Error code BIOHD-8, cant start windows I have a Compaq computer but cannot get windows started (keeps on booting and booting for ever, safe mode and all other modes dont work).. Pressed F9 for diagnostic and the following details came up as the cause of problem; Drive Error code BIOHD-8, a SMART test failed on the drive. Suggestions: Backup important data/ contact HP support. The software build is 92APheREA1 Any help please?
    Guru:
  • 458 Answers
A BIOHD-8 error refers to a Hard Disk failure.
This error message occurs when the Hard Disk has failed.
It is a very common problem with HP hard disks.
Unfortunately, when the Hard Disk fails, it can not be fixed, the only solution here would be to back up your files and replace your Hard Disk with a new one.
I would recommend that you buy a Toshiba Hard Disk because they are one of the most durable Hard Drives in the market and they rarely get faulty.
Thank you for using Fixya,
Kenneth
Posted on Feb 15, 2010
BIOHD-s no drives detected
Error Code Biohd-2 No Drives Detected errors are caused by missing system files or broken system registry structures. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
If you are unable to get a connection with your hatd drive
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
You might have to use safe mode with Networking to download
Select safe mode with Networking to download
Oct 07, 2013 | HP Computers & Internet
Will not boot in to windows keep reseting error. 100a biohd -8 hd535-3 hd535-6 hd521-4 hd521-2
boot your laptop in safe mode by pressing F8 while starting the computer. follow this link http://download.bleepingcomputer.com/malwarebytes/mbam-setup-1.51.1.1800. download and install antimalwarebyte while in safe mode. Run a complete scan, restart the laptop, update your antivirus and do a complete scan and you will be good. If your laptop restarts when trying to boot into safe mode, then you need to repair your Operating system with its original disk. This would solve your problem. Please give me a feedback
Aug 09, 2011 | HP Pavilion Elite m9515y PC Desktop
Error unitialized corrupt boot structure detected biohd-4 boot path, keep getting this after trying to install windows 7, cant boot disk anymore so cant install windows 7
try repairing the file system using chkdsk with /f switch. However, it is strongly recommended to run this tool only if you have a full data backup
. To do so, click \'Start\' and then \'Run\'. You can then type \'chkdsk /f <drive name>\' in the \'Open\' box and click OK. Here, the drive name should be exactly what is appearing in error message. Alternatively, you can opt for deleting the corrupt partition provided the backup is available. If no good backup exists, you should consider to use a Windows Data Recovery utility. These are powerful and valid Windows partition recovery utilities built to scan the corrupt or deleted partitions and safely recover the lost data. The applications are easy to install and use.
Jun 11, 2010 | HP Pavilion Slimline s3620f Desktop
How to Reset HP Mini 1000 Laptop BIOS?
http://laptoppassword.blogspot.com/2011/06/hp-mini-password-service-compaq-mini.html
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
Cant get windows xp to load
Hit F8 while it is booting up and take it into SAFE MODE if at all possible. From there run an error check.
Go to My Computer - right click on C: -- go to properties - then select Tools - error check. Make sure you check the two boxes to have windoews fix the errors as they are found. The error check should run after you restart your computer.
if it still doesn't load.. reboot while presssing F8 and take it into safe mode and use SYSTEM RESTORE to restore computer to earlier date.
Go to:
START - ACCESSORIES - SYSTEM TOOLS -- SYSTEM RESTORE. and then select a date computer was working ok.
May 27, 2009 | Compaq Evo N600c Notebook
Error code:BIOHD-8
Rebooting forever is either memory fault or the HDD have corrupt system files. From the BIOHD-8, it sounds like HDD issue. Try download "HDD Regenerator 1.51" CD ISO, burn to DC and scan to whole Harddrive. This nice software is designed to recover corrupt/bad sectors. I had a friends PC falls into this case. 1 bad sector was found and recovered within 2GB from start where most Windows system files are stored. Then reboot and windows do a chkdsk automatically, and resolved!
Apr 16, 2009 | HP Computers & Internet
Computer will not boot up. I have tried to boot up in safe mode, normal, safe mode with prompt command...nothing works, just goes back to the normal start up screen and keeps doing the normal start up over...
It looks like you're encountering an endless reboot? Here's what to do to find the actual error message.
  1. Turn on the computer, and press F8 after the POST screen but before Windows attempts to start to access the advanced startup options.
  2. Select "Disable Automatic Restart On System Failure" and press Enter.
You should now get a blue screen with an error message and error codes. Please write these codes down and report back.
Mar 24, 2009 | HP Compaq Presario SR1830NX PC Desktop
Compaq Presario 700 PC Notebook ''they keep start up they dont wanna gotrue open the windows'' Problem when shut down when i start up again they keep start up showing the window xp and re start back again...
When turning on the computer keep pressing F8
Select boot into safe mode
Then in safe mode click start then run then type in MSCONFIG
Click on Launch System restore.
Restore your computer to the day beforeyour problem started.
Mar 06, 2009 | Compaq Computers & Internet
Hello... My Windows XP has the following registry failure (c:0000218) I've attempted to boot up my Avanquest Systems Suite 8 Rescue disk, but it has failed. I can't get into safe mode, etc. Thanks, Paul
Sorry to hear about your trouble. From the error you stated, it seems your SR got corrupted (common with norton/symantec products). The best bet is to try System Restore from Safe Mode.
As for your second problem, here is an alternate way to access Safe Mode (I am assuming you can get into Normal Mode):
  1. Go to START, then RUN
  2. type "msconfig" and hit enter
  3. the system configuration window will appear
  4. among the several tabs across the top, one of them will say "boot.ini", click this tab
  5. there will be a box that you can check next to Safe Mode.
  6. Click Apply, then OK
  7. Restart
  8. Keep in mind that your computer will automaticall go in to safe mode until you uncheck this box.
Good luck and keep us updated!
TJ
Nov 30, 2008 | Avanquest System Suite 8: Windows
608 people viewed this question
k24674
jasbo
jasbo
