Question about Poulan Garden
One broken bolt that holds the chain bar. It
One broken bolt that holds the chain bar. It moves but it seems to be comming from the other side of and wondered how to take the case apart to get to the broken bolt and replace it with a new one.
    President:
  • 2,220 Answers
You do not tell us which model Poulan, that limits how much help we can provide. The head is probably in the oil tank.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/showthread.php?t=63219&highlight=Bar+stud+replacement
Post 6 in this thread is quite good. I have seen a post that required repair of the casting (with photos) to repair. I was not able to find it.
Look closely at the old one, once removed, See if it has some sealer applied
The IPL for your saw can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If I can be of further help please reply below. HTH
Lou
Posted on Feb 08, 2010
Tightening chain
Tightening chain is performed by adjusting the bar. Two bolts generally hold the bar in place. Loosen these. Make sure that chain has enough play to easily move by hand. If it sticks, it's too tight. Then tighten the bar, check the chain oil, and cut wood.
Mar 25, 2015 | Garden
Rf600r tighten chain
Chains are tightened by extending the chain bar. Loosen the two bolts holding the chain bar, move the bar away from the engine body and hold it upward (bar should be angled upward slightly) before tightening the bolts back down.
Nov 19, 2013 | Garden
Chain comes loose ms 391
Check the chain tension as you cut. The chain will stretch as it warms up. Be sure the side bolts that hold the bar are snug. Lift the bar upward when you are adjusting the chain and while you tighten the side bolts. Never cut with a loose chain.
Oct 24, 2013 | Stihl Garden
Change blade
all chain saws have a sprocket that the chain runs on this sprocket is what make the chain rotate on the bar. the bar is the long part that sticks out in front of the motor. you must remove the side cover of the saw to access the sprocket region of the saw. be sure the saw is unplugged and then remove side cover the bar is usually held in place by a couple of bolts. on gas saws these two bolts also hold the side cover in place and must be removed to replace the bar and chain. once you have removed the side cover look for bolts holding the bar in place. if you only want to change the chain then you may be able to only loosen the bolts or screws holding the bar in place.there should be a screw to adjust the bar forwards and backwards. this screw put tension on the chain so when you put a new chain on turning the screw will proberly tension the chain /do not overtighten the chain.
also be sure you put the new chain and blade on the same as the old one that comes off trying to cut with a chain that is on backward does not work. last note if you are replacing the blade because the old one is dull take the saw to a saw shop they can sharpen the exsisting chain and save you money.
Jan 24, 2011 | Remington Electric Chain Saw
How to adjust the tention on the roller catch
  • Locate the guide bar retaining nuts on the side of the motor that holds the bar. Use the guide bar retaining nut wrench to loosen the two bolts mounting the bar to the motor.
  • 2
    Locate the chain tensioning screw on the front of the motor housing near the guide bar. Turn the screw clockwise to increase tension and counterclockwise to release tension. Tighten the chain until the chain moves freely along the length of the guide bar, but is tight on the curves of the bar
  • Read more: How to Adjust a Chainsaw Tension ' eHow.com http://www.ehow.com/how_4894871_adjust-chainsaw-tension.html#ixzz19dQwO8tJ
    Dec 30, 2010 | Garden
    I have an 18 inch bar and the chain has to be tightened every few minutes. I tighten the nuts against the bar as tight as I can but the bar must still be moving to loosing the chain. Do I need to add lock...
    There is an adjusting pawl with a screw that does the tightening. The nuts only clamp the bar once the chain is tightened. The adjusting screw is in the plane of the bar. The pawl may have disengaged the bar or may have broken.
    Jan 01, 2010 | Poulan PP4218AV 18" Chain Saw
    Can not keep chain on bar. Tried 2 different
    The inside part of the chain are called drive links. I think when the chains came off the first time (loose chain?) some of these links were slightly deformed (burred). Take a flat file to the burrs on the sides of the drive links. Once repaired keep your chain properly tensioned.
