Question about Viking 31 in. DECU165 Electric Cooktop
Glass cooktop is loose and bowed up in front it will not stick down onto gasket
The glass of the electric cook top is lifting from the stainless steel frame
[PDF]Professional Performance for the Homeā„¢ - Viking
www.vikingrange.com/.../m10103_viking_built-in_surface..
Viking RangeFortunately, our built-in rangetops, cooktops, and gas woks offer the ... sealed or open burners, every Viking gas rangetop delivers unrivaled ..... The only thing cleaner than the glass ceramic surface of Viking electric cooktops is the installation.
Sep 30, 2015 | Viking Cooktops
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
Kitchen aid KECC507GBL3 electric 36in cooktop. Burner switch is out - cannot get glass top off. Have removed all screws from plate mountings on the sides. Is there a trick to this?
If it’s a range, there is usually a couple of screws that hold the front of the top down, remove the screws, lift the front of the top and pull it out from the back hinges. Install the new top, make sure there are no loose wiring.
If it’s a cook top then make sure that the power to the cook top has been turned off, open the cabinet and look up. There should be a couple of brackets that secure the cook top. Remove the brackets, carefully lift the top and set it on the counter top (put a towel on the counter top first). replace the glass top (make sure there is no loose or exposed wiring), set the cook top back in the counter, secure it with brackets as was before, and double check your work.
Thanks for contacting fixya.com
Jan 14, 2010 | KitchenAid Cooktops
Was cooking fudge-hot sugary liquid boiled over onto glass cooktop. I tried to clean, but appears as if glass top has been ruined. It is rough. Tried scraping with razor, but does not help. Used cooktop...
Maybe try white vinegar - apparently you can clean glass hobs with it & it might help dissolve the fudge stuff if you pour it on that. I wouldn't use a razor as you might damage the hob more.
Dec 15, 2009 | Jenn-Air JED8430 Electric Cooktop
Replace JED8430ADB Ceramic Glass
First, you have to pull out the cooktop from the counter and remove the knobs.
Next, there are hex screws around the perimeter - do not remove the lowest ones on the front and the back (they hold the tray that the burners sit in) or the ones on the bottom (they help to hold on the blower assembly).
The final trick are two screws that are located in the downdraft plenum - there's one on each side (you don't have to remove the two in the back or the front - those are for small covers only).
The glass should lift out.
When putting the new glass in, remember that the plenum walls fit on the inside of the glass (you won't see the top of the steel).
Nov 25, 2008 | Jenn-Air JED8430 Electric Cooktop
GE gas cooktop
Wow, never heard of that,.... bleeding through glass? I checked the GE service web site and there are no Service Bulletins relating to anything like this. I guess if it were mine and I had that history with it, I'd try the new top, but removing the gasket and first putting a layer of foil duct tape on the underside of the new glass top, then use some new foam gasket material under the cooktop. Good luck. Please don't bother to rate this solution, as anything but a fixya will lower my rating. Thanks.
Nov 08, 2008 | Cooktops
Replace burner seals of gas cooktop
good day,
hope this link below will solve your problem.
kitchen
Sep 03, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
Glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Jul 10, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Thermador wcggcv30 gas cooktop - how to remove glass top
Remove the brass ring nuts and the screw from each of the burners and pull off the knobs, then lift up the glass cooktop; no need to remove the three screws around the perimeter or even take out the box.
Nov 23, 2007 | Cooktops
Viking 31 in. DECU165 Electric Cooktop Logo
96 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Ed Mac
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
