Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
We set self clean mode at 9am and its now 730pm and oven is off and cool but door wont unlock and fan wont shuttoff
I had set the oven to clean and my husband came into the kitchen and thought is was on bake and turned it off. I tired to put it on clean again and it would not clean. He tried to set it on bake and the door won't close or the oven heat. How do we reset all of this. Thanks,
Posted on Feb 08, 2010
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
Self cleaning lock handle does not unlock
Unplug power, wait one hower and plug cord back.
That should reset the oven, if it does not, the oven timer control is clearly defective and should be replaced , you find parts here.
Oct 08, 2008 | Thermador Ovens
Door wont unlock
I did that once and had luck unplugging and used a ice cold cloth to cool down the lock handle until it unlocked. Just try not to cook a turkey in the cleaning mode without the fire departments phone number handy.
Nov 23, 2011 | Ovens
After the self cleaning was complete; my oven door will not open and is stuck in the locked mode with the cooling fan running. I've unplugged it and let it sit a couple of hours, but when I plug it back...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Oct 18, 2010 | Sharp KB3300JS Stainless Steel Electric...
Frigidaire wall oven fan running - door will not unlock
the fan will run untill the oven cools. if it dont shut off you need to shut down power for ten mineuts the reset if still runs you shuold call for service
Mar 22, 2010 | Ovens
My oven is locked and wont open. it is cold and wont unlock
Hi
Thanks for using FixYa. The locking of the oven is a safety measure while self clean function is activated. Once the oven has completed the cycle & has cooled down, then it will reset the door lock.
If a self clean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition or you were not using the self clean cycle, then, the lock must usually be accessed and moved manually to open the door—
In order to open the door you have to open the control panel and remove the door lock.
Remove the three screws from the bottom of the control panel. You'll heed a 1/4" open wrench. Pull the bottom of the control panel toward yourself and push it up to release from the upper tabs.
The door lock is secured by the three screws.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 25, 2009 | Maytag MER5775Q Electric Kitchen Range
After canceling self cleaning on my GE Hotpoint oven, I was able to unlock the door and open the oven door. When I try to use the broil or bake feature it keeps saying "un lock dor" The door is not lock...
You will need to allow oven to cool, the temperature is one thousand degrees plus while the oven is cleaning. Until the oven cools it will not open, this is a safety caution. If it will not open after it is totally cooled, it may be stuck, try pushing on the door or pulling it out a bit while trying to move the lever.
Always consult the owners manual when using the cleaning mode on your oven. Be sure it is fully cooled before cleaning any residue out of oven area.
Jan 28, 2009 | Kitchen Ranges
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
GE self cleaning radiant oven - model JB578GP
I went out to my circuit breakers and turned the circuit off, let the oven cool, and powered it back up after about 2 hours. Fine now.
Feb 17, 2008 | GE Profile JT912 Electric Single Oven
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
153 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
