Question about HP Business Inkjet 1000 - Printer - colour - ink-jet - Legal - 1200 dpi x 1200 dpi - up to 23 ppm (m...
HP BIJ 1000 - Reliability and Performance
I have several HP Business InkJet 1000's that I have to test to ensure they work before I send them out to clients.
Last week I tested 5 or 6 and noted which ones were working ok, this week I have tested them again and found that some of the them are not working.
I simply tested by installing printer on my PC and printing a test page, for some reason printers that worked fine a week ago give me perisistant problems, most problems revolve around cartridges and pritn heads, they all install ok, but sometimes they print badly, other times they continue to flash lights and don't print.
Is there any known issue with the BiJ 1000 that would cause such problems?
Any help would be appreciated
Regards
Martin Parsons
Technical Analyst
Cegedim Dendrite Ltd
  • charliehagie Apr 29, 2008
    HP Business Inkjet 1000 Printer prints the first copy perfectly. Slowly as you print the ink gets lighter on the subsequent copies ie: ink starvation. 4 test pages and the copy is illegible. Wait 10 or 15mins and print again the process repeats itself. It's as though the ink flow does not flow strongly enough to keep the flow of ink consistent. This problem occurs on one printer on the cyan colour and the other printer on the black. The printers have run well for 3 years and heads have only been changed once after 2 years. The are no faulty light indicators on the LED panel. Any ideas what could cause this fault
I have the exact same problem. 1 Page okay, then ****.
Posted on May 01, 2008
  • jamescase13 May 01, 2008
    I do too, HATE it, I threw away two 1100 and on my 3rd!!! 1000, its a joke...beginning to think there cheap garbage like epsons c84, remember that junk? I would go though epsons faster then the ink cartridge!!!
    HP TIP Take out the failed cart and pump up the black rubber thingy on the bottom 5 pumps. reinstall and try again.
Error code 0x610000f6.. would this be related to refiled cartridges
Hi paschal karl
The error code you are seeing may or may not have to do with the cartridges being refilled.
Here's the thing, yes, you can refill your cartridges or use re manufactured cartridges, but you may run into problems.
QualityLogic, one of the world's foremost quality assurance organizations, tested the performance of HP inkjet print cartridges vs. re manufactured (refilled) brands. The results: original HP inkjet print cartridges far surpassed ink refills in both print quality and reliability.
  • Nearly one out of every six refilled ink cartridges tested was dead on arrival or failed prematurely
  • 70% of refilled cartridges had some form of reliability problem
Count on HP original ink cartridges for consistent, worry-free printing. You may think you're saving money on re manufactured or refilled ink cartridges, but in the long run, the cost of wasted time, ink, and paper can more than make up the difference. -Source
Most people think, 'well of course that is what HP or an HP representative would say', but I have done some research and found that many others have too. Here is a perfect example of somebody who does not work for HP in any way and basically is a customer advocate (in my opinion) ;Should you refill your printer's ink cartridges? HP says no (of course) By Matthew Murray
I found the above article interesting and genuine.
To summarize, again, yes you can refill the cartridges. The printer is not programmed to reject them. Sometimes the cartridges will not work and of course because they are non HP, HP would not be able to do anything to help. HP cartridges have a 2 year manufacture warranty;Limited Warranty for HP Ink Cartridges and Customer-Replaceable Printheads for HP Inkjet Supplies, this may give you comfort knowing HP stand behind their product.
Perhaps you will find the following document helpful:
HP Printers Problem with Printhead Printer Failure Ink System Failure or...
I hope this helps.
I work on behalf of HP.
Jun 23, 2015 | HP Photosmart 7520 All-in-One Color Inkjet...
Printer Error Message
Yes, there a few items you need to consider with respect to HP 61 (or 61XL) cartridge errors messages on any HP Deskjet 1000 through 3510 printer model:
If you get an HP 61 / 61XL integrated ink cartridge refilled (i.e. currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore ink low, non-genuine, counterfeit messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of this low ink phenomena.
If the new (or refilled/reman/compatible) HP 61 / 61XL ink cartridge refuses to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance. Ensure you press OK or Cancel up to six times to clear out the printer error log.
These types of severe cartridge errors (i.e. Incompatible cartridges, Black/Color cartridge(s) problem / Cartridge not intended for this printer, etc.) typically indicate the internal micro-electronics of the HP 61 cartridge are electrically damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you run a Tap 41 diagnostic test to check cartridges electrical health (this is a forced service test so the printer will attempt to send whether cartridges are good or not); Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings:
http://www.youtube.com/watch?v=BskAfa6NJSg
HP Deskjet 1000-3056 Printer Models -- HP 61 Ink Cartridges Tap 41 Diagnostics Test
http://www.youtube.com/watch?v=tMZkqE36ifk
Aug 24, 2012 | HP Deskjet 3052A Wireless e-All-in-One...
I have hp deskjet 1000 printer. when i replace blk/white cartidge the printing work didn,t complette. somebody tell me check your printer nozzle and clean it . but i didn,t find the nozzle button anywhere....
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken.
Thank you for using Fixya
Sep 23, 2011 | HP Business Inkjet 1000 Printer
Whats the paper out symbol mean??? in hp business inkjet 1000
Exactly what it says - the paper supply in the printer is out. Add more paper.
Aug 01, 2010 | HP Business Inkjet 1000 - Printer - colour...
Trouble with HP Business InkJet 1000
ur check all the sensor one bye one indivisual in dislpay scareen error code are different .mpost probablity this error front cover.
Jan 19, 2009 | HP Business Inkjet 1000 - Printer - colour...
How to reconfigure ink cartridge
Change your system date to backward and you can use it again
Oct 23, 2008 | HP Business Inkjet 1000 - Printer - colour...
HP HP Business Inkjet 1000
If the printer is new, then maybe the printer catridge nozzle seals have not been removed and so the catridges are not being detected.
If it has been working before and then the problem starts, look at which light is blinking  because the paper and catridge lights are different. So check wich light is on and get to me for further instructions.
thnx
Jul 31, 2008 | HP Business Inkjet 1000 - Printer - colour...
HP Business Inkjet 1000 error detecting new cartridge
Disconnect the communication cable (USB?).
Turn off the printer, wait one minute then turn it back on,
Then press the left button on the panel, the transparent one to the left of power button. It will print a status page. Check the dates and information under each color that is failing.
The ink cartridges MAY be outdated. Printing the test and information page without the computer connected fools the machine since it can't get your computer date.
If the cartridges are outdated, then change your computer year back to 2005 or so, reconnect the printer cable and send something to print, once the printer prints it out, reset your computer to today's year.
You will need to do this procedure whenever you turns off the printer. (Disconnect cable, change computer year, print, reset computer date).
Hope this works.
Wagner
Feb 20, 2008 | Canon Pixma iP6600D InkJet Photo Printer
HP Business Inkjet 1000 - Printer - colour - ink-jet - Legal - 1200 dpi x 1200 dpi - up to 23 ppm (m... Logo
332 people viewed this question
Seeker5211
Seeker5211
