Question about Sony VAIO VGN-NR430E/S NoteBook
I have a Sony VGN NR430D/S and after a year's use, the laptop will not boot or start when the power button is pressed. It started when after I used it, I clicked on the SLEEP button instead of switch off or power off on the VISTA OS. Is this an electronics or software issue. Is there a workable solution for this now?
  • Colin May 11, 2010
    More info Does it startup when powered completely off, if so then disable the sleep mode in control panel / power options, change all settings to "always on"
  • 733 Answers
Remove the battery and press and hold the power button for 10 seconds. put the battery back in and try to start it. if it still won't boot up, it may be a hardware issue.
Posted on Feb 08, 2010
I have vgnnr430d. it appear to me that: the file is possibly corrupt. the file header checksum does not much computed checksum
Posted on Mar 04, 2010
How do I access the boot menu at startup, Sony vaio vgn cr190 Win XP?
You can either try to spam the F12 button upon start-up to directly select which device to boot from, or either F4 or Delete are the typical keys used to get into the BIOS and you can change the boot order from there to automatically select a CD drive device if it ever detects one.
May 04, 2014 | Sony A1246282A - VAIO VGN-N Series Laptop...
Sony VGN-FW41E not starting...
Power supply in the laptop may have went bad
Aug 27, 2012 | Computers & Internet
Hi, I have a sony vaio vgn-fw265d and the last time I used it I put it to sleep but didn't connect it to any power source so the battery drained out. When I tried turning it back on, the light switched on...
Remove the battery and try to start it up with the AC power. If it's not working, after you try to boot up and the lights are on, press the power button for several seconds (10-15) and it should go off. Press the power button again and it should start.
May 02, 2011 | Sony VAIO Notebook
Sony vaio vgn-fj270 bios wont boot, just display [Be-$]Be-$
try to turn off the laptop. Remove cables and battery then press and hold the power button for 8 secs. Then reinsert the cables and battery on the laptop. Turn on the laptop. Check if the BIOS screen appears. If it is still wont boot to windows, try to restart the pc and repeatedly press F8 to Boot to safe mode. If unsuccessful, this might be a problem with the memory of your laptop. If you cannot tear down the laptop, consult a technician to tear it down and reseat the memory .. or better call your manufacturer to repair it...
Jan 05, 2011 | Sony VAIO VGN-FJ270/B Notebook
Sony Vaio VGN SZ491N doesn't start or boot. No lights no noises. Tried holding start button 10 seconds, tested power supplies (OK on other machines), been having a problem with the battery being loose...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. The DC jack might be loose or broken. It might need to be either re-soldered or replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Sep 17, 2010 | Sony VAIO VGN-FS980 Notebook
Sony vaio vgn-fs8900p isn't booting
Most likely your hard drive has gone bad. It could be your RAM too. I know that you said you checked your ram one stick at a time. What if both sticks are bad? I would get some cheap (low MBs) sticks of ram that are compatible with your computer to see if your computer will start to run right with those in.
May 20, 2010 | Sony VAIO VGN-FS8900 Notebook
Laptop will not boot, Sony Vaio VGN CR220E, lights come on, don't hear the Hard drive start up, however. I get the clunks from the CD drive, but that's all.
Such problems happen when you have either faulty RAM or faulty Mother Board. Repairing MotherBoard Chip is a costly affair but replacing RAM is convenient and most probable solution.
With Regards,
Ankit
Oct 08, 2009 | Sony VAIO VGN-CR220E/P Notebook
Sony Laptop wont power ON
Try booting it from your CD drive.
Any messages on the screen ? any lights on??
Aug 26, 2009 | Sony VAIO PCG-K35 Notebook
No screen and no sound but i can hear the fan and processors sound in the back
Hi dheerendra let me know the display massage when you are start your system by pressing the power key. let me know are you able to boot the system or not. Try to put windows xp bootable cd in drive and choose boot from cdro option in cmos setup. when setup is started then choose repair option.
Jun 26, 2007 | Sony VAIO VGN-SZ460N/C Notebook
Sony VAIO VGN-NR430E/S NoteBook Logo
917 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
