Question about Maytag Performa PAV2200
Performa draws 20A on wash cycle and motor trips out
  • Maytag Master
  • 12,061 Answers
WoW if it is drawing THAT ,much current then you have a serious issue, 20Amps means that there is almost a Short Circuit, It works out to 5.6 Ohms, 112V/20A=5.6 Ohms. This is WAY too little a Load. Please be careful. In all honesty I think you should get it looked at by a professional.
Posted on Feb 08, 2010
Holiday Tradition Express starts to run but seems to trip out and stop. Could this be a problem with the electronic board? Does anyone repair these boards?
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run additional loads.
if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
By the way my advice is free cuz God is good!
Jan 03, 2017 | Washing Machines
Direct drive whirlpool washer has electrical odor and stops.
the burn odour and stoppage an electrical fault and coupled with a 20 amp circuit breaker tripping indicates a motor fault
Capacitors are tested with an capacitance tester and not an ohm meter as ohms is a resistance and not capacitance reading
When breakers activate it indicates a massive short or current draw and the problem could be in the windings of the motor
could be water getting into the motor at times causing the intermittent problem
I would suggest that you call in a service technician or an accredited electrician to check out the machine properly
Jan 20, 2016 | Whirlpool Washing Machines
When put on a wash it trips the electric
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
May 10, 2015 | Miele Washing Machines
Ground fault keeps tripping
Mar 17, 2015 | Washing Machines
I got 2 wascomat gen5 that trips breakers only on rinse cycle
Why does my washing machine trip the electric
run the machine, after it trips, unplug and carefully touch the motor,it may have a bad capacitor, or dry bearings causing it to draw excessive current,if these 2 things are not it, then look for a bare wire that may be touching case during this part of the cycle,and if you can get an "Amprobe" it reads current and check machines current draw during the start to trip current
Oct 27, 2009 | Hotpoint WMA58 Front Load Washer
Maytag Performa washer will not drain?
i'd look at replacing the motor that sounds like the prob
Jun 11, 2009 | Maytag Performa PAV2200
Washing machine has high amp draw
yes sounds like your motor is breaking down
Jun 15, 2008 | Washing Machines
Circuit breaker on laundry circuit has started to trip
if the machines are both on the same outlet i would attempt to run them on seperate outlets first to see if it improves. as time lapses breakers or gfi's can weaken and a continous amp draw esp. in the spin and the ignition stage at the same time which are the largest amp draw from either machine at any give time could be causing the issue. if this does not work you need a tech to look at it
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Jun 03, 2008 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
