate the test function on your surround-sound remote control or amplifier panel to do this.
You will know your speakers are hooked up if sound comes out of each speaker during the test.
Make sure your audio cables are hooked up properly.
Make sure the audio cables running from your television to your amplifier are plugged in correctly. The red and white wires should be plugged into the "Audio Out" spot on the back of your television.
Those same red and white audio wires should be plugged into one of the "Audio Input" spaces on the back of your amplifier.
Turn on your television.
Locate the "Menu" button on either your television remote or your television set.
Scroll through your options until you find "Audio Mode" or a similar naming convention.
Select it.
Scroll through your options until you find "Digital Audio Out," or a similar naming convention. Choose it.
Scroll through your options until you find "Dolby Digital Out." Select that option.
Power your surround-sound system on.
Make sure you have the correct audio input selected.
After the correct audio input is selected, make sure you actually have the Dolby Digital aspect of your surround sound system turned on.
The default for most surround-sound systems is the standard two-channel, stereo output.
Set up a home theater
http://www.cnet.com/1991-7386_1-6214422-7.html
Aug 07, 2013 | Samsung Ht-E355 330W 5.1 Channel Home...
I'm trying to connect a Samsung HD LCD tv to a Denon AVR1508 receiver using HDMI cable so that the TV sound comes thru the receiver/speakers. which jack do I use (on both the tv and the receiver,
connect the hdmi to the tv (hdmi input 1) and to the receiver (hdmi output) you must make sure that the receiver input settings are assigned correctly. Then hook up all of your devices to the receiver. remember that the 1508 dosent do hdmi upconversion, so if you have any devices that are NOT hdmi, you need to run rca cables from the output of you receiver to the input of your tv. If you have any digital inputs coming out of your devices, i would recommend using them. your 1508 has two inputs that are assignable.
If all of your devices are hooked up to your receiver, and its hooked up to your tv properly, just turn down the sound on your tv, and turn up the volume on your denon!
Dec 04, 2011 | Denon AVR-1508 Receiver
How do i connect the following speakers to a tv?
Look for a headphone jack plugin on the TV, and if you have one then plug the speakers into that. Otherwise if you only have RCA audio jacks on the TV (red/white plug-ins), you'll need an RCA male/stereo female adapter. I did a quick search and found this one on Amazon for $1.49:
http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE
You could probably find one at Radioshack or a local electronics store otherwise.
Also, in case you need it, here's a link to the owner manual:
http://www.jbl.com/resources/Brands/jbl/Products/ProductRelatedDocuments/en-US/OwnersManual/Creature%20OM%20Rev%20A.pdf
Sep 06, 2011 | JBL CREATURE II Computer Speakers
Im having problems with my samsung tv the power keep going off and on
  • 1 Check the power. Don't be embarrassed if your problem is as simple as an unplugged power cord. It's better that you should discover this than pay a repair technician to come out to your house and find out.
  • 2 Isolate the problem. The main troubles that will crop up with a TV set are either no picture, no sound or both.
  • 3 Check the input setting on your remote control. If you have other devices connected to the TV, such as a video game system, those devices must be used with a different input setting than the input you use for watching programs or movies on a DVD or Blu-Ray player. Chances are, the kids were playing a game and forgot to turn the input back the way it was.
  • 4 Press the Input button on your remote control to return to the setting you wish to use. For example, the cable box might be connected to Input 1 and your DVD player might be connected to Input 2. Newer television sets have at least 3 inputs.
  • 5 Check the coaxial connection from your cable or satellite receiver to the television. The cable should be attached securely by twisting the round lock nut clockwise. Also check the power connections for the satellite or cable receiver. If either is unplugged, you won't receive a programming signal on the TV.
  • 6 Make sure the video cable is securely attached to the TV jack if you have a home theater system. The video cable runs from the Video Out jack on your home theater receiver to the Video In jack on the back of your TV.
  • 7 Check your receiver setting. Home theater receivers manage several components, so if you have the receiver set to operate the CD player but you are trying to watch a movie on your Blu-Ray player, you'll need to change the selection to Blu-Ray to watch the movie on your TV.
  • 8 Check the TV speakers to see whether they have been muted by accident. Press the volume button on your remote control or go to the Menu section and scroll down until you reach TV Speakers. Toggle left or right to turn the speakers on or off.
  • 9 Press the speaker button on your receiver to make sure your external home theater speakers are activated. Many home theater systems use external for their superior audio rather than the speakers inside a television
  • pls rate or vote on how helpful it works.
  • Feb 05, 2011 | Samsung HCH551W TV
    How do the wires go into the back of the creature?
    First go to this site and download and install this codec pack. Also, make sure you have your speakers set as you default sound device.
    JBL Creature 2 are a computer speaker system designed and sold by JBL. The system is made up of two satellite speakers and an omni-directional subwoofer. The speaker system connects directly to a computer's available sound card output jack or a laptop's stereo output jack. Occasionally, problems can occur with the sound quality and connection with the speaker system. If there is no sound coming from the speakers, check the cable connections. Ensure the satellite speakers are firmly connected to the matching jacks on the back of the Creature's subwoofer. The connections are color coded and, in addition, each speaker connector is shaped differently to fit only into one jack. Ensure the output cable is firmly connected to the subwoofer audio in jack and the computer's audio-out jack. Ensure the power button on the back of the subwoofer is pushed inward. If everything is connected properly, the green lights on the underside of the satellite speakers will glow.If there is still no sound, tap the right-hand side audio-increase button on the right satellite speaker until sound is heard. Also ensure there is audio playing from the computer. Double check the lower right-hand side of the window's main screen and look for a speaker icon. If the icon has a red slash over it, click the icon and uncheck the "mute" option.
    Hope this helps
    Dec 30, 2010 | JBL CREATURE II Computer Speakers
    Compaq JBL Platinum Series Speakers not working on Windows Vista
    change the audio and sound device setting in the control panel. try to change the speaker setup
    Oct 05, 2009 | HP JBL Platinum Computer Speakers
    Use JBL Creature speakers (pc speakers) through tv
    There may be a setting in the TV's menu to set fixed or variable output for the rca's. You want variable. Some have two sets of audio outputs for fixed and variable. Depends on the TV. Check those two things. If no help let me know what the TV is and we'll see what we can do.
    Jan 25, 2009 | Onkyo TX-SR605 Receiver
    Wiring with a sattelite receiver and new Samsung TV
    Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
    "You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
    To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
    1. Turn off your TV and Home Theater System.
    2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
    1. Turn on your TV and Home Theater System.
    2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
    For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
    In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
    Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
    Dec 26, 2007 | Samsung HT-X50 System
    Televison & Video Logo
    41 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
