Question about Samsung L200 Digital Camera
My samsungL200 camera has a cord with a rectangular plug on one end and 2 round plugs a yellow and a white on on the other end. How does it plug into my processor?
  • Samsung Master
  • 5,568 Answers
This is probably an audio/video cable. This means you will have to buy a USB cable to download the camera's stored pix. Since there are (way too many) different connectors used on cameras, I recommend taking the camera with you to ensure you get the right one the first time. The other end should be the typical flat, rectangular USB connector that will be plugged into your computer system.
Depending how old/new your computer system is, you may have a 'card drive' that can accept your camera's memory card. If it does, you can remove the card from your camera and plug it into the card drive to download. If using Windows, you can 'open' the camera's memory card just as with any drive and it will show on your 'My Computer' screen. If you see only a single folder, you may have to open that and perhaps another to find your picture files which will likely be '.jpg.'
You can copy and/or move these files to your hard drive for viewing and processing.
Posted on Feb 08, 2010
How to we connect from projecter to tv
depends on what type of output the projector has if it has a round 5 pin connector then you will use an S video cord and a separate audio cord which is either 1/8 inch like a headphone jack with RCA cables plugs on the end or two RCA plugs on each end.
if it has a rectangular connector that is sloped on 2 sidesthen you'll use an HDMI cord which has both video and audio.
if it has three colored circular connectors then you use RCA cables video is yellow audio is red and white or black
Jan 10, 2015 | BenQ Office Equipment & Supplies
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
Charging battery
If you want to charge your battery within your camera you must plug in the charger cord to the camera while the battery is inside the camera. It is the round cord end that comes with the original camera.
Feb 20, 2013 | Polaroid Z2300 Instant Print 10mp Digital...
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
I have one of the older models of delonghi but the plug got burned off due to attaching and improper extension cord. Is there a possiblity for the cord to be replaced
I don't know how much trouble it is to access the heater end of the cord but if you can see how to do it, it would be a good time to replace the entire cord & plug. Any of the home improvement stores (if in the US) will have the right materials and you will have the chance to lengthen the cable to eliminate any extension cord. Make it 20' if you choose, the wiring will handle it.
Ask or look for a 3-conductor flexible heavy appliance-type cable with at least a 15 amp rating. This may be marked as 2/12 and will have a third wire for safety ground, generally colored green. The other two will be one black and one white insulated conductor. When properly wired, the white is neutral, the black is 'hot.' The plug will be fairly large and have screw terminals for the three wires. This type of replacement plug will handle any 120 V household appliance. The actual blade contacts that go into the receptacle may have one wide, one narrower, and one round pin for the standard outlet. The wide blade inside terminal for the wire is intended for the white insulated wire, the narrow for the black and the ground (green or green/yellow) insulated wire goes to the round ground pin's screw terminal. These plugs are equipped with a substantial strain relief under which the entire cable diameter is clamped.
Inside the heater's attachment area, there should be currently wires attached that correspond to those in the new cord but if not, they may be marked as in Europe (the brand is Italian) and that may have changed since I left there years ago. If you find the following colors, substitute the paired color for US use:
- Brown = US black = Hot - Blue = US white = Neutral - Green or green/yellow = US green or green/yellow = Ground
If you find anything else, let a professional connect the new line for your own safety.
Dec 06, 2010 | DeLonghi TRD0715T Oil Filled Radiator...
I HAD ONE LEAD IN MY BOX IT FITS IN THE CAMERA BUT I CANT FIND WHERE TO PUT IT ON MY LAPTOP THE LEAD HAS A WHITE AND YELLOW END
The white and yellow end are meant to go into a vcr or tv. You need a cord with a USB end to plug into your computer.
Sep 04, 2010 | Cameras
Manual for samsung es65 camera I would like to view my pictures on my samsung TV I was told I could do this direct from the camera to the TV just by using the a/v cable Is this correct and if so what ports...
You can download a user manual from here:-
http://downloadcenter.samsung.com/content/UM/201002/20100202195655453/ES65_ES67_English.pdf
You should have a AV cable with the camera, that has 1 round plug at one end and 3 round plugs at the other.
The single end plugs into your camera, there is a socket on the side marked AV. The three plugs at the other end go intot the TV.
They are colour coded (White - audio left, Yellow - Video and Red - Audio right) you need to find three sockets on your TV which match. Once connected and a slide show running on your camera, select one of the AV tv channels on your tv remote control.
If there isn't the 3 colour coded sockets on your TV, there probably is a couple of SCART connectors on the back (Big black socket with about 20 holes) You can buy adaptors, from electrical stores, which convert your AV cable out to a scart. Its just a box with the 3 coloured inputs and a scart output.
Jul 03, 2010 | Samsung Cameras
Where do I plug in the white and yellow cords into my computer ?
The white and yellow cords are av hookups (tv, stereo, etc.) You need to use the USB cord to connect the camera to your computer. Or, you could insert the card into a separate card reader and plug that into your computer.
Dec 30, 2009 | Samsung L100 Digital Camera
Does anyone know how to hook up a sumsung nv3, which comes with a yellow and white cord, one that hooks up to the TV) or is there another cord that was lost. I don't know, but if you can help I'd...
Thank you for using Fixya. Does the yellow and white cord have a round end with a metal tip on the middle? If it does that is the RCA cable, and it is meant for the Audio and Video inputs of the TV. If it is not round, please let us know the exact model of the camera so that we will be able to find out how the cables should be connected.
With regard to the camera being connected to your computer,, generally what camera uses is a USB cable.
Jan 04, 2009 | Cameras
Samsung L200 Digital Camera Logo
46 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
