HDD & DVD PLAYER/RECORDER / time date
AFTER SETTING TIME / DATE ect and preset no problem (24 hr)
after turning the recorder off at night time at wall plug, it will not hold it's time/date have to reset when turning back on
is this normal ?
or will i have to leave it on standby all the time ?
thanking you
    Genius:
  • 1,019 Answers
Is there an option To Save Settings, after setting the time-date ?
Most devices usually have a small internal battery or memory chip that stores this information. however there are also devices that when power is removed completely. i.e a power failure or switched off at the mains, time and date settings have to be reset.
Hope this solves your problem.
Mike @ Compurepair.
Posted on Feb 22, 2008
LG HDD RECORDING WONT STOP
Did you try to contact LG support?
Nov 19, 2015 | LG RH1999H DVD Recorder/HDD Recorder
How do you set the clock
Hello
To set the clock to your SV-dvd 3E:
Your DVD-VCR contains a 24-hour clock and calendar used to:
Automatically stop programme recording
Preset your DVD-VCR to record a programme
automatically
You must set the date and time when:
You purchase the DVD-VCR
Do not forget to reset the time when you change
clocks from winter to summer time and vice versa
[1] Press SETUP on the remote control.
Result: The MAIN MENU is displayed
[2] Press the corresponding up/down button or Forward/Reverse buttons to select the
CLOCK SET option.
[3] Press the ENTER button to select this option.
Result: The CLOCK SET menu is displayed
[4] Press Reverse or Forward button to select the hour, minutes, day, month and year.
Result: The option selected flashes
[5] Press the Up/Down buttons to increase or decrease the value.
Result: The day of the week is displayed automatically
You can hold the Up/Down buttons down to scroll more
quickly through the values
[6] On completion, press RETURN twice to exit the menu
OK.
Oct 10, 2011 | Samsung SV-DVD3E DVD Player/VCR
WHEN I PRESET THE VCR TO RECORD MY SHOW LAST NIGHT 8:00PM IT WOULDNT WORK THE RECORD LIGHT DID NOT COME ON AT THAT TIME
There are a few things you must do in order to program a recording. One, you must make sure that the vcr clock is set. Two, the vcr must be set on the right date, as does the recording. Three, make sure that the daylight savings, AM/PM, etc. settings are saved accordingly. Also, if you have the operating manual for the vcr, you could check it for exact program instructions. I hope this helps, and I wish you the best of luck! Sincerely, Der Strom
Apr 13, 2010 | Philips Magnavox DVD/VCR Dual Player
I have the polaroid dra-01601a dvd/hdd audio
First of all with all do respect I do not have the polaroid drm 2001G. I have as I exprest in my letter to you the polaroid dra 01601A. The problem i had was an audio problem and i simply rechecked all my connections and found that I needed and extra set for HDMI plugs on my TV.
Jan 03, 2010 | Polaroid DRM-2001G DVD Recorder/HDD...
Setting the time to 12hr instead of 24hr
according to my manual there isn't an option for 12 hour settings only the 24. I know, it's pretty dumb!
Mar 25, 2009 | Protron PD-DVR100 DVD Recorder
Audio is out
Hi, try this:
Reset the whole machine by doing the following (this will not erase your HDD by the way):
1. Turn off at wall for 5 minutes
2. Turn back on at wall WHILE holding the standby/on button on the front until the front panel display goes black.  The recorder should then be left for a few minutes and then turn it on on remote, when the machine should prompt for language, time and date and work normally again!
Dec 31, 2008 | Philips DVDR520H DVD Player/HDD
Recording
check time clock and did you push the power button off?
Oct 11, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Recording Late
Check your automatic clock setting. If it is on automatic, set it to manual, and set the date and time on the recorder. It may be picking up an unreliable time setting from a station that is not too accurate.
tom
Aug 26, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Setting the time
Go to Settings ---> date and time
Set date format: MM/DD/YY or DD/MM/YY
Set date: Day / Month / Year
Set time format: 12 Hr / 24 Hr
Set time: Hour / Minute / Second
Feb 27, 2008 | Philips GOGEAR SA6045 MP3 Player
LG DBRH197
Read the timer record troubleshooting suggestions - timer record will only start is the unit is turned off!
Jul 03, 2007 | LG DBRH197H DVD Player/HDD Recorder
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
