Question about Texas Instruments TI-83 Plus Calculator
I try to graph something and I get invalid dimension. How do I fix that?
  • Texas Instru... Master
  • 8,046 Answers
  1. Press [2nd][Y=] (STATPLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
  3. Press [2nd][0] (CATALOG)
  4. Press [PGRM] (C) to jump to first command that starts with c.
  5. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  6. Calculator displays Done
  7. Start the new problem
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Posted on Feb 08, 2010
What to do when error;invalid DIM shows up on the screen?
INVALID DIM error message may occur
if you are trying to graph a function that does
not involve the stat plot features. The error can
be corrected by turning off the stat plots. To
turn the stat plots off, press 2nd (stat plot) ,and
then select 4:PlotsOff.
• You specified a list dimension as something
other than an integer between 1 and 999.
• You specified a matrix dimension as something
other than an integer between 1 and 99.
• You attempted to invert a matrix that is not
square.
Sep 13, 2014 | Texas Instruments TI-84 Plus Calculator
How to fix INVALID DIM in plotting graph
The ERR:INVALID DIM error message may occur
turn the stat plots off, press y ,and
square.
Apr 05, 2014 | Texas Instruments TI-84 Plus Calculator
How do I fix invalid dimensions
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If you're not trying to graph a function, please tell us exactly what you are trying to do when you get this error.
Jun 13, 2013 | Texas Instruments TI-83+ Graphing...
Error message invalid dimensions
INVALID DIM error message may occur if you are trying to graph
a function that does not involve the stat plot features. The error can be
corrected by turning off the stat plots. To turn the stat plots off, press
y , and then select 4:PlotsOff.
Jan 19, 2012 | Texas Instruments TI-84 Plus Silver...
How do you fix the texas instrument calculator that does not graph. It says invalid dimension.
Nov 23, 2010 | Texas Instruments TI-83 Plus Calculator
Every time I try to graph on TI 84 it says ERR: INVALID DIM 1:QUIT I have enterered something simple y= x+2 and window is set for -10<x<10 and -10<y<10 the curser in y=...
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf to download the manual. On page 401, you will find the following:
INVALID DIM • The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff. • You specified a list dimension as something other than an integer between 1 and 999. • You specified a matrix dimension as something other than an integer between 1 and 99. • You attempted to invert a matrix that is not square.
Nov 11, 2010 | Texas Instruments TI-84 Plus Calculator
Everytime i try to graph something, it says error: invalid dimensions. I cant figure it out! can you tell me what to do?
Aug 30, 2010 | Texas Instruments TI-83 Plus Calculator
INVALID DIM error! help me!
Here is what the manual says
INVALID DIM : The dimension of the argument is incompatible with th current operation. (As dimension of a matrix, a list).
You can tell us more about what your were trying to do, we may able to help. Reset memory to default, the error may disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps.
Sep 02, 2009 | Texas Instruments TI-83 Plus Calculator
I need help with graphing everytime i try to draw a graph it comes up with this ERR:INVALID DIM what does that mean
It means that your Xmin or Xmax is messed up. it often shows up when you are plotting somethings (histogram for exanple) and you don't have enough X or Y range to fit all the points in it. it also happens when you are multiplying matricies without using the right dimensions. ERR:INVALID DIM just means your dimension is invalid.
Mar 06, 2009 | Texas Instruments TI-84 Plus Silver...
Invalid Dimensions for Graphing and Equation
I suspect you are using the TINspire in TI84PLUS mode (with the TI84 keyboard).
If that is the case, the simplest procedure is to turn off STATPLOTS.
Press [2nd][STATPLOT] [4:PlotsOff][ENTER]. Calculator displays Done.
Hope it helps.
Nov 12, 2008 | Texas Instruments TI-Nspire Graphic...
Texas Instruments TI-83 Plus Calculator Logo
81 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
