Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Washer/dryer wont work independently
Hi All,
I'm having a little problem here and was hoping someone can point me int he right direction. I can not get the dryer or washer to work by it self. In order to use the dryer i would have to put the washer on and then the dryer will kick on. And when i open the washer lid the dryer stops. The same goes for the washer i have to press the start button on the dryer in order for the washer to work. Any ideas? Thanks in Advance-Jerry
  • 2 more comments
  • SailorJerry Feb 22, 2008
    oh yea before i forget its a MAYTAG LSE7806ACE
    There is 220 going to it. It just seems like its acting like everything is in series.
    There is 220v going to it. It just seems like everything is in series. The 220v goes to the dryer side and then the washer is connected through the wire harness on the back.
  • SailorJerry Feb 24, 2008
    bump
    President:
  • Maytag Master
  • 2,651 Answers
You have an electrical problem, sounds like 1 half of your circuit braker has popped youshould be getting 220v. id check ther first
Posted on Feb 22, 2008
I have a code of loc coming on and my dryer wont work how can I fix this issue??
The control panel is locked. on the control panel, there will be either a "lock" button that you hold down for 3-5 seconds to unlock, or it will have "lock" in small letters with a line pointing to 2 of the option buttons. hold the 2 buttons it points to for 3-5 seconds and it will unlock. the control lock is a child safty feature that will not allow any the washer to work until it is unlocked. P.S. to put the control panel into the lock mode, is the same way as you unlock the control panel.
May 29, 2015 | Frigidaire ATF6000ES Front Load Washer
Gas dryer has minimal heat
Not my expertise, but check exhaust vent, making sure it is not clogged, then contact manufacturer for probable causes, maybe burner nozzle is clogged, or gas valve is not functioning properly. Burner nozzle would be first place to start.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Apr 24, 2014 | Amana NGD7200TW Gas Dryer
Whirlpool ite6234d thin twin could someone tell me in detail where the belt is located in the washer?
I can not find your model number that you posted.
I can tell you that all whirpool thin twins up to last year were direct drive with no belt except for the dryer section. Whirlpool stackers from the early eighties did have a washer belt if yours is this old replace the entire machine.
Jun 22, 2017 | Whirlpool LTE6234D Top Load Stacked...
Not sure of year but i have a Maytag Performa, Model #PYE2300AYW and serial # 107-861-51YY..It wont do anything when I press the button to start the dryer it doesnt click anymore. I think it could be some...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 28, 2011 | Dryers
No problem w/5+-yr Neptune washer/dryer pair, they have served us well. But - washer currently hinged on the left/latch on right, dryer hinged on right/latch on left. Of course, the washer hook-up is...
If the doors were interchangeable I would expect that to be a selling point (!) and mentioned in the manuals ;-0)
The problem is that the holes for the hinges, the door catches, the electronics/electrics for the door solenoid and close sensors need to be available already on the other side. On top of those requirements the doors need to be the same internal shape upside down, as they would be upside down if swapped over to the other side.
So sorry, all in all it doesn't look good, does it ;-0(
John C
Apr 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
Hi, I have a Bosch freestanding freezer (GSD14A20GB) and recently defrosted it using a hairdryer, I now know that this was not a good idea as the following occurs when I switch it on: -Freezer appears to...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 04, 2010 | Freezers
Dryer stops midway through cycle and wont restart just beeps
If it was really loaded with int, it may have killed the motor. You could take it apart and thoroughly vacuum it. If that doesn't work, I'm afraid you'll need a motor
Apr 09, 2009 | Kenmore 42822 Front Load Washer
Maytag dryer overheated and won't turn on now
you need to open the top lid. There are two piins that release it(located where the top and front meet) lift it up and you will see the element on the top left, to the right side you will see two WHITE wires, they go to the thermal fuse. You can atach them and then plug the dryer in and see if it starts. When it does, you will need to order the thermal fuse kit.
Before you begin make sure to UNPLUG the dryer!!!!!!
Mar 01, 2009 | Maytag PYE2300AY Electric Dryer
My candy cmd 146 washer dryer
yes, 2 of them. front of the aly trunking on top of the drum. just press the little ceramic centers and it will work again, done mine 3 or 4 times now, bit annoying to be honest lol
Sep 11, 2008 | Candy CN146 Front Load Washer
No power
Thanks for your email. The problem was fixed, the main power board had been affected. Checked for spares and found they were available on line but the mark up prices independents were charging meant that a new machine was the only option.( It would also take 21 days to deliver) However on contacting Miele direct they were extremely happy to send us the part at half the lowest price that the independent were quoting. Their parts dept also checked that we wre ordering the right part.They were very thorough and patient and confirmed that the powerboard would take only 3 days to send. Thanks
Aug 19, 2008 | Miele WT945 Front Load Washer / Dryer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
130 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
