How to fix a jammed 3 cd changer by onkyo c-707ch?
My 3 cd changer is stuck closed or jammed and won't open to get the cds out. the player is onkyo c-707ch.
Help?
bluenadas
  • 203 Answers
SOURCE: cd tray mechanics
It can be repaired but in all of my years in consumer repair, I dread the CD/DVD tray alignments the worst.
There are many things involved in getting them to operate without fail. Using the mfgs documentation you can get them up and running but most of the time they failed because something is amiss to begin with. So you spend an hour getting everything setup and it will work once or twice but them fail. Only to find out that a location sensor is bad or a gear is missing a tooth....
Posted on Nov 21, 2007
melnavz
  • 1226 Answers
SOURCE: jammed cd player
You can fixed the alignment of the disk tray of the CD player. But its pretty cool if the repairman in your nearest location would you let do the job.
Posted on Jan 07, 2008
RFICKES
  • 51 Answers
SOURCE: Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
Find the screws that hold the to of the case to the chassis. They should be on the bottom, and back. Once they're removed, gently pull the top off. You may have to fish under the carousel to get the CD, but if you're gentle, you should be okay. Make DARN sure the power's unplugged, and keep your tools away from the power supply, just in case there's some residual energy left. Good luck!
Posted on Jan 04, 2009
SOURCE: TEAC CD player jammed
I had the same problem in 2007: I removed the cover and manually encouraged the cd drawer to open. It has been working ever since.
Posted on Sep 14, 2009
SOURCE: cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Posted on Oct 26, 2009
My alpine CD player is showing a cd 3 error jam
Are all CDs in the magazine? If not, there may be one stuck in the changer
Sep 23, 2012 | Alpine Car Audio & Video
3 cd's are stuck in player and the 5th changer won't open
Unplug it from the wall and give it time to power down. When you plug it back in it will reset itself and the changer will open. Pretty much the way a computer resets itself when you unlug it completely. Also works on my DVD player when it jams up
Sep 12, 2012 | Panasonic Audio Players & Recorders
C.d.s get stuck and now tray wont close
The problem is in the loading bay, sometimes 2 CD's will get jammed locking up the system, or the timing gear is out of sync, or possible broken gears.
May 04, 2012 | Onkyo DX-C390 6-Disc CD Changer
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
2003 Ford Expositi CD Player will not play or eject
Does the CD door open or is it stuck open? If it is open look to see if you have a jammed CD. This happened to me and this is what I did. A CD had gotten off track and jammed the CD changer turn table. I stuck a little key in the slot and was able to pull the CD out. This fixed my problem. Hope it helps.
Dec 21, 2009 | 2003 Ford Expedition
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
May 07, 2008 | Onkyo DX-C390 6-Disc CD Changer
Jammed cd player
Jan 06, 2008 | Audio Players & Recorders
471 people viewed this question
 Grubhead
Grubhead
