Question about Whirlpool Duet GHW9150P Front Load Washer
Cold water inlet not working - Whirlpool Duet GHW9150P Front Load Washer
    President:
  • 949 Answers
Remove the hose after you turn off the supply line, then place the hose inside the washer and turn it on, this is so you are sure the line is supplying water, don't turn on full force or the hose could fly out.
Now once your sure that water can come out of the hose and that there is not another shutoff is turned off, you know that the inlet valve is bad.
Posted on Feb 08, 2010
DWD-WD1353WC no cold water, uses hot only
unplug your machine swap the water inlet wires hot to cold and cold to hot if you now have only a cold wash replace the water inlet
Mar 15, 2018 | Washing Machines
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
Hot water when cold is selected
""Selectedd cold / cold and machine fills with hot water.""
Is your machine a FAV6800A or FAV9800A? If it's one of those I Have specific info to troubleshoot in Service Mode.
We will go into Service mode and turn on the Hot and Cold water inlet valves from the console and make sure the correct water inlet valve opens and fills the machine...........Rich
and a p/n if you need to replace the water inlet valve assembly.
Apr 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a Samsung WA13G7Q1 washing machice The
the quection is not complete, when the cold water inlet and hot water inlet both work then what is the problem....
Apr 27, 2010 | Samsung Washing Machines
Do u have to have hot and cold water hoses connected for machine to work.or will it work with just cold water
Most of the front loading washers and combos have two inlets for hot and cold water which are automatically controlled according to the setting used and hence both the water inlets needs to be connected for the machine to work properly or else the machine may take more time to fill water and there is also a possibility of the machine malfunctioning. However if you don't want to use hot water you may supply cold water to the hot water inlet which will at least make sure that the machine works fine.
In case you have only one faucet for supplying water to the machine you may use a Y-connector which will allow you to connect one hose to one side of the connector and two hoses to the other side of the connector which can then be connected to the two inlets to the machine.
Feb 25, 2010 | Washing Machines
Cold water doesnt work
Hi, First check and see if there is something plugging the cold water inlet screen. Remove the cold water hose to look at the screen. Another way to test the inlet valve is set the washer to cold wash, listen for the inlet valve to buzz or hold feel the cold inlet fitting and see is you can feel it vibrating.
If there is nothing plugging the inlet screen and the inlet valve doesn't buzz, you will need to change it.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 14, 2009 | Kenmore 24032\24036 Top Load Washer
Rinse cycle and cold/cold temp are not working
You either have a faulty cold water inlet valve or you have the cold water hose connected to the hot water inlet valve. Cheers
May 15, 2009 | GE Washing Machines
GE WHRE5260E1CC NO HOT WATER
hi If the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Sep 13, 2008 | GE WHRE5260E Top Load Washer
Can't get the cold water to turn on. I have 1. switched hoses 2. no kinks 3. water is turned on Model 1220
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Aug 17, 2008 | Hoover Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
