DVD player and CD player stop reading discs.
I live on a Welsh mountain and it is cold and damp in my room when I am away - which I have been for two months. Neither my CD player nor the DVD player on my computer will recognise they have discs in them - discs that I know work because I have tried them before and after elsewhere. Presumably this is condensation on the lens? How do I fix it?
  • Maes Gwyn Mar 06, 2008
    I tried the hair-dryer on both CD player and computer. Well, the CD player now works fine. But the DVD player on my computer now won't shut its tray. There is s whirring motor noise, but nothing happens. I'm not sure how to rate this one!
  • Maes Gwyn Mar 08, 2008
    Dear Mike,
    I hope that helps! I certainly do appreciate your help and advice, which I realise is given generously at your own expense. I could not get that advice anywhere else that I am aware of.
    So, the DVD on the computer now works. But the CD player has stopped working again.
    I have been back in this place for a month with the heating on and, although it is extremely wet and windy outside, I am quite comfortable in here. Having blow-dried the CD player and left it switched on on the floor, which is underfloor heated, for hours, I put it back on its shelf, which is in the warmest part of the room (no external walls etc). I play some music, switch it off, then a few minutes later switch it on again - and 'no disc'. Is there anything I can do, short of moving to the South of France?
    I promise not to give 'inappropriate' or 'thanks but no thanks'.
    Alex, Maes Gwyn
    Genius:
  • 1,019 Answers
try opening the Drive Trays, and hold a hot air dryer about 2-3 feet away for about 15-20 Minutes, Aim the dryer towards the opened trays. close the trays reboot the computer.
If still not working, i,d suggest putting a laser head cleaner in, and getting some more heat for your House.
Computers do usually tend to function much better at Room Temprature.
Hope this solves your problem.
Mike @ Compurepair.
Posted on Feb 22, 2008
  • Mike Waldron Mar 06, 2008
    If you,d rated it A little Better, I,d have told you how to do that Too. Anyway being the kind of guy i am, and not completely satisfied with the rating, as i feel i solved your Problem.
    Just physically push the DVD Drawer in.
    It,s as simple as That. Just 1 point i,d like to Make.
    The rating system on Fixya, either promotes Or demotes An experts Status. I don,t think users realise This. Too many thanks For trying Or inappropriates, Can make a competant expert look like a complete Novice. as most of the Advice given on here, Is Free and at the expense of the Expert, i.e Time-Knowledge And on-line Time. I think we as experts sharing our knowledge and wisdom Deserve a little More respect. and appreciation from Users.
    p.s good-luck and keep your room at a stable warm-temprature to avoid further problems.
    Mike @ compurepair.
No disc message
1 - Try a different disc.
Either works, or not.
If works, problem original non-playng disc.
If not working, problem is player (or another faulty disc).
2. If player is problem:
Try using a 'head-cleaner' disc (from store).
These usually play whilst cleaning.
If no play - problem is 'read head' in player.
If it plays, then try ( a known good - works in another machine), disc.
3. If 'read head' is faulty, you need a techy to replace, or throw it away, buy a new one (more likely).
Rafe
'Live long and prosper'
Sep 07, 2013 | Craig CVD327 DVD Player
Stopped playing after I inserted damp CD in 200 disc loading mechanism
this can be due to some moisture in lens.
leave the unit to get dry for 2 days.
Jul 04, 2008 | Kenwood DV-5700 Multi-disc DVD Player
It won't play a dvd! and when it does it just sits like it is stopped!!
Hello
Eject the DVD from the Cyberhome DVD player. Look over the bottom of the disc. If any dirt and fingerprints are present, remove them with a damp cloth, moving from the inner circle of the DVD to the outside.
Insert the DVD into a scratch repair device, if the DVD has any light scratches (deep scratches are not reparable). Turn on the DVD repair kit and the device literally sands down the scratch. When this is finished, the DVD should work correctly with the Cyberhome DVD player.
Avoid inserting homemade DVDs into the disc drive. The Cyberhome is not compatible with many self-created DVDs, causing a "Disc Read Error" message to appear on the screen.
Spray compressed air into the disc drive of the DVD player. The compressed air removes dust and other debris from the laser and reading lens in the player.
Apr 25, 2011 | Cyberhome CH-DVD 300 DVD Player
"No disc" error
This means that the lens of your dvd player is having a hard time reading the discs. It could be dirty. You need to run a disc cleaner to run into your player for like 30 seconds. It it does not solve the problem. You might need to clean the lens manually. Open the casing and unscrew the plastice plate covering the lens. Then get a q tip damped in an alcohol. Gently wipe on the lens' surface and let it dry. Return everything back and play those discs again.
Feb 13, 2010 | Daewoo DVG-8500N DVD Player
The DVD power is coming on, but it can't open
Try this, if the dvd player has been left in a damp/cold room, or its dusty the player will display "no disc".
Bring the dvd into va warmer room swtch it on and leave for about 2 hours then try.
Oct 26, 2009 | Philips Audio Players & Recorders
"no disc" message
This usually happens when the player has been sitting inactive for a while.It is caused by dust.The only recommendation is to open the dvd slot and blow into it .
I have the same problem when mine has been inactive for only 2 weeks.
Make sure the room you leave it in isnot cold or damp.
Oct 18, 2009 | Televison & Video
My DVD player has stopped reading any discs
If the player does not play even known working discs (both CD and DVD), you may want to try first to have the lens cleaned out with a disc cleaner which should be available in most DVD stores. If that does not work you may want to open the device if it is out of warranty and inspect the drive and the head. See if the lens is actually moving or may need replacement.
Aug 27, 2009 | Samsung DVD-909 DVD Player
DVD-Player not reading discs.
Well if it happens to every disc, then you know its the discs that are the problem. It should be the DVD player. Check if you plugged in the yellow, white, and red plugs accordingly. And also try blowing inside the DVD player, to blow away any dust that might be fogging the disc from beiing read.
Good Luck!!!! Rate Please!!!!!
Jun 13, 2009 | Philips Televison & Video
The dvd player displays "no disc" sometimes.
In your entertainment center there maybe a very low level vibration interrupting the dvd lasers ability to track the dvd's.You should try using a rubber damping pad under the player or putting noise damping feet on the the player. This should stabillize the player and let the unit work correctly Hope this helps you with your problem.
May 04, 2009 | GE DGE100N DVD Player
Various LG DVD Player
Some models of PIONEER cd players had radio frequency problems that caused them to work on and off. Are you near any radio or braodcast towers? Poorly shielded power supplies cause this as well. A weak laser diode in the pick-up assembly in model runs could be the problem. You might want to Google the model number and see if this is common for these units.
Apr 27, 2007 | LG DK 9411P DVD Player
Televison & Video Logo
653 people viewed this question
Top Televison & Video Experts
Electro Med Services...
