Question about Kenmore Dryers
Dryer produced no hot air - Kenmore Dryers
  • 56 Answers
Many parts in the dryer can cause this however the easiest to check is you house circuit breaker or fuse. a dryer needs 240v to run the heat and if one side (120v) blows it will still run but without heat
Posted on Feb 08, 2010
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
My Estate dryer is putting marks on my clothes that almost look like burns. With stain solution I can usually get them out but it's happening with every load now, what could be causing this? It h
Oct 02, 2012 | Estate Dryers
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
Sep 28, 2012 | Fisher and Paykel Dryers
I have a Roper Dryer Model #REX3514PQ0 and it's about 5 or six years old. I was drying my laundry. The first load dryed fine. One the second load I notice that the setting nob up top was not moving and...
What I would do is pull the dryer out and unplug the power cord. I would remove the rear cover and check the components back there for continuity.f08dda1.jpg83a4f65.jpg15ccca9.jpgIf all of that is good then the timer or breaker might be bad. Why? The timer calls for heat through the RH leg. The amp draw from the heating element arcs up the contact point inside the timer. The motor runs on 120 volts the heater runs on 240 volts. So the breaker will take a beating on the heater side of it. The dryer will hower still run. To recap It could be the heater the limits the time or an electrical problem.6db32c2.jpga2de035.jpg
Rate it or Hate it:
Jul 15, 2010 | Roper Dryers
The dryer will not produce heat and blowing lint
check where your dryer vent goes through your outside wall they sometimes clog up with lint and cause the escaping heat to recirculate back to your dryer causing the sensor to read the dryer as too hot clear all lint from the outside vent so you can feel the air coming out very steadily and quickly If this works you are all set otherwise check your heating element
Jan 04, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
No hot air is being produced from my Zanussi TC 180 condenser dry
what make is it?is it a top lint screen or inside?
Mar 31, 2009 | Dryers
Dryer works but no hot air
Hello, if it's an electric dryer and you have absolutely no hot air, then it's either the heating element or the thermal cut-off, most likely.
The thermal cut-off is the fuse on the element's housing.
Check both for continuity. Good luck :)
Please feel free to keep emailing me if you'd like.
Nov 18, 2008 | Whirlpool LEW0050P Electric Dryer
Dryers Logo
47 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
