Question about Epson Stylus C88 InkJet Photo Printer
Green light out both red lights flashing alternately
  • 63 Answers
If the lights are flashing alternately then this is the Service Maintenance request by the printer. Usually this is related to the ink pads. You will need to change the ink pads and use a SSC utility.
http://www.ssclg.com/epsone.shtml
Posted on Feb 10, 2010
jackboy
  • 2985 Answers
SOURCE: Epson C45(Red and Green light flashing alternately)
The waste ink collector pads are getting full and this is a protection indicator.
Either get the machine serviced or it may be cheaper to replace it-[depending where you live]
There are tricks to keep the machine going- but eventually the you will get ink leaking all over the place.
Take a look at www.fixyourownprinter.com
Posted on Dec 26, 2007
SOURCE: Epson C45(Red and Green light flashing alternately) problem
solution service required epson c45
Posted on Mar 28, 2008
SOURCE: Epson C48 red and green lights flashing alternately
Where is the prtinter nappy diapher
Posted on Aug 27, 2008
munnabhai
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Posted on Sep 21, 2008
gwbm
  • 353 Answers
SOURCE: Epson c46 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C46 Service Manual". You will often find them for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Posted on Feb 11, 2009
I have a pioneer pdp-r05XE, on the plasma, the light flashes green and red alternately whilst on the receiver it flashes green 6 times. I can't get the tv to turn on...
Unplug if you have not done so BOTH units from power for several minutes (any cable or satellite box also connected.
wait several minutes and restore power to all units which may allow them to reboot.
Cannot hurt and may help.
Dec 06, 2012 | Televison & Video
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
Red light keeps coming on and green one keeps flashing
is both light flashing alternately? if yes, it means you need to replace the waste ink pad and reset the waste ink counter...
May 20, 2010 | Epson Stylus C62 InkJet Printer
Lights on printer are alternating between red and green flash
try to reset the printer by opeing the front cover and close it again.
Mar 17, 2009 | Samsung ML-2510 Laser Printer
My printer has two flashing lights
try to rest the printer by opening the front cover (not the paper tray) and closing it again.
How do i disconnect my HBH PV703 Headset from a damaged phone and connect it to another Phone
Step 1 - To reset your Bluetooth headset:
  1. Press and hold down the volume keys "+" and "-" on your headset at the same time, until your hear a beep and the light flashes red and green alternately.
  2. Press and hold down the volume keys on your headset until it is turned off. The headset is now reset as it was when purchased.
Step 2 - To pair the headset with your phone:
  1. Make sure the headset is turned off.
  2. Turn on the Bluetooth function and Bluetooth visibility in your phone (This makes the phone visible to other Bluetooth devices).
  3. Place the phone within 20 cm (8 inches) from the headset.
  4. Press and hold down the call handling key on the headset until it beeps, shows a steady green light and then flashes red and green alternately. If the indicator light only flashes red or green, simultaneously press and hold down both volume keys until the headset beeps and flashes red and green alternately.
  5. If your phone supports auto pairing, press "Yes" when you are asked to add the headset to the phone. If not, check your phone User Guide on how to pair the Bluetooth device. If required, the headset passcode is 0000.
  6. The headset beeps and flashes green when successfully paired.
Jan 21, 2009 | Audio Players & Recorders
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus C88 InkJet Photo Printer Logo
756 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
