Question about Motorola Mobility ROKR E8 Cellular Phone
My MOTOROKR E8 is not getting switched on. If I connect it to the power, it says charging. Once I disconnect from power plug it is dead.
I will assume the issue is the power switch. My phone did the same once and it took me a long time to work around the fault. If yours is having the same issue, hold the power switch toward the on position but not quite all the way. Maintain it there for several seconds and see if it powers on. Try various positions until it works. Ensure the phone is plugged to its charger the entire time. Good luck!
Posted on Feb 12, 2010
What the code for full reset motorola e8 ?
To Full reset it...You also Unlock the Mobile...You can get the Unlock code at reliable cost here
http://www.theunlockspot.com/motorola-motorokr-e8/rs10wp9/ and Unlock it.............
Nov 10, 2010 | Motorola Mobility ROKR E8 Cellular Phone
On my motorokr s9 the green light just stay on even when I don't charge it is there a reset button or anything?
This is caused by a power surge. To correct, plug your headset into charge, and then plug into power strip. Trip the switch on the power strip to off. It will cause a drain and turn off your green light and then allow the headset to turn back on.
May 06, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
How to install themes in moto rokr e8
which would be the best site for skins or themes for MOTOROKR E8 please help. I hope u will THANKS!!! :-)
Apr 04, 2010 | Motorola Mobility ROKR E8 Cellular Phone
Motorokr e8 phone is not functioning (not even switching on)
try replacing the battery or the charger appliances
Dec 10, 2009 | Motorola Cell Phones
Unable to play you tube videos on motorokr e8, did wap settings manually! help
You cannot stream videos on Motorokr as you have WAP service. I have a GPRS service and I use video streaming easily.
Nov 08, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Orange light when I charge my MotoRokr E8!
Kevin you must try charging it with the wall-charger, if that doesn't works, try entering BL mode by pressing # and *, and then pull the trigger to turn it on.
It will tell you that battery is low, you can connect then the charger, pull the trigger again, it should start normally.
Jun 22, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Your Problem: I changed my language settings on my Motorokr E8 to an asian language and i cannot change it back
first of all press the top most right button, then using the scroll go inside the settings icon . the settings icon will have a wheel made on it, then select the top most icon n then select the 7th option in tht select the language
May 05, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Once i charge my phone i get a yellow light rather than green.
Leave it plugged in for a little while. When it's yellow it means that your phone is dead and it's charging up the battery. It will eventually turn on and the light will turn green.
May 03, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Motorola Mobility ROKR E8 Cellular Phone Logo
153 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
