Question about iRiver H10 MP3 Player
Iriver H10 I have a iriver H10 . It has frozen on USB Busy Do not connect. I have tried to reset it but that won't work . Thanks Dean
  • 8,596 Answers
Make sure the hold/lock is not enagaged - check user manual for details.
Then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 30, 2008
Have an iriver H10 - i turn it on and i get this message. " System files missing. To restore the system files, connect H10 to iriver plus" I did this and nothing worked? Can u help?
upgrade the firmware of your device follow this... How to upgrade firmware
1. Download the zipped file for your region.
2. Unzip the file and you will see *.exe file.
3. Connect your H10 to PC via provided USB cable and power on H10.
4. Once the device is ready, run the *.exe. It will automatically copy the firmware to your H10.
5. The progress bar copying firmware will be shown and your H10 device will give you 'Busy' message.
6. Once it's done, it will give you 'Upgrade Complete' message.
7. Please disconnect H10 with 'Safely Remove Hardware' option on your PC task bar.
8. Turn on the power of H10, go to 'Settings -> Extra ->Firmware Upgrade' and select 'Yes'.
9. Your H10 device will shut off automatically once the firmware upgrade is complete.
http://211.39.137.201//download.asp?filename=H10_5G6G_UMSUpdate(EU)_v203.zip&filepath=/file/Down/
http://211.39.137.201//download.asp?filename=H10_5G6G_UMSUpdate_v203.zip&filepath=/file/Down/
Jun 06, 2010 | iRiver H10 MP3 Player
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Pc doesnt recognize iriver ipod
first of all iriver is not an ipod
try to download the driver named iriverplus that shuld work
Jan 29, 2009 | iRiver H10 MP3 Player
Iriver h10 20gb not recognized in UMS
I sometimes have to reset my iRiver in order for my Mac to see it. I have an h10 5gb, to do this, I have to remove the battery then reconnect the battery. Then I connect it the usual way to get into the UMS mode. But I think with yours it has it's own reset button. If it was working and now has stopped, I would think you just need to reset it and try again.
Oct 10, 2008 | iRiver H10 MP3 Player
Iriver h 10 mp3
OK, one day i turned on mu iriver and it's say's "system file missing to restore the system files connect to H10 to iriver and i dont know how to connect it.The other proplem when playing the music it's like a scratch CD i dont know how to fix it.
Sep 25, 2008 | iRiver H10 MP3 Player
REPAIR OF IRIVER H10 20G
Try rebooting the little hole next to the lock with a pen or something similar mine works everytime
Nov 16, 2007 | iRiver H10 MP3 Player
IRiver H10
You have all posted different issues into one forum - bad idea.
For the laptop people - many laptops have USB ports that do not have enough power to drive/charge an Mp3 player - must use USB 2.0 ports.
"HD Audio Bus" guy - go here for the missing driver: Go to Microsoft's own site, and try the hotfix/driver:
http://support.microsoft.com/kb/835221
Woest - Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Nov 15, 2007 | iRiver H10 MP3 Player
Iriver H10 20GB
Simple reset should do the trick - remove and reinsert the battery.
If the problem persists, check the iRiver website for a firmware upgrade - their site is not the most user-friendly but it is CHOCK FULL of information.
Here's the link to the manual:
http://www.iriver.com/support/down_view.asp?searchProductIdx=61&searchCategoryIdx=2&searchString=&page=1&idx=710&tmpSearchProductIdx=&tmpSearchCategoryIdx=&tmpSearchString=
Nov 12, 2007 | iRiver H10 MP3 Player
I fixed this problem for my mate, here's what I did:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Mike.
Sep 21, 2007 | iRiver H10 MP3 Player
IRiver H10 20 GB
Hi Vera I am using windows2000 OS, can not yet justify a faster Pc to run XP .. following is what I use to load and manage my MP3 audio files on my H10 20GB >using an alternative to WMP 10, I use 'EasyH10' .. prepares an H10 player without iriver plus or Windows Media Player 10 based on music and playlist files transferred manually using windows Explorer easyh10-15.exe Info re Easy_H10 URL http://www.misticriver.net/wiki/index.php/Easy_H10 URL http://sourceforge.net/project/showfiles.php?group_id=138812&package_id=152796 download 'easyh10-1.5_win32gui.zip' - connect USB cable between Pc and H10 - place H10 in 'Lock' position - use a tool ( refashioned paper clip ) to press the reset button - start H10 in USB Mass Storage Device Mode... Hold down 'O' button, continue holding 'O' button while you press the 'On / Off ' button until screen displays USB connection, after emergency display - In Windows Explorer locate the ' removable drive' - Transfer your music files with tag information to 'Music' directory on H10 - Run EasyH10 - for Media database construction to display songs in MUSIC mode. - Playlist conversion, a necessary process for your playlist files to become compatible (recognizable) with an H10 player. - EasyH10 also imports/exports tuner presets from/to a text file. Prh
Mar 18, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
424 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
