Question about Panasonic PT-47WX49 47" Rear Projection Television
My tv is showing double images - Panasonic PT-47WX49 47" Rear Projection Television
Put it out on the curb and buy AMERICAN!
Posted on Feb 08, 2010
  • 4234 Answers
SOURCE: tv shows double images
This is a problem within the convergence circuit. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Dan
Posted on Jan 27, 2009
MikeNJ1964
  • 398 Answers
SOURCE: double imaging
The Toshiba 55H70 is a standard rear projection set. It does not have a "lamp", it has 3 picture tubes. When the colors suddenly do not line up on the screen, it means that one of your convergence output IC's has burned out and needs to be replaced. This is very common on those sets. If your set is using the STK392-110 IC's, it is probably a good idea to go ahead and replace both IC's with the newer upgraded STK392-150 IC's. The IC's should be replaced and the convergence circuits realigned by a qualified tech familiar with Toshiba projection sets.
Posted on Sep 11, 2007
C-Dog
  • 84 Answers
SOURCE: Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Posted on Feb 18, 2008
  • 2920 Answers
SOURCE: double images
you will need to have the tv re converged to make the picture right call a repairman
Posted on Feb 16, 2009
asnowman
  • 788 Answers
SOURCE: the tv screen shows double images
Your symptom sounds like a damaged convergence IC.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board2.gif. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
asnowman
Posted on Oct 14, 2009
Sony lcd tv double image
What is it connected to?
Apr 08, 2014 | Televison & Video
Blu Ray showing "split screen/double
Did you check your settings on your tv and blu ray?
Jun 04, 2017 | Televison & Video
My tv is almost 6yrs old and all of a sudden the picture is blury almost showing double images. The color is also of at the top and bottom of the screen.
this is typic old projection tv, some tecnical ajust parameters have reset, so if you can adjust,this settings on service menu on tv, or ask for help on local repair store, to calibrate scren.
Nov 29, 2009 | Televison & Video
Our TV is showing double images
Due to failure of convergence out section in rear projection TV, it gives double image on screen.
Replace convergence out ICs on main circuit board of TV to fix this problem.
Let me know if you want to fix TV by yourself and you have electronics repair tools and knowledge to follow instructions., also confirm TV model and brand to provide you more technical info.
Thanks.
Nov 28, 2009 | JVC AV-56WP74 56" Rear Projection...
Double screen image
Double image shows that TV got problem of Convergence Out ICs failure and will be replaced two ICs mounted at D Board of TV.
ICs, STK392-360 are available in Part Store, click to see an image and price info.
Apr 27, 2009 | Sony KP-65WS500 65" Rear Projection...
Tv shows double images
Look for the convergence menu in the manual and try to align it.
Apr 02, 2009 | Toshiba TP55H60 55" Rear Projection...
Symphonic sc 1304 combo vcr records double images
I would try to clean the heads. Before I do anything else. You can buy a good head cleaner at Wal-Mart! Good luck with this.
Mar 12, 2009 | Symphonic SC313D 13 in. TV/VCR Combo
Double images
Feb 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Dan
Jan 27, 2009 | Toshiba 55H70 55" Rear Projection...
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
239 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
