Washer stops with a E 10 error several times during wash cycle Frigidaire -Electrox Front Load Washer Model GLTF2940FSC
  • 1,531 Answers
This is a general error code.the first thing you need to check is the drain pump,and look for anything that may be obstructing the flow of water coming out.
if you still hav water in the tub you can use a wet/ dry shop vac and attach it to the end of the drain hose and remove all the water then you need to remove the front panel and look at the drain pump
Posted on Feb 08, 2010
Testimonial: "Thank you"
  • seth adams Feb 08, 2010
    this is a general error code.the first thing you need to check is the drain pump,and look for anything that may be obstructing the flow of water coming out.
During the wash cycle, an error HE appears, and the wash cycle stops. the clothes are soaked with water
Hi areej, this is AP! Thank you for your post.
I understand you are experiencing an HE indicator during the wash cycle on your Frigidaire front load washer. I would recommend contacting a local technician as this appears to be a problem within the motor speed control board. However, I would recommend a local authorized technician to come out and properly diagnose and repair your front load washer. I hope this information helps.
Mar 05, 2014 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire front load washer. When I start a new load it starts with a couple of seconds of water then stops. Does not go into a wash mode, the timer shows it's going thru the cycles but
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 08, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a ATF7000FS1 washer that has been pausing the wash cycle on it's own. I will have to press the start/pause button during the cycle to restart. This happens several times during a wash cycle. How...
some machine will stop before spin its called crease guard if you are useing a low temp cycle its there to give you the option to stop your cloths wrinkling try another cycle
Nov 08, 2011 | Frigidaire Affinity ATF7000E Front Load...
During any cycle washer will stop and beep and flash E10. after pushing start it will continue, sometimes will do this several times in a load.
i believe that code is water related not getting enough water maybe drain hose is too far down drain and unit is siphoning
Apr 18, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore model 41743142200
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Jan 07, 2008 | Kenmore 45081 Front Load Washer / Dryer
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
