Question about Fisher Paykel EcoSmart GWL15
Fisher&paykel smart drive 9 excellence 6.5
Hi guys
My problem is the machine works for about 1min then shuts off. I have to wait 3 mins before it turns back on using the power switch it works for about 1 min then shuts off again. Its been to technician who changed the face cover thinking water was getting behind buttons causing it to cut out well problem is still there.
If anyone knows the problem please help
Robert
    Sergeant:
  • 351 Answers
Check the reed switch under the lid (magnet). also check the lid switch under the motor control board for rust,check that the inlet valves have the same ohms reading,if there diffrent change both of them.also are the hoses on the correct taps because it may be stopping while filling.(both taps on)
Posted on Mar 02, 2008
ginko
  • 19396 Answers
SOURCE: Fisher & Paykel smart drive
It is either the inlet valve or the pump. If the pump is fine you need to replace the inlet valve. Here you can find parts.
Posted on Jun 08, 2008
TheMobilian
  • 8220 Answers
SOURCE: We have a Fisher & Paykel Smart Drive 9
As a result of the agitator action, lint and wash water are sucked into the agitator stem and down to
the base of the agitator, where they are directed into the cavity between the basket and tub. The
extruded holes in the basket are shaped to allow the wash water to flow back into the tub, but
prevent the lint from following.
The lint then floats to the surface of the water, between the basket and tub and remains there until it
is flushed out the drain at the end of the wash cycle.
An older F&P MANUAL
Posted on Sep 13, 2009
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Posted on Feb 20, 2010
SOURCE: fisher & paykel excellence 7.5 smart
www.fisherpaykel.co.nz/admin/pdfs/pdf_usecares/426991_aw_uc.pdf
Posted on Sep 14, 2010
  • 44 Answers
SOURCE: I would like to download
You need to get the exact model number and enter it at his website http://www.fisherpaykel.ca/customercare/userguide/
Posted on Oct 16, 2010
I have a 2006 camry v6 engine having proplem with engine starting and when engint starts rpm goes up and down with fuel mixture rich
HI !
YOUR CAR ENGINE IS ETC SYSTEM ? (electronic throttle control) i think need clean the throttle body first .disconnect the ETC fuse & EFI fuse in fuse box more 1min .after connect back the fuse .turn switch on 1min.off all electrical A/C or lighting .star the engine hole the throttle 2500-3000rpm 3 min .last turn off engine & start the engine .this is ETC learning .
Oct 17, 2014 | 2006 Toyota Camry
Error C3102
The Fuser is not turning... follow these steps
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key. Keep holding it till the T reset appears
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, wait 10 seconds and turn the machine back on, this should reset the service code and with any luck the machine will run!
May 03, 2014 | Konica Minolta Bizhub C451 Copy-print-scan
Brand new L7680. Just set it up with the software and the screen is showing a failure signal 'Alignment failed. Refer to device documentation for details. All that says is run the process again. I have, 5...
This not an issue w/ the software. please follow these steps...
Solution #1 Clean all the inks
  1. open the cartridge access door.
  2. take out all the inks that you have on the printer. (put them on the table upside down)
  3. get a wet clean cloth.
  4. on each cartridge you need wipe it out the electrical contacts on the ink cartridge it self.
  5. put the inks back in to the printer.
  6. close the cartridge access door
  7. turn off the printer
  8. unplug/disconnect the power cable
  9. wait for 1min.
  10. plug the power cable back in back in to the printer.
  11. turn on the printer.
  12. access the setup menu (press the wrench icon on the printer or setup button)
  13. Go to tools, then look for clean printhead
  14. align the printer.
Solution #2 Clean the printhead manually make sure that the printer is on.
  1. Open up the cartridge access door
  2. Take out all the inks that you have on the printer. (put them on the table upside down)
  3. Once you have take out the inks.
  4. Take out the printhead (printhead is the one that holding the inks)
  5. look for the printhead latch. (pull it up)
  6. Take out the printhead.
  7. Clean the electrical contacts of the printhead using a wet clean cloth again.
  8. Put the printhead and the inks back in to the printer.
  9. Close the cartridge access door.
  10. turn off the printer
  11. unplug/disconnect the power cable at the back of the printer.
  12. wait for 1min.
  13. plug the power cable back in to the printer
  14. turn on the printer.
  15. repeat cleaning and aligning the printer by going to tools under setup menu (wrench icon).
Solution #3 Reset the Printer
  1. While the printer is on unplug the power cable at the back of the printer
  2. On the printer press the # and number 3.
  3. keep on pressing for 1min.
  4. After 1min. plug the power cable back in to the printer.
  5. If the printer is not turning on press the on/off button.
  6. You should get a message "part NVM reset" , then follow the following task. (cleaning and aligning printer).
If you still having issues w/ it call HP printers support department 1-800-474-6836
Good luck! :)
Jan 31, 2011 | HP Officejet Pro L7680 All-In-One Printer
My colman rooftop ac unit shuts off after 5 min of use wait 5 more and you can turn it back on again when its running it works great its on a 1984 holiday rambler and has very low hours?
Try a new fan motor. It runs about $125.00, It will run a few min. then will trip the motor themal switch. you can probably still here the compressor running. It may also trip the breaker on shore power . good luck! the part you are looking for is a 1/3 hp 115vac 2 speed 1580/1020 rpm part number #1468-3069
Aug 25, 2010 | Coleman Mach III Air Conditioner
It wont work!
HI,
Please allow your phone to charge for 3-4 hrs by connecting it to the wall charger.After 4hrs remove the battery from the back and reinsert it.Then press and hold the power button for 1min.Make sure it is connected to the charger when you perform these steps.
Let me know if the phone turns on or not.
Apr 09, 2009 | Sony NWZ-E436F MP3 Player
Computer keeps shutting off
The problem more likely seems with the power supply or the front power button. Donnot try switch on the computer again and again it may cause damage to the motherboard. Use the following link to pin point the problem.
http://tinyurl.com/5bbrxc
Thanks
Proton
Do remmber to rate the solution if it was helpful or fixed your problem.Thanks for using fixya
Jul 05, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
I can't access ther router using 192.168.0.1
Hi Wafula,
Unplug the Dlink, wait 2 min, and plug it back in. If that work, on the back is a small hole, marked RESET. Using a pencil, or straightne out a large paperclip, press that the button inside gently. Hold it for 30 sec. Release and unplug the unit. Shut down the whole network. "Starting from the wall", power up the modem, wait 2 min, power up the Dlink, and power up your machine. Your Dlink should be at default now. Remember to reset you security, change the password, etc.
I have had to do this several times, sometimes unplugging the power, and plugging it back while holding the button. (Got 3 hand?)
Jan 10, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Computer won't start up!
Waiting for 10 or 15 or even 30 minutes doesn't make much sense to me. What kind of flash drive or drives do you use? .. USB Thumb/Pen/Flash drive? .. If your flash drives in "My Computer" folder just happen to disappear, does the computer still working or freezed state? When you say your computer does not want to start on AT ALL.' the machine is not running at all or just that the operating system is not booting up?
Sep 18, 2007 | Medion M3 Director 5100 PC Desktop
Fisher Paykel EcoSmart GWL15 Logo
130 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
