Question about Car Audio & Video
I need the wiring connections for a Craig amp #V501
I need the wiring connections for a ''Craig'' Powerplay 24 watt amplifier #V501. There is a red wire and a red/white wire. I know where the other wires connect,but not sure about the red ones.Thanks
  • 47 Answers
THE SOLID RED IS USEUALLY UR POWER NOT SURE ABOUT RED WHITE WIRE ON AN AMP THATS A FIRST FOR ME AND IVE DONE LOTS AND LOTS OF CAR AUDIO INSTALLS
Posted on Feb 28, 2010
I need to reset a power amplifier. i have a 250 watt power amplifier from radio shack. i thtink that one of the wires touched or someething either that or the power was on for too long. but now the p
One important note to be aware of Polarity. DC connections are Positive + and Negative -. RED/Black and/or White wires. Yellow is usually Video. Do not Reverse the polarity as this can cause mismatches and/or short circuits. Disconnect your attached wires and re-attach them correctly and firmly. Wires must be set into or onto the posts or connection points correctly by + or - and they may not touch one another. Check the Reset or Fuse on the amp and make certain you have full power.
If you fail to polarize correctly, you could damage the speakers moreso than the Amp.
Jan 07, 2014 | Radio Shack 250 Watt PA Amplifier...
How to wire the tuner and amp what wires do i need to get it to work
In most cases, you need a pair of Red/White RCA cables. Connect one set of ends (1 red + 1 white) to the external tuner's output and the other (white + red) to the input on the Amp.
Then you need double stranded wire to connect the speakers to the amp. one x double stranded wire for each speaker. You can use electrical cord from the hardware store (e.g. 18 gauge wire) or you can buy some speaker wire (16 to 20 gauge - use lower number wire (thicker) for higher power amp). 16 to 18 gauge wire for a 100 watt per channel amp if your speakers are less than 15 feet from the amp (wires are less than 15 feet long). If longer than 15 feet, use the 16 gauge wire. You can use 18 gauge for most anything else.
Jun 20, 2011 | Kenwood Audio Players & Recorders
Hello Fixya Guru ! I am in the process of installing several Marley PLF series 2000 watt/ 240 volt electric "Hydronic" baseboard heaters. I am using 10/3 bx with a 30amp breaker. To my...
You are correct that these heaters use a two-wire 240 volt supply, and the neutral is not needed.
2000 watts = 240 volt x Amps ==> Amps = 8.3 amps
30 amps x .8 safety factor = 24 amps
24 amps / 8.3 amps = 2.9 heaters per 30 amp breaker (3 heaters should be okay)
More info, pls let me know.
Charlie
P.S. Where does the 2880-watt number come from ?
P.P.S. There has to be a ground bus-bar in the panel -- if it's a main panel (not a sub-panel) the ground buss and the neutral buss are connected in the panel. Could you clarify what you have in the panel.
Jan 11, 2011 | Fahrenheat Electric Convector Baseboard...
I have a craig powerplay amplifier model # V 502 48 watt. i need wiring schematic.can you help ?
From left to right your connections will be as follows:
BATT: 1x solid (at least 4mm in thickness) wire directly connected to your car battery positive(+).
GND: Will be an earth wire of the same thickness connected to any section on your vehicles body (chassis). Even a seatbelt bolt will do.
P.CON(REMOTE) will be the remote wire coming from your radio (normally blue or orange in colour).
The speaker connections are pretty straight forward unless you are going to connect subwoofers.
At the back:
FILTER: leave off unless you are going to run subwoofers
OPERATION: Leave it on sterio unless you are going to run subwoofers
LINE IN: Will be RCA cables coming from your radio
SPEAKER LEVEL INPUT: is for connection if your radio does not support RCA jacks
Please feel free to ask about anything you are unsure about. I hope this helps and solves your problem
May 20, 2010 | Kenwood KAC-5201 Car Audio Amplifier
Subs wont pound
could be the wiring or not enough power getting to the amp or check your grounds
Sep 18, 2009 | Pioneer GM-7200M Car Audio Amplifier
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Metrik mac-505
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
May 08, 2008 | Power Acoustik LT-980/2 Car Audio...
How to set up an intigrated amp to a 100 watt reciever
audio connection must have matching in audio level and symetrical.
1-prepare your connection cabels(better to be colour marked at connector(red for right channel- white for left chanel).
2-take pre amp right out to power amlifier right in.
3-take pre amp left out to power amplifier left in.
4-connect amplifier right out to right loudspeaker.
5-connect amplifier left out to left speaker.
6-adjust volume level and enjoyyy.
Feb 26, 2008 | Audio Players & Recorders
VR 200 Watt amp
Disconnect the wire from the remote turn-on terminal of the amp and insulate it so that is can not make contact with anything.
With the wire disconnected, does the amp remain on?
Jan 03, 2008 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Car Audio & Video Logo
188 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
