Question about Canon FAXPHONE L170 Plain Paper Laser
Can not transmit faxes
Everytime I am trying to fax a paper, the display shows "recieve", instead of "transmit". Can not send faxes.What is the the problem?
The model is: Canon Faxphone L170
Thank you
  • fax2000 Feb 25, 2008
    I have a separate fax line and it is set on the fax/phone mode.
    It says receive when I insert a document and dial the number and hit send.
    There is a dial tone when pick up a handset.
    I have no problem receiving faxes...
    Thank you
    Novelist:
    Champion:
  • 202 Answers
Mostly this happens when the firmware of the machine is corrupted
Try reflashing it through a nearby service centre
Also check the document feeder
Please do check the settings whether it shows receive only mode!
I hope this helps u, ..... advance sorry otherwise
Posted on Feb 26, 2008
  • 15 Answers
Does it say receive all the time or just when you insert a document and dial the number and hit send?
Have you tried another phone line?
When you pick up the handset do you hear a dial tone?
Posted on Feb 23, 2008
  • I don't know then. This is definitely a strange one for the books. Sounds like a bad problem with the modem or main board. I'd check with Canon to see if they have an repair/exchange program.
Do you have a seperate fax line? if so check the fax line.
also in the fax menu set up your fax to phone/fax mode, and set up all your fax info.
if you have distinq ring you need to set up your # of rings.
Everytime I am sending a fax i get the common error 20 02
Comm Error will show on the display if there is an issue on phoneline that were using.
First please check if the machine has a dial tone or try to call the fax # where you need to send the fax, just check if it's ringing. Second before loading the paper make sure that the display shows date & time. Then load the document in the tray the display should show enter fax # & start. Start dialing the # then hit start.
Hope this helps.
Mar 29, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
Transmit Error
To eliminate a machine problem, make a copy of something; you are using the scanner to verify if the mechanics are OK.
To eliminate a phone line problem, take the fax to another house or office and try there it again.
Oct 30, 2009 | Panasonic KX-FPG391 Plain Paper Thermal...
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Faxing from scanner rather than feeder.. help.
ideadly the scanner needs to scan to get the image to send out in fax form. The feelder paper feeder that is for recieving fax
Jul 31, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I can send fax but cannot recieve one it just rings
My Mode was wrong. I switched it to telephone and fax (instead of manual). Then i set the ring to pick up on the third ring. now i dont have to be here to press start everytime a fax comes. I found all the information by searching for the manual on line it is under "Basic fax settings"
Mar 19, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
I can send but cannot recievefax. Fax is on SLEEP all the time.
The machine is set with the sleep mode as a default. The fax part can be changed to recieve a fax by pressing the fax mode button. Press it until it says Fax only, not F/T. F/T means Fax/Telephone. This mode would make it to where you have to pick up the reciever and press start when a fax comes in. The Fax only mode means it will pick up everytime a fax comes in automatically. Let me know if this was helpful. Please give my helping a rating. Thanks!
Feb 11, 2009 | Brother IntelliFax-4100e Fax
When I try to fax and hit the send fax button in the window recieve appears
Fax machines are ANALOG devices. DSL is digital.
Before throwing it out, it would take it somewhere where there is a regular phone line (Plain Old Telephone System([POTS] and test it.
Sep 30, 2008 | Brother IntelliFAX 885MC Plain Paper...
BROTHER FAX/TELEPONE T76
Unplug and plug back in see if that gets rid of the check paper pls open top cover. Also make sure the confirmation is set. Transmission report on
Oct 31, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Paper feeding when printing recieved faxes
If this is primarily happening with receipts from one sending fax machine, the most likely cause is that the sending machine is transmitting an end code that causes this page to print.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Oct 26, 2007 | Canon FAX-JX200
Canon FAXPHONE L170 Plain Paper Laser Logo
259 people viewed this question
old marine
old marine
