Question about Dryers
Taking to long to dry clothes there is heat so not heating eleoment
  • 1,531 Answers
Most common problem is restricted air flow while the dryer is running go outside and see how strong the air flow is. there should be alot of air coming out pretty strong
Posted on Feb 08, 2010
LG Dryer takes too long to dry clothes
Sure the outside vent is not clogged up? If so it will overheat and turn it self off and do a poor job of drying the clothes.
Also check and make sure that all of the heating elements are working properly.
Jul 09, 2017 | Dryers
Clothes dryer doesn't heat
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Nov 26, 2011 | KitchenAid Dryers
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
My GE dryer takes 3-4 times as long as I expect it to to dry my clothes. I've read that it should take about 45 minutes to dry a load but after the first cycle the clothes are still damp. It usually takes...
You have checked a lot already ... thanks for the comlete story. Often the questions here hurt for detail.
Are your clothes getting hot?
Two reasons for not getting dry ...
No heat
No air.
You need warm air (heat and air) going through your drier to achieve dryness.
Sounds like you have no heat. Are you properly setup on the control panel (you selected heat)? You have physically inspected the entire exhaust sustem including the outside vent, hose and lint trap - absolutely clear ...
check the heat my friend
Oct 20, 2009 | Dryers
Dryer heats up but doesn't dry clothes take 3 hours after restarting 3 times to dry 3 articles of clothing.
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
Oct 15, 2009 | Whirlpool LER4634J Electric Dryer
Take too long time to get cloth dried
how much are you putting in ? Is it a 220 volt dryer? May have a dead line (electris) to heating coils, or thermaostat is not functioning and letting the dryer coils get to operating temperature. Your heat setting control may be faulty. I wouls look at heat control first.
Jul 02, 2009 | Frigidaire GLER341A Electric Dryer
Dryer won't heat up to dry the clothes the heating element works
Check the following to address this issue--
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 03, 2009 | Kenmore Dryers
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