    Chain adjustment
    1. Make sure the chain brake is off (gloves will protest your fingers).
    2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
    3. Ease the tension adjustment until the chain is obviously loose.
    4. Using one hand, hold the nose of the bar up.
    5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
    6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
    Lou
    If no burrs please repost. This has piqued my interest. I think a brand new chain will operate correctly.
    Oct 31, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
    Reinstalling chain and adjustments
    Use this as a guide:
    http://www.youtube.com/watch?v=P8_OcnIC3ZI
    He does a few things wrong
    Chain adjustment
    2. If necessary, loosen the nuts that are clamping the guide bar in place (or whatever your saw uses to hold the side plate and bar on with). We don't need these really loose - just finger tight will do.
    3. Ease the tension until the chain is obviously loose.
    5. Now, while holding the nose up, adjust the tension so that the chain just touches the underside of the bar.
    6. Continue holding the nose of the bar up & tighten up the side plate nuts / bolts / quick-release system.
    Sep 26, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
    How to replace chainpoulan pro 18"
    First lay the new chain out with the cutter teeth facing forward on top. You should wear gloves because it takes very little to inflict a deep cut with these chains.
    Take the tool that came with your saw and loosen the two nuts (don't take them off yet)that hold the sideplate on over the chain. Leave the saw setting on its bottom.
    When the nuts are loose take the screwdriver end of your wrench (or a screwdriver) and loosen the chain quite a bit. Wearing the gloves, make sure when you pull it forward it moves very loose.
    Now take the two sidecover nuts all the way off. You'll see how the chain goes arpound the sproket. Push the bar back toward the sproket until it is loose enough to remove the chain.
    The bar will come off too, and it is important to note the small nub that goes in the tensioning hole on the bar near the bottom of the saw, fairly close to the sproket. Keep the chain straight; I hang mine on nails driven into the wall in my shop. You can get them kinked up so that they seem they'll never straighten out.
    Take this time to clean all behind the sidecover itself, and the entire enclosed area. There will be sawdust, twigs, etc. I blow mine off with compressed air, but protect your eyes. Take something, toothpick, Qtip, or the like and clean the groove all the way around the bar, including the oil holes near the rear.
    You should now be ready to insert the new chain, putting the bar with the slot lined up with the sidecover bolts, and gently get the chain on the sproket. This may take a couple tries before you get it right. When it is on (you'll see you have to hold the bar up or it will tip too much) hold the bar in place with the tightener in the hole, and slip the side cover back on. Tighten the nuts just enough to hold the bar in place, then tighten the chain tension screw, while holding the bar. Tighten the side nuts more, until the bar is held in place.
    When it is just tight enough to hold the bar but not prevent the bar from moving forward when you tighten it, tighten until you can still move the chain, but there is no visible slack in the chain. You should be able to grab the chain at the bottom and with moderate force pull it away from the bar about a half inch.
    I like to pour a little oil on a new chain so it has plenty of lube. The chain will stretch because it is new. Run the saw at about 1/3 throttle for a minute, holding the end close to something to make sure the chain is throwing off a fine thread of oil. Then run it at 1/2 speed about another minute. Rev it a few times, make a practice cut or two, and it should by now need another slight tightening.
    Sirwriter
    Jun 07, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
    Chain tension
    Hi Sally, I guess you don't have the owners manual. It tells you how to adjust chain tension. If you look around near the motor side of the bar, you should see two nuts that hold a bracket tight against the bar and an adjustment screw or bolt or something to loosen or tighten the chain by moving the bar or making it longer or shorter. Adjust that so that the bar is as short as possible and put the chain back in place. Then tighten that feature till the chain is snug again and tighten the two nuts to hold the bar firmly.
    Sep 07, 2008 | Remington Electric Pole Saw
    Garden Logo
    122 people viewed this question
    Top Poulan Garden Experts
    Roland W VanLue
    Roland W VanLue
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
