Question about Dryers
I have a maytag electric dryer that the timer does not move when you turn the dryer on. Dryer will run indefinitely until you open the door.
  • 1,531 Answers
Then you need to replace the timer
Posted on Feb 08, 2010
My maytag atlantis gas dryer will not turn off at the end of the cycle
Dryer will not shut off:
The timer: Located in the control console of the dryer the timer consists of a small motor connected to a series of gears that rotate cams, which turn electric contacts off and on inside the timer. The timer contacts control the dryer motor as well as the heat circuit and the timer motor itself. A defective timer motor or a defect in the timer's electrical contacts can cause the timer motor to fail and the timer will need to be replaced. The contacts can be checked for continuity with a multi-meter. This test should only be made when the dryer is unplugged. Another test u can do is observe by eyesight and see does the timer advance or is it stuck on one cycle?
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
Mar 23, 2016 | Maytag Dryers
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
GE Profile dryer keeps running and timer switch doesn't move
Aug 13, 2014 | Dryers
My dryer recently started staying on indefinitely or until I physically open the door. Is there something I can do to fix it? Is it a timer issue?
Have you tries running the dryer on all the cycles? If you have and it acts the same on all the cycles then it is a bad timer.Best thing to do is set the timer on the timed cycle for about ten minutes and if it doesn't advance then you know the timer needs repalced.
Mar 05, 2011 | Maytag Dryers
The timer doesn't work. The dryer just runs until
is the heat working?when the dryer heats up and then the heat will shut off then the timer advances,when the heat turns back on the timer stops,heat shuts off the timer will move again,if the heat is working you could have a bad timer
Mar 12, 2010 | Frigidaire GLER341A Electric Dryer
Maytag Dryer timer keeps running
I have looked at your dryer schematic. The only thing that moves the timer forward towards the end of cycle is the timer motor. You are going to need a new timer, looks like they have one for 54 bucks HERE
Feb 08, 2010 | Maytag PYE2300AY Electric Dryer
Dryer will not turn off
May 20, 2009 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Timer runs continuously - Does not stop at all
There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
Jan 01, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag dryer PYE3300AYW Continuously runs
jefo, it sounds to me like your timer is not advancing. Does it move at all or stay in place? In what you are saying it will stop when you turn it to off, I would think it could be the timer that is the problem. Part # 53-1810.
May 19, 2006 | Maytag PYE2300AY Electric Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
