Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
OFF/ON KEEPS TURNING OFF AND ON AS IF YOU ARE PLUGING IT AND UN- PLUGING IT
    President:
  • 2,923 Answers
There are several reasons why this is happening. It could be any of the following:
Inverter board - a device that converts direct current to alternating current. A circuit to convert one DC voltage to another by INVERTING the input DC to AC, running thru a transformer, rectifier, regulator to output the new DC voltage. When used in context as an "inverter board" it refers to the backlight of an LCD screen. It is the board(s) that the backlight(s) is mounted on.
Voltage Regulator - the voltage regulator usually placed on the power supply board of the projection or LCD TV. The voltage regulator is responsible in supplying high or low voltage.
One of these components is bad that's why the TV keeps turning ON and OFF. You need to contact a local repair tech for repair.
Good luck and have a good evening!
Posted on Feb 08, 2010
I have a 1965 suzuki k15. i lost the keys and need a wiring diagram so that i can bypass the ignition, but still make everything on the bike work. Any help would be greatly appriciated.
all the key does is add an extra path to ground for ignition and charging the coil as 3 black wires take plug out leave pluged in kick over pluging and un pluging one wire out of the connector till you see spark then simply repeat for lights look for lamp to come on while running when unpluging a wire if not it unplug try another theres very few wires should be a quick process
Mar 31, 2011 | Suzuki ST 250 Motorcycles
I'm trying to delete a print job and the job will not delete. I can not uninstall the printer software and reinstall it because the job is still trying to delete and un pluging it didnt work either. I...
Try turning off BOTH the printer and computer and unplugging the printer from the PC. Reboot PC and printer, then plug the printer to the PC. This should delete any remaining print jobs.
Jan 14, 2011 | Lexmark X2650 All-In-One InkJet Printer
My wii keeps turning off
SOMEONE KEEPS PLUGING IT OUT ON YOU
Jul 02, 2010 | Nintendo Wii Console
I wrote a essay and every time I print it I get a blank paper
it has to do with your ink or printer i had to take mine black try to reset it by un pluging it then re pluging it then take out the ink then put it back in then you should be good to go let me know if any other plroblms occur
Jan 13, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Water keeps filling up washing cycle does not start
hose off water level switch or switch bad. if water comes in even after un pluging from wall valve is bad
Dec 31, 2009 | Whirlpool Washing Machines
I'd like to disable the OEM alarm. It keeps going off and the battery dies
simple just un plug it its brain has got scrambled try pluging it back in after 1hour it should work ok i hope
Nov 13, 2009 | 1994 Jeep Grand Cherokee
How do I repair/replace CD player on 2002 Grand Am Se
I have a 2001 i think they are the same. Just stick your thumb in the cigaret ligher hole and pull hard it should pop off the cover. make shure car is off and key is out. then with cover off stick the key in and turn it on. Put car in 1irst gear then that should b anof space to take it complete out after un pluging ets and flashers and cigrat lighter.make shure hand brake is up. then u can go from there just unscrew the radio and un plug it. it is hard to un plug it.
Oct 20, 2009 | 2002 Pontiac Grand Am
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
